Old Feb 25, 2013, 07:04 PM
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Fixed Trike Landing Gear Location
Howdy:
Best location or rule of thumb for trike gear?
I have never done (successful) landing gear on a scratch build, trike or otherwise. I was wondering where is the best location, fore & aft. Perhaps nose gear far forward out to where I think the nose/fuse could handle the shock of a bad landing? The mains perhaps 1/2 the distance behind the CG that the nose gear is in front of the CG?
Salient Factors
0. Delta wing with fuse, pusher prop.
1. I will not have steerable nose gear. Too complex this go 'round.
2. Delta wing, flat bottom config, so lots of room on bottom to play with.
roo_ster is offline Find More Posts by roo_ster
Old Feb 25, 2013, 09:24 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Main gear on a delta should have the main gear just behind the CG. Just enough to tilt the nose down if you were to push the tail to the ground. Should sit on the ground with the nose slightly high in order to rotate at takeoff. Built a few of them.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Sold NIB Airfield (FMS) 1400mm Spitfire Kit, Fixed Landing Gear, $90 or BO, LPU Irvine CA ek123 Aircraft - Electric - Airplanes (FS/W) 2 Jan 21, 2013 11:19 AM
Question Any "lawful" location for a rare fixed landing gear? blacksmith2 Pusher Prop Jet Models 5 Aug 01, 2010 11:23 PM
Sold T-28 Landing Gear with Robart Trike Gear Strut Covers & Dubro Super Lite Wheels Sammy70 Aircraft - General - Miscellaneous (FS/W) 3 Jul 11, 2010 08:55 PM
Best landing gear type for Easy Star -- trike or tail dragger? JohnSoPA Foamies (Kits) 11 Aug 07, 2008 11:15 PM
Help turning E-starter to trike landing gear sokmeister Parkflyers 2 Dec 19, 2003 05:23 PM
