Old Nov 11, 2013, 08:58 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Very nice project Rolf!
I am goiing to user these ESCs for my Rover Project:
http://der-frickler.net/modellbau/cars/rover_4x4
By the way, is there any kind of break implemented in your code?
some specials ESCs for Crawlers have some kind of Hand-Break which causes the motors to block when the stick is in center. That would be a really nice feature.
Does anyone has an idea how that is implemented?
By the way, small and cheap Brushless ESCs are great soure for controlling the Lights on your Plane or whatever ;_)
http://der-frickler.net/modellbau/avr/esclight
(Jo)Hannes is offline Find More Posts by (Jo)Hannes
Old Nov 23, 2013, 09:44 AM
Joined Oct 2012
Someone write program control mt brushed from for esc brushless Silab ? atmel is old
fantasy1988 is offline Find More Posts by fantasy1988
Old Dec 02, 2013, 01:51 AM
Joined Nov 2012
Silab is hard
rc my life is offline Find More Posts by rc my life
Old Dec 02, 2013, 02:20 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
As far as i know these Guys have some Silab ESCs running:
https://launchpad.net/brushed
Old Dec 02, 2013, 03:28 AM
Joined Oct 2012
you can compile file hex for esc use chip Silab. As fas as know that is esc HK 10a.
i do not know complie for Silab
Old Jan 04, 2014, 01:39 AM
New Zealand, Northland, Whangarei
Joined Aug 2013
So, someone please correct me if I am wrong.
I have a spare one of these. HK F-30A
I got 5 for my quad in case I bricked one while flashing to simonk.
I can use this firmware using the same method I used to flash the others to simonk.
I will end up with an ESC that will control a brushed motor and has reverse?
If so, which wires do I use to connect to the motor, trial and error?
Also, could I use this from a 4s battery to run LED strips rated at 12v by changing limits in my tx?
I know its overkill but it's lighter than a 2 or 3s battery and a reciever controlled switch and I have one so I don't have to buy anything.
Stambo is offline Find More Posts by Stambo
Old Jan 04, 2014, 07:29 AM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
I don't really know about the firmware but I doubt the "Switched" output would be "dim-able".
I would measure the current draw of the lightest at 12v or consult the datasheets for it. Argument sake the array takes 600mAh at 12v and try the array calculator with your specs but treat the array as a single LED with no resistors...
http://led.linear1.org/1led.wiz
Description:
Link to solution http://led.linear1.org/1led.wiz?VS=14.8;VF=12;ID=600
Ok you can't get a 1.7watt resistor so something like two 1W 10 ohm in paralllel if you can't get a 2w or maybe a 12v regulator.
djdavies83 is offline Find More Posts by djdavies83
Old Sep 24, 2014, 12:58 PM
San Marcos, CA
Joined Aug 2009
Will this work with the new SiLabs Turnigy Plush?
flyandi is offline Find More Posts by flyandi
Old Oct 17, 2014, 05:46 PM
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
No, the code is for Atmega only.
Zen09 is offline Find More Posts by Zen09
Old Oct 19, 2014, 11:55 PM
Joined Jun 2013
it can use chip silab . but have not at this thread .
looking for here https://launchpad.net/brushed
John michel is offline Find More Posts by John michel
Old Oct 20, 2014, 02:05 AM
San Marcos, CA
Joined Aug 2009
went with Atmel chips - thanks!
Old Oct 20, 2014, 02:10 AM
Joined Jun 2013
no, it was supported silab and atmel
http://bazaar.launchpad.net/~brushed...ed/trunk/files
Old Nov 27, 2014, 12:37 PM
Solihull, England
Joined Jun 2004
I would like to try this on an AfroESC. I know what mods I need to make but what do I use to make the source code changes and then compile it. I have tried Studio 6.2 but it throws lots of errors so I must have something very wrong.
Can anyone tell me the difference between http://bazaar.launchpad.net/~brushed...ed/trunk/files
and KapteinUK software in this thread?
Peter
Peter Seddon is offline Find More Posts by Peter Seddon
Old Dec 03, 2014, 05:21 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
What errors are you getting?
They are quite different. Rolf's code is written in assembler, and uses macros to handle the ESC specific stuff.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Discussion Brushless ESC with a brushed motor soprano1 Power Systems 7 May 05, 2012 02:10 PM
Discussion ESC - brushed/brushless emeraldPark Electric Motor Design and Construction 1 Mar 14, 2012 10:13 PM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 10:48 PM
need reversable speed control with no delay aaronredbaron Power Systems 0 Jul 31, 2003 05:40 PM
