Old Oct 09, 2012, 04:02 PM
egicar is offline
Find More Posts by egicar
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Originally Posted by Alain RONK View Post
Bonsoir Egicar
Elles ne sont pas trop lourdes les batteries de 350 mah ?
Avec mes 200 mah, je peut tenir 4 minutes.
Amitiés
Alain
My website
: www.modelisme-racer.fr
We continue in English (my wife is French )
Well, yes, they are a bit heavy (22g versus stock 14g), but I put them near the RX and the COG is a bit toward the nose. But the plane is still flyable very well.
I just received, this evening from HK, the Nano-Tech 260 mAh 35/70C
The weight is 15,25g. I'll try them tomorrow after work and I'll report my flight time.
egicar is offline Find More Posts by egicar
Old Oct 09, 2012, 04:37 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
Originally Posted by whichwaysup View Post
Agree with Kenelder - With AS3X you don't want to get too slow, because the tip stall come suddenly and with little or no warning. However, while there are challenges with landing too fast, I have found that keeping the power on can help you get a good rollout. With such a short airframe, it seems easier to correct mistakes (over input on elevator when flaring, or flaring too high) when you are a bit faster.
really? I've been having great success hand launching over a high grassy field and for landings I've been real successful with a slow high alpha mush/stall at about a foot above the grass. I also fly sailplanes/ gliders and it helps in getting the feel for bleeding speed with the elevator while using very little or no throttle. With any kind of head wind at all dead stick landing haven't been too difficult at all..
rtbates is offline Find More Posts by rtbates
Old Oct 09, 2012, 04:57 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, VA, Roanoke
Joined Apr 2012
A little morning flying. Pretty rough - cold thumbs and too many days away from the sticks.
GeeBee flt1 10 9 (5 min 15 sec)
whichwaysup is offline Find More Posts by whichwaysup
Latest blog entry: Clever sayings
Old Oct 10, 2012, 04:26 AM
Alain RONK is offline
Find More Posts by Alain RONK
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
Hello !
@ Egicar : thank you for your replie !
The the Nano-Tech 260 mAh 35/70C is very interesting.
After flight testing, give me your impressions
Best regards
Alain
Alain RONK is offline Find More Posts by Alain RONK
Old Oct 10, 2012, 10:17 AM
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
Hello,
I have a question for you :
What's the signification of UMX, please ?
Best regards
Alain
My website : www.modelisme-racer.fr
Old Oct 10, 2012, 10:34 AM
egicar is offline
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Hello,
Best regards
Alain
Hello Alain,
here is what UMX means: Ultra Micro eXtreme
Ciao,
Egidio
Old Oct 10, 2012, 12:20 PM
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
OK, thank you very much !!!
Best regards
Alain
Old Oct 10, 2012, 01:31 PM
egicar is offline
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Hello !
Best regards
Alain
Hello Alain,
this afternoon I flew my Gee Bee with the Nano-Tech 260 mAh and the GWS 5030 propeller: 5:30 minutes. The LiPo absorbed 245 mA when recharged (it was at 3.7V per element).
I'm very happy about these results!!
Old Oct 10, 2012, 01:54 PM
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
Hello Egicar
Me too, this afternoon I flew my Gee Bee with the original battery. The flight is 3:30 minutes and after, 30% remains in the battery.
I used a small tester :
I used four battery so I can make several flights
Best regards
Alain
Old Oct 10, 2012, 02:23 PM
egicar is offline
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Hello Alain,
I have read the Volts on my GT-Power A6-10 charger, at the beginning of the charge process, and I've read the mA at the end of the process, at full charge.
Me too I have 4 x 260 mAh LiPo ... + 1 x 200 mAh stock LiPo + 5 x 350 mAh LiPo.
I use the 350 mAh in my MiniSwift as well.
If all these new 260 mAh will work good, I'll buy 6 of them at HK in the next days.
I also have to say that the GWS 5030 (mine are black ) propellers are very good! IMO, better than the stock one: more balanced and less Amp. draw.
Old Oct 10, 2012, 02:37 PM
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
Hello Egicar,
If this propeller is better, I command !
Another question of the plug of the battery 260 mah purchased at HK.
Is it compatible with the plug inside the GeeBee?
Best regards
Alain
Old Oct 10, 2012, 03:01 PM
egicar is offline
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Hello Egicar,
Best regards
Alain
Hello Alain,
you can find these propellers at HK as well.
About the LiPo plug, it is perfectly compatible with the Gee Bee female.
I also bought this adapter, so I can charge up to six LiPo in paralel with my charger.
Best regards,
Egidio
Old Oct 10, 2012, 03:24 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
modell-hobby-spiel 2012 - Gee Bee Air Race (4 min 13 sec)
Compare with non-AS3X Pole Cat racing....
PF Indoor fly Dec 11 Pole Cat RACING (2 min 21 sec)
It would probably make and even bigger difference outdoors.
Silverexpress is offline Find More Posts by Silverexpress
Old Oct 10, 2012, 03:52 PM
Joined Apr 2012
Man, that is good stuff!
Old Oct 10, 2012, 03:56 PM
Alain RONK
Alain RONK's Avatar
France, IdF, Melun
Joined Jul 2010
Originally Posted by egicar View Post
Hello Alain,
Best regards,
Egidio
Hello Egidio
With this adapter, can you charge up to six LiPo in the same time with the original charger ?
Best regards
Alain
Help! Adrienne Paige Gee Bee R2 Plans Eric Giorgiantonio Fuel Plane Talk 5 Jan 29, 2012 11:02 PM
For Sale Herr Gee Bee R2 (NIB) 25" wingspan pdawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Oct 12, 2011 10:20 AM
Wanted Adrian Page Gee Bee Z 1/5th and/or Gee Bee R2 1/5th (looking for) Xanix Aircraft - Fuel - Airplanes (FS/W) 0 Jul 23, 2007 06:16 PM
