Old Mar 08, 2013, 12:15 AM
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Hi MiYeti,
I am not sure if it wil be too slow or not. I know when I triedthe gears in a servo I had, the reduction had the prop barely making any thrust.
You can experiment with it just in the hull and temporarly mounted to see the results. I have a buoy tender and lindberg tug, both are direct drive. Give it a shot, this hobby is all about trying different stuff.
(the first setup I had in my buoy tender were aircraft motors and an RC Car ESC, It was going so fast the model was almost a planing hull!!)
Cheers
G-O
Guard-Officer is offline Find More Posts by Guard-Officer
Old Mar 08, 2013, 12:24 AM
I'm a crash test dummy ;)
MiiYeti's Avatar
United States, IL, Tinley Park
Joined Feb 2013
Ok thanks! I will tape the servo in and see how well it works in the test tank (most commonly known as a bathtub) and will post a link to the video of it running.
MiiYeti is offline Find More Posts by MiiYeti
Old Mar 11, 2013, 12:07 AM
MiiYeti's Avatar
Joined Feb 2013
Originally Posted by MiiYeti View Post
i was planning on using the original gears on the servo. will it still spin fast enough?
I found out yesterday it does not have enough RPM to move the boat so I removed the gears and am going direct drive from the servo motor. I will post some pictures tomorrow when I finish gluing in the motor and drive line.
Old Mar 12, 2013, 01:17 AM
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Way cool, young Sir, way cool! Welcome to the communal side of the hobby! You are doing great work.
craig_c is offline Find More Posts by craig_c
Old Mar 12, 2013, 05:47 AM
Blackpool, Lancs
Joined Feb 2006
On mine, I found that the prop blades on the kit prop were too thick and blunt, sanding them to a better profile helped a lot.
If painting the LEDs, paint them white first, then black. The white is better for internal reflection, LEDs are usually intended to shine through the dome, so need all the help they can get when you want the light to appear somewhere else.
mfr02 is offline Find More Posts by mfr02
Old Mar 16, 2013, 11:09 AM
Sometimes I am the weapon
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
Others have finished it, so why not you? I suspect this destroyer is none other than the Blue Devil.
Ive never built any other kits. I started on a lindburg destroyer and was not happy with the way it was going so I started this kit to see if it any better. I will go back to the destroyer over the summer (It will not win I am determined to finish it)
I hacked a 44OZ futaba S3003.
Harquebus is offline Find More Posts by Harquebus
Old Mar 16, 2013, 05:25 PM
MiiYeti's Avatar
Joined Feb 2013
yes it was quite the hand full when i was trying to improve some of the parts such as the gaps on the back of the 5" guns and the gaps on the depth charges. but i will finish it! it cant beat me!
Old Mar 16, 2013, 06:05 PM
Harquebus's Avatar
Joined Jan 2006
Many people have been inspired to improve the Lindberg BD. If you need resources, don't hesitate to ask. Any progress on the tug?
Old Aug 24, 2013, 02:57 AM
Harquebus's Avatar
Joined Jan 2006
Originally Posted by Guard-Officer View Post
MiiYeti,
I have hacked a couple of 1/4 scale servoès for a very small buoy tender, and with a 0.6'' 4 blade prop on each on 6V i get a very realistic power. You shouldnt need to put a gear reduction on this with only one motor and at 4.8V
G-O: Can you provide more detail on these 1/4 scale servos? What brand were they and did the output shaft on the motor have enough length (some or most are very short which makes adding a proper coupler difficult)? ?
Old Aug 24, 2013, 11:10 PM
Joined Feb 2009
Hi Harquebus,
I would have to find the box or receippt to remember exactly the brand, but they were a cheaper brand name, I didnt want to spend lots just to chop it up. the drive shaft is very short, you just gotta glue a piece of silicon tupe to it for a coupling, works very well onto a 1mm shaft
cheers
G-O
Old Sep 23, 2013, 09:33 PM
Harquebus's Avatar
Joined Jan 2006
I guess I was wondering what size motor was used in a 1/4 scale servo as they are larger than a standard sized servo.
mfr02: You were saying you had to sand the prop blades on the kit to get a better profile. I certainly want to utilize the kit prop just as others have done and partly because it is quite sturdy for a piece of plastic. Can you describe what you did to the prop? Would sanding the leading edge of the blade be enough (to help it have more bite)?
Old Sep 26, 2013, 07:16 AM
Blackpool, Lancs
Joined Feb 2006
Here is what it looks like a depressing number of years along the line. Since I only figured out that it needed attention after trials, and consideration had not been paid to servicing, all the filing/sanding was done in situ. It did make a worthwhile difference.
The colouring was Humbrol brass with a few drops of pale green added. Back then, a lot of people thought it was a brass prop with a patina - after 15 years of use in salt and silt, its showing genuine weathering.
Old Sep 26, 2013, 12:23 PM
Joined Feb 2009
Oh sorry Harquebus,
I am not sure the size, it might be around a 200 size. nice low rpm ones though for direct drive on 6v.
Cheers
G-O
Old Sep 28, 2013, 04:08 PM
Harquebus's Avatar
Joined Jan 2006
G-O: Great, thanks for the info.
Mfr02: Prop looks noticeably thinned all along the blade surface and the imitation "patina" looks great. That's a detail often overlooked. Did you drill the prop all the way through to the hub?
And to the OP and other lurkers; finally have my hands on the other Lindberg tug, the Coast Guard Tug "weighing in" at 3.5" wide and a little over 11.75" long. This is an altogether upgrade on the Diesel Tug despite the smaller size. Better profile on the area around the prop for increased water flow as others have noted and the parts for everything else are less bulky, thinner and more delicate so there's less massive topside weight which the Diesel Tug exhibits. This is a steam tug complete with whistle on the funnel and ostensibly of wooden construction with all the planking detail (which could be sanded off to make a steel hulled, more modern tug). Good kit and they are readily available again.
Any progress, MiiYeti?
Old Sep 29, 2013, 04:52 AM
Blackpool, Lancs
Joined Feb 2006
Yes, the prop was drilled through. That was the only way I could think of to get the hole accurate - make sure the front face was flat, mount it on the bed of the vertical drill, get the bit centered, and go for it very slowly.
Build Log Building a 1/72 canadian "Glen-class" tug from the 1/82 Lindberg Diesel Tug Lichtbote Scale Boats 84 Jun 18, 2014 07:55 AM
Help! Lindberg 1/82 scale model Diesel Tug sivadmatt Dock Talk 32 Mar 17, 2014 07:39 PM
Build Log Salvaging a Lindberg Diesel Tug RGinCanada Scale Boats 231 Feb 18, 2014 11:06 AM
Build Log Lindburg Diesel Tug (12") MiiYeti Scale Boats 5 Feb 26, 2013 02:51 PM
Discussion Jersey City Tug.. Steam or Diesel? everglades Dock Talk 1 Mar 05, 2008 11:32 AM
