Old Aug 09, 2012, 07:50 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Question
DX7 to DX5e delta wing setting
Hi All,
Setting up a foam jet for my grandson. Have never used the delta (elevon) setting on my DX7. My DX5e does not have the delta wing option. It's not a computerized TX.
We now buddy box with the two radios for my planes with seperate ailerons, elevators, and rudder. No problems there. But the foam plane we are building together is going to have just elevons.
I can set up the DX7 to fly the plane in the delta (elevon) mode, but will this function transfer to the DX5e when we buddy box.
Tom
tacx is offline Find More Posts by tacx
Old Aug 09, 2012, 07:59 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Your DX5e IS a computer radio, albeit a very basic one. Page 11 of the DX5e manual tells you which switch controls elevon.
http://www.horizonhobby.com/pdf/SPMR5510-Manual_EN.pdf
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Aug 09, 2012, 08:26 AM
freechip is online now
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Next to the four channel reversing switches you should have a MIX switch, this is the ELEVON MIXING Switch.
freechip is online now Find More Posts by freechip
Old Aug 09, 2012, 09:34 AM
tacx is offline
tacx's Avatar
Joined Apr 2009
Yikes !!! My bad. I didn't think to look at the manual. Daahh!
Just figured the DX5e wouldn't have that feature.
Thanks for the info.
Tom
Old Aug 09, 2012, 09:43 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
What's a manual? Even if you don't read the manual, you must of had to play with the reversing switches when setting up a model. You were never curious to see or know what that 5th switch (MIX) was for?
Old Aug 09, 2012, 11:07 AM
tacx is offline
tacx's Avatar
Joined Apr 2009
Nope, Never needed to mix anything. Didn't, use the DX5 that much. Learned with it on an eflite Apprentice, then bought a DX7. Have been using the 7 for everything.
Again, thanks for your help.
Old Aug 09, 2012, 11:10 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Have fun..
Discussion Need help on servos and settings for dx6i delta wing Wa7sh Foamies (Scratchbuilt) 4 Aug 08, 2012 06:08 AM
Discussion DX7 'EXP' setting on curve settings steveap1 Beginner Training Area (Heli-Electric) 7 Jul 16, 2012 09:51 PM
Discussion DX5e and elevons for delta wing coupe-r Foamies (Scratchbuilt) 2 Jul 21, 2010 11:41 PM
Discussion question on radio set up for delta wing elevons QinMD Electric Plane Talk 4 Jul 12, 2008 10:20 PM
Help! Radio setup for delta wing dx7 (7202) BrainDrain_dx Flying Wings 1 Dec 02, 2006 05:18 PM
