Old Apr 13, 2014, 12:12 PM
USA
Joined Jan 2002
Switch to Powerpoles and avoid this problem altogether.
Ohmic is offline Find More Posts by Ohmic
Old Apr 14, 2014, 07:39 AM
USA
Joined Jan 2002
Here's a picture of my Dual PowerLab 8 input connector.
Old Jul 06, 2014, 10:44 AM
United States, FL, Oldsmar
Joined Dec 2013
Is there any way to discharge batteries for disposal with the PL6?
barrs is online now Find More Posts by barrs
Old Jul 06, 2014, 01:45 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
No. The PL6 will not discharge below 2.50V / cell. For disposal you need to discharge to zero volts.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jul 06, 2014, 03:06 PM
Seattle
Joined Sep 2007
If you use one of the NiXX presets, you can discharge down to about 2v for the pack, perhaps lower. But I prefer to just use a couple automotive bulbs in a fire safe location. Packs I'm discharging are usually no longer trusted and I don't feel comfortable having them connected to the charger.
Gregor99 is online now Find More Posts by Gregor99
Old Jul 08, 2014, 12:50 AM
Joined Dec 2012
I have a chargery 24-1200 psu .what should I set supply voltage to ,the manual states that each port is 30 amp ,there are three ports .the psu is rated for 50 amps.should I paralel 2 of the ports and set charger limit to 50 amp or is it ok on 1 port set to 50 amps?
Stevewr is offline Find More Posts by Stevewr
Old Jul 08, 2014, 06:40 AM
USA, GA, Marietta
Joined Aug 2005
Please provide a link to your power supply.
Also what batteries are you charging?
If as you said each power supply port is rated for 30 amps then, yes, you should be able to parallel two of them. Set the current limit on the PL6 to 40 amps.
Supply voltage?? Where?? Power supply or the charger??
Glen
Old Jul 09, 2014, 12:00 AM
Joined Dec 2012
Not sure how to provide link ,http://www.chargery.com/ on the web site psu is a chargery s1200 ,24v-50amp-1200 watt .I should be getting pl6 this week from buddy rc ,so not familier with charger yet .I will be charging glacier 3300 6s-30c batterys & also 2200 3s -65c battery.my old charger was a thunder power 610c.it was taking 40-50 minuets to charge at field .I have read that the default setting is 25 amp on pl6.the power supply is adjustable from 12-24 volts.so I was not sure where to start ,just want to set up properly with out hurting power supply.would like to charge at 2c or higher .old charger would only charge at 3 amps max.the reason I bought pl6 was that it was highly recomended on rc groups and I would rather have a charger that I can grow into rather than having to buy something better later.hope this helps ,thanks for every ones responce.
Old Jul 09, 2014, 12:11 AM
Seattle
Joined Sep 2007
Set the supply for 23.5v to avoid buck boost transitions. Set the charger's input current limit to 40 amps. Leave the charger's low supply limit at the default as this is not needed. The supply has over current and over load protection.
Use preset #3 High Power. The charger how many packs you have in parallel, then tell the charger the charge rate for each pack in amps. Don't use the 1c, 2c, 3c auto mode settings.
Enjoy!
Old Jul 09, 2014, 02:15 AM
Joined Dec 2012
Thanks for the quick reply looking forward to this charger,enjoy reading all the posts learning a lot ,thanks again
Old Aug 14, 2014, 05:27 AM
United Arab Emirates, Dubai
Joined Jul 2012
I would like to know what should be my supply current limit and low supply limit? I am using 24V47A Plug-n-Play Supply from feathermerchantrc.com?
Also is there anything else I need to do before charging? I don't want to blow something up...
ahtiram is offline Find More Posts by ahtiram
Old Aug 14, 2014, 06:59 AM
USA
Joined Jan 2002
http://www.rcgroups.com/forums/showp...&postcount=563
New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) Tim Marks FMA Direct 5969 Jan 11, 2015 05:59 PM
New Product Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 408 Nov 15, 2014 08:52 PM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 10:43 AM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 04:24 PM
Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) helinut4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 27, 2009 05:24 PM
