Old Jan 07, 2015, 01:48 AM
RPC
Joined Oct 2008
New Product
Hermit Micro FPV brushless quadcopter 145mm 98g!
Hi folks,
Here we introduce our new produce Hermit Micro FPV brushless quadcopter, Hermit 145 is a newly designed micro FPV quad copter, only 140mm motor to motor size can it fly in the narrower and confined space easily. Although it is very small, it can install a 5.8G video transmitter(VTX), a DV of 120-angle lens, a flight control board integrated with receiver, GPS (option), OSD (option) and so on. Besides, you can adjust the distance of motor to motor through the frame, and the view angle of DV is adjustable too.
Features:
1) Weight: 67g (not including battery)
2) Flight weight: 98.0g (450mAh 25C7.4V)
3) Flight time: 9 minutes ( with 2S 450mAh 25C battery, VTX and DV on working)
4) Motor to motor distance: 145mm, 150mm, 155mm adjustable;
5) View angle of DV is +/- 25 angle adjustable;
6) Applied high efficiency brushless motor, its weight is 3g, KV is 4000;
7) Applied micro 5.8G VTX (200MW) comes with clover antenna, only 6.0 grams;
8) Applied super light DV, it is 720P/30F and with 120-angle lens, it supports real time AV output, its Micro SD can support 32G at the most, Micro SD is not included.
9) Integrated with DSM2 compatible 7CH receiver;
Hermit 145 compared with R7008SB receiver on size:
Included in box:
1) One set of Hermit 145 frame
2) MP03 brushless motor : 4 pcs (weight is 3g, 4000KV, with 1.5mm shaft)
3) Mu-3A ESC: 4 pcs;
4) 2 sets of propeller (8 props)
5) One piece of MX-VTX-B with clover antenna;
6) One set of MINI DV(720P/30F,120-angle lens)
7) One piece of MX OVERSKY 32 flight control board (integrated with DSM2 7CH receiver, supports firmware of BaseFlight and CleanFlight)
8) 1 piece of 450mAh25C7.4V battery;
Note:
1) The integrated DSM2 compatible 7CH receiver outputs data through serial port;
2) It supports outside receivers such as PPM, DSM2/DSMX, SUMD or SBUS (revert circuit needs to be added)
3) You can also choose Mu-3Aa-L1 which was installed on the motor carbon arm(only for 150mm and 155mm motor to motor distance);
4) MX NANO CC3D flight control is an option;
5) The max flying weight should not be more than 120g
6) 99% of the quadcopter was designed for plug and play, no need more solder, but for power cable, customer need to solder it themselves.
7) We can provide both RHCP and LHCP clover antenna, please let us know which one your prefer when you make the order.
Please feel free to contact us if you are interested in our product.
Thank you!
Overskyrc Team
YXmotor is offline Find More Posts by YXmotor
Old Jan 07, 2015, 05:11 AM
United Arab Emirates, Dubai
Joined Jul 2012
I using futaba tx so can we put a futaba rx on it? is the vtx compatiable with fatshark glasses? what will be the price? any videos? website?
ahtiram is offline Find More Posts by ahtiram
Old Jan 07, 2015, 09:36 AM
RPC
Joined Oct 2008
Hi,
It supports FUTABA receiver SBUS, I'm sorry I don't know the frequency of fatshark, please check this link:http://www.overskyrc.com/mxvtxb-vide...-6g-p-549.html and compare the frequency with that of fatshark and see if it fits.
Thank you!
Old Jan 07, 2015, 09:40 AM
RPC
Joined Oct 2008
No video at the moment, we will ask MassiveRC to test our product and they may record a video, you can purchase it from this site:http://www.overskyrc.com/hermit-micr...98g-p-599.html its price may increase to USD295 after 1 week.
Thank you!
Old Jan 07, 2015, 02:55 PM
United States, AK, Anchorage
Joined Sep 2014
couple questons,
1.I am using a frsky taranis... does this work with that receiver? or do I need to by the dsm2 module?
2. reading the post it looks like it has a digital video recorder on board as well as a video transmitter?
