Old Nov 28, 2009, 06:32 PM
grabber is offline
Find More Posts by grabber
grabber's Avatar
Joined Aug 2008
chattering eflight servos
I just put some eflight S75 sub micros in mini futana with AR6200 Spektrum reciever.
They chatter badly like they can't find center after you move a control.
I plugged a standard Futaba servo in to the reciever and it works normaly.
Is there a problem with these eflight servos?
grabber is offline Find More Posts by grabber
Old Nov 28, 2009, 06:56 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Are you using a ESC's BEC to power everything in the plane? The cheaper servos draw more power than a better brand servo does. It may be that when you go to run the servos, they draw too much power, become starved for current, and set off a chain reaction causing the receiver and the other servos to go all flaky on you.
Try temporarily connecting a separate battery pack to the receiver and temporarily disconnect the red power wire on the ESC's throttle cable, and see what happens.
If it works OK, then you likely are near exceeding the ESC's ability to provide power for your radio system in that situation.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Nov 28, 2009, 08:14 PM
grabber is offline
grabber's Avatar
Joined Aug 2008
thanks
I will that a try. that sounds like it might be likley.
This is my first eletric so I have things to learn.
Old Nov 28, 2009, 09:13 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Are they the regular S-75 or the newer S-75 digital?
coriolan is online now Find More Posts by coriolan
Old Nov 29, 2009, 03:01 PM
grabber is offline
grabber's Avatar
Joined Aug 2008
they are the regular S-75 servos
Help! Cirrus CS101 4g servos now chattering wingnutt Radios 1 Jan 30, 2008 08:30 PM
Discussion REVO 3.3 and chattering servos Lou Off-road Cars 5 Oct 05, 2006 01:53 PM
Chattering Servos Eric Mac Radios 1 Sep 10, 2005 07:51 AM
Question Chattering servos. nadg63 Radios 5 Oct 27, 2004 11:41 AM
Is there a fix for chattering servos? ErnieR Electric Plane Talk 5 Mar 06, 2002 06:09 AM
