Old Jul 18, 2013, 03:54 PM
"Flying is my life!"
FlyVA's Avatar
United States, VA, Salem
Joined Oct 2002
Above and below DLG tails for F3X?
Usually the bottom of a vertical stabilizer starts in the fuselage and extends upward. Mostly seen on DLGs, vertical stabilizers are equally 50% above and 50% below the fuselage so as to minimize the boom twist leverage generated when discus launched
Are there any aerodynamic disadvantages to an “above and below” vertical stabilizer on a larger design?
FlyVA is offline Find More Posts by FlyVA
Old Jul 18, 2013, 04:38 PM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
I don't know to be honest, but I suspect there is a problem in that you might not get far in to the comp with a under over tail in some f3x classes. E.g f3f and f3b with ballast.
satinet is online now Find More Posts by satinet
Old Jul 18, 2013, 04:55 PM
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
In DLG's it's important to balance the torsion loads on the tail boom for structural reasons.
In F3X the loads are lower considerably so it isn’t needed.
Also, F3X models may get the rudder damaged if it’s lower than the fuselage on landings and it can be a little dangerous when launching.
roydor is online now Find More Posts by roydor
Old Jul 18, 2013, 04:57 PM
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I also believe it violates some of the model rules for arrestment on F3B and F3J models. i.e. no skegs
djklein21 is offline Find More Posts by djklein21
Old Jul 18, 2013, 05:05 PM
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Ava is legal for F3J.
Tuomo is offline Find More Posts by Tuomo
Old Jul 18, 2013, 07:10 PM
FlyVA's Avatar
Joined Oct 2002
All good points fellows but back to the original question.
Old Jul 23, 2013, 10:53 AM
Marc PUJOL
Joined Feb 2010
Yes ther is alttle advantage for a below fin. But it is a it marginal.
The main advantage is that it allows to stop the plane (it's an allowed skeg)
The main drawback is the resistance in torsion during landing. But with a good boom, you can manage.
I have experienced for 2 years with my Genoma series (4M F5J planes) without any issues
Marc
marc.pujol is online now Find More Posts by marc.pujol
Old Jul 23, 2013, 04:33 PM
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
The german Bizarre team (with Reinhard Vallant) had an F3J model called Free Willy for the win (FW FTW), which had a symetric vertical.
http://bizarreteam.forumieren.de/t4-...rste-einblicke
I however only saw them flying with the Free Willy (which had the normal tail).
I did not understand the rationale for the symmetrical tail on a J plane.
Best,
Reto
RetoF3X is online now Find More Posts by RetoF3X
Old Jul 24, 2013, 02:51 AM
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
The justification for DLG's is to add yaw damping (with a larger tail) without creating a bunch of torque on the tail boom. You would have to make heavier booms to take the twisting of a top only vertical stab.
The tail booms on F3J models have much larger diameters and thus larger torsional stiffness. So building a large enough vertical stab doesn't impact the overall weight budget of the model like a DLG.
You might make an argument about proverse roll moments with the application or rudder, but that is a REALLY small effect with a properly sized tail.
Avaldes is offline Find More Posts by Avaldes
Old Jul 24, 2013, 07:20 AM
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Some time ago there was a launch video over here. Pike Perfect launching and tail twisting torsionally in a quite alarming way. I would not mind having a torsionally stiffer tail booms in my F3J planes.
DLG:s have proportinally much larger vertical stabs. The design trend in F3J is towards the very same direction - with tailbooms getting longer and structural weight lower. Only time will tell what the dominant tail configuration is after 5 or 10 years. Waiting for the 2022 WC...
Old Aug 01, 2013, 05:23 PM
FlyVA's Avatar
Joined Oct 2002
OK...this thread has run its course so I'd like to share what my beliefs were when the question was first asked. The symmetrical (or close to it) should:
(1) not hurt performance
(2) reduced torque load (twist) on boom
(3) provide "center" rudder drive point
(4) raise the horizontal stab higher away from ground damage
(5) legally lower the model skidding distance on the ground
(6) be a hell of a lot better looking than a big butt cruciform tail...IMHO of course.
Mission accomplished. Thanks to those who posted.
Discussion Above and below tails FlyVA Cross Country Soaring 1 Jul 15, 2013 07:41 PM
For Sale DLG Arrow Pro.... see below flxzcat Aircraft - Sailplanes (FS/W) 1 Apr 26, 2013 06:20 PM
Discussion No hell below us, above us only sky. Michael in Toronto Life, The Universe, and Politics 10 Dec 08, 2006 10:24 AM
Discussion Gearbox/outrunner: above or below fuse? geekdom Beginner Training Area (Aircraft-Electric) 2 Jan 18, 2006 12:06 PM
Coast Guard c-130 pictures from above and below needed. Michael Heer GWS (Grand Wing Servo) 2 Nov 07, 2004 07:21 PM
