Old Jun 25, 2012, 09:26 PM
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
how are snaprolls done?
One of my favorite moves in 3D flying is snaprolls. Or should i say snoprolls haha!
What imputs are needed to perform a snoproll
Is there a preset i can do with my transmitter 9x? I was tinkering around and made 1 elever go up or down at the flip of a switch. And what's the name of the part where the plane is falling inverted? I also think that move is phenominal. What's a really nice manouver?
out of stock is offline Find More Posts by out of stock
Old Jun 25, 2012, 09:33 PM
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
A snap roll is a stall and an autorotation
For a posative snap you would give up elevator followed by rudder and aileron (both left or both right. release the rudder and then center aileron and elevator(split second difference)
If you have 3D rates then you will need less than full elevator, practice so that you are on the same heading at the end as when you start and the wings are level at start and finish.
When you have that down learn multiple snaps and snaps to knife edge.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Jun 25, 2012, 09:56 PM
Randal McSandal's Avatar
Joined Dec 2011
Don't forget forward stick after the high-speed stall to really whip it around.
Randal McSandal is offline Find More Posts by Randal McSandal
Old Jun 25, 2012, 10:01 PM
Dennis C's Avatar
Joined Jun 2004
good manouver but not a true snap
Dennis
Old Jun 26, 2012, 12:19 AM
DONT PANIC! :)
Joined Jan 2012
Wow sounds intense. I like that. Snap to knife. For these manouvers, are expensive servos required? I'm thinking i need to upgrade. I'm using futs s3010's. Can it be done with these?
Old Jun 26, 2012, 12:22 AM
DONT PANIC! :)
Joined Jan 2012
Dennis what would be considered true snaproll? I'm inquisitive.
Old Jun 26, 2012, 12:36 AM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Daniel Héligoin's Snap Roll on Takeoff (0 min 22 sec)
hone1er is online now Find More Posts by hone1er
Old Jun 26, 2012, 07:52 AM
I like the violent stuff!
Costa Mesa, CA
Double snaproll takeoff to knifedge is for my foamies, knocked the corner of the aileron off once. Dennis got the inputs right, from there it's timing. And yes a deep 3D snap is not a true snap, precision snaps are way different.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Jun 26, 2012, 09:09 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Dennis
Dennis
According to Scott Stoops your definition is not a true snap roll either. A snap roll is a rudder/elevator maneuver with a very high angle of attack. By using ailerons you are adding pro-snap, necessary for some aircraft to snap. Also pro-snap is a little easier to control and recover from. Also, if being judged there has to be some noticeable stall, hence the nose up at the beginning of the maneuver.
Eagle34 is offline Find More Posts by Eagle34
Old Jun 26, 2012, 09:56 AM
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
Jesky is a good one to watch if you want to see how it's done. once you have the basic snap down and can do it nice and clean there are all sorts of variations and combinations to be had with rolling maneuvers.
Irg is online now Find More Posts by Irg
Old Jun 26, 2012, 10:02 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Yep, Mr. Smooth right there. I wanna be like AJ.
Old Jun 26, 2012, 10:07 AM
Irg
Irg's Avatar
Joined Apr 2009
yeah. me too.
I was having a hard time getting my snaps clean, and Ben from 3DHS gave me a little tutorial at the NJ throwdown a few years back. it is hard to pull them off cleanly if your rates are too low or too high.
Old Jun 26, 2012, 10:11 AM
United States, CO, Denver
Joined May 2010
so when you see people do that high alpha roll to a hover, that is actually just a snap roll, yes? Hence, why it's called Snap to Hover?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Jun 26, 2012, 11:13 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Yes and no. A true snap would put you back on your original flight path. Yes it is a variation of the snap, but you are over rotating to get to the hover position, so maybe a snap and a quarter. I like to do the snap to hover on take-off with my smaller planes. Gives a wow factor to taking off. >>> Take-off, snap to hover, torque roll, roll out in KE, KE circle around the field <<< Then I'm about out of moves, LOL, all in under a minute.
Old Jun 26, 2012, 11:16 AM
DONT PANIC! :)
Joined Jan 2012
So the faster the servos the better the snap?
Discussion How common are DJI ESC problems? Bill Glover Multirotor Talk 12 Jan 25, 2014 10:03 AM
Discussion How are the pins for wings made? GreenAce92_v2 Sailplane Talk 20 Jul 05, 2012 05:21 PM
Discussion how to tell if my batteries are done for. CaptainRC Electric Power Cars 10 Jul 19, 2007 09:46 PM
How are these great paint schemes done on foam ?!?!?! Johnhardy1 Foamies (Kits) 5 Sep 01, 2005 11:49 PM