3. how is the video feed? is there much interference from the motors running it on the same battery? is there any sort of filter on board?
4 it comes with 450 mah battery. what is the flight time with that and can we upgrade?
5 what connector is on the battery? can I charge it with my regular lipo charger? does it have a balance plug?
AkDalton is online now Find More Posts by AkDalton
Old Jan 09, 2015, 03:56 AM
RPC
Joined Oct 2008
Hi Sir,
1, Yes, it can work with frsky taranis, no need to buy DSM2 module;
2, It does have a digital video recorder on board, please check 5.8G VTX from this link: http://www.overskyrc.com/mxvtxb-vide...-6g-p-549.html
3, Almost all the analog VIDEO receiver can get the signal from FPV quad copter, you can check the description on our site for VTX-B.
4, The flight time is about 9 minutes with our 450mAh7.4V25C battery when VTX and DV is on. You can use a battery with higher capacity such as 600mAh 25C, but the total flight weight should not be more than 120g; Besides, you need to adjust PID parameter when the flying weight is increased.
Thank you!
Jon
Old Jan 09, 2015, 10:56 AM
Ten4's Avatar
Joined May 2013
Really tempted to buy this. I usually wait a while after people have given feedback but waaahh, I've always wanted something tiny to fly around campus. I have money but need to save it for living as a student XD
One question: Will you be selling a version without the camera and VTx?
Ten4 is offline Find More Posts by Ten4
Old Jan 10, 2015, 11:07 PM
Joined Sep 2011
I am also interested in a version without the video TX, the model that is included does not have any overlapping channels with the fatshark frequencies unfortunately. I almost purchased it until I noticed that issue.
Do you have any video of this quad in the air that has been posted?
VultureCP is online now Find More Posts by VultureCP
Old Jan 11, 2015, 11:10 PM
CunningStuntsFPV
figgoat's Avatar
Australia, WA, Dirk Hartog Island
Joined Dec 2012
This thread belongs over in mini multirotor thread. If it doesnt have wings, it should be elsewhere.
figgoat is offline Find More Posts by figgoat
Old Jan 13, 2015, 12:09 AM
3DFun's Avatar
Joined Mar 2007
How big is this quad compared with a nano qx?
3DFun is offline Find More Posts by 3DFun
Old Jan 13, 2015, 02:42 AM
RPC
Joined Oct 2008
Yes, we are considering, thanks for your suggestion!
Thank you!
Jon
Old Jan 13, 2015, 10:13 AM
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
This is FPV aircraft forum and not fixed wing so it belongs here just fine.
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Jan 13, 2015, 10:23 AM
Joined Jul 2014
Originally Posted by YXmotor View Post
Hi Sir,
But will I have to buy a FrSky receiver to make it work with the Taranis?
dingrrcg is offline Find More Posts by dingrrcg
Old Jan 13, 2015, 10:32 AM
Joined Jul 2014
What props are included? Are they the CR23 model?
http://www.overskyrc.com/75mm-propel...ops-p-536.html
Old Jan 13, 2015, 06:10 PM
Joined Sep 2011
The website states a DSM2 7CH RX is included in the FCU which I assume is this: http://www.overskyrc.com/mx-nano-ove...ard-p-601.html
Which would require that you have a DSM2 compatible transmitter module on your controller such as the Orange DSM2 or the Spektrum DSM2
Discussion Eachine DP4X-124 124mm Micro Brushless Quadcopter subpixel Mini Multirotors 55 Jan 16, 2015 05:08 PM
For Sale 150 sized micro brushless quadcopter for fpv icah Aircraft - Electric - Multirotor (FS/W) 2 Dec 29, 2014 02:55 AM
For Sale Fpv Quadcopter / Dead Cat Frame / Dji F450 / Brushless Gimbal / Fpv Cameras 5.8 Tx / ryanroberts1983 Aircraft - Electric - Multirotor (FS/W) 5 May 30, 2014 01:06 AM
Discussion My [Brushless] .98g plane Angry_Monk Scratchbuilt Indoor and Micro Models 33 Mar 18, 2008 02:37 PM
