Old Nov 04, 2009, 06:18 PM
hotflyer80's Avatar
Joined Oct 2008
need help jumping Losi Mini lst-2
I have a little losi mini lst-2 and I run it out in my backyard track. When ever I go over a jump, even a very small one, it flips foward so bad that every time it flips over on the ground. It is really annoying and I am afraid I am going to break the truck. How can I fix this problem?
hotflyer80 is offline Find More Posts by hotflyer80
Old Nov 05, 2009, 03:42 AM
USA, MN, Minneapolis
Joined Jul 2008
locked center diff
E-maxxman is offline Find More Posts by E-maxxman
Old Nov 05, 2009, 08:25 AM
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
i agree for some reason these little trucks tend to send most of the power to the front .
i own 2 of them and both jump horridly . and i have threaded shocks on one and integy piggyback on the other . another thing . instead of locking the center diff . best to get the up grade ball dif as they are for one better in durability but you can tune it tighten it for more rear traction or losten for less . great up grade there . i feel it you lock the center you will just strip it the first on power landing you have .
rcphreak is offline Find More Posts by rcphreak
Old Nov 05, 2009, 09:09 AM
hotflyer80's Avatar
Joined Oct 2008
I rebuilt the front diff. and put a little all purpose grease in there, I think its a little thicker grease than in the back diff, would that affect it?
Old Nov 05, 2009, 09:24 AM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
no as the diff in each front or rear only controls wheel power distribution to that set of wheels. the center diff is what controls distribution to front vs rear . although with thicker in the front you may notice it push alot more in the corners as the diff takes more bind to work properly. rember the diff makes all the difference in cornering . that is why if you lock them up it will adversely affect cornering ability . and make the truck bind while trying to turn . while the center if locked will just deliver the same power to both front and rear at the same time instead of to one more than the other .
i would keep the front and rear diffs loose as not to bind them and get the ball diff for the center so you may tune it to act as you wish . im sure if you lock the center it being plastic the result will be it will break . from stress
Old Nov 05, 2009, 09:29 AM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
the center trans unit on this truck is basicly a mini t tranmission turned side ways in order to make 4 wd that is why the center diff is the same for the lst , mini t , mini slider , ect.
Old Nov 05, 2009, 10:07 AM
hotflyer80's Avatar
Joined Oct 2008
Thanks, I was just using it and its getting better. This truck has a really tight turing radious compared to my pede which I like. Just one question, hows the durbility on yours? Mine breaks all the time even when I am not abusing it.
Old Nov 05, 2009, 11:54 AM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
my main problem with these trucks is the small white gears in the diff units . they are crap as why make a metal diff and then use plastic gears inside . i am verry sorry i ever went brushless with these trucks . as they can not handle the power .
if i had the chance to go bach is have kepe the stock brushed motors in it and just use the 2 cell lipos as there a nice jump in power but its not too much to keep breaking the diff units . other than that the servos seem to be quite weak . i have one that has stripped the gears in it . im not paying losi 20 + dollers for that servo . for the same result . how ever you can buy gears for like 4 bucks . thats worth it and its not to hard to do .
Old Nov 05, 2009, 05:14 PM
hotflyer80's Avatar
Joined Oct 2008
Yah I stipped the diff gear twice, but I called losi and they sent me a new metal grear the second time. I also stipped the servo gears twice, I called losi again and they sent me three new servos. I was thinking about upgrading to brushless but now that you say that I think I will only go for the lipo. I also have a question, is my ESC LiPo compatible? The truck is about a year old.
Old Nov 05, 2009, 11:26 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
yes all of my losi esc's have been 2 cell lipo compatable . they have a built in cut off .
if its a lst 2 it is a sure thing it came with the 2.4 gh radio right ??
i have hooked 3 cells to it also but after a couple hard min it go into thermal cut off .
but boy its fast but agin you risk killing gears that way trust me the lipo is good enfugh .
its not going to run 50 but it will be fairly reliable .
Old Nov 06, 2009, 06:24 PM
hotflyer80's Avatar
Joined Oct 2008
The shocks broke so I am going to go and buy some aluminum ones and i will most likely get a new LiPo too. I am also debating weather to get aluminum shock towers, aluminum steering blocks and castor blocks or aluminum hubs.
Old Nov 07, 2009, 12:07 AM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
sweet remember aluminum bends if your jumping then most likly you will be crashing .
might be best to invest that cash into extra stock parts . but i love the bling factor too !!!
Old Nov 07, 2009, 10:27 AM
hotflyer80's Avatar
Joined Oct 2008
I really wish that RPM made parts for the mini lst2. But I think I will just get the shocks and a LiPo battery. I will wait for other parts to break before I upgrade them.
Old Jan 30, 2010, 12:09 PM
RC Toys R 4 White Trash
Dan5.0's Avatar
Joined Dec 2008
Is there a LST 2 thread anywhere?
Dan5.0 is offline Find More Posts by Dan5.0
Off Site Losi Mini LST FULLY Hopped Up & Race Ready. mugler Cars - Cars and Parts (FS/W) 0 Sep 20, 2009 02:59 AM
Sold FS NICE LOSI LST 2 1/8 Monster rdr4evr69 Cars - Trucks and Parts (FS/W) 4 Sep 18, 2009 06:59 PM
Sold WTT Losi LST 2 1/8 Monster for T-rex 450 rdr4evr69 Aircraft - Electric - Helis (FS/W) 0 Sep 18, 2009 09:42 AM
For Sale Team Losi Mini LST 1/18 scale w/ Extras 2.4ghz Funzy Cars - Cars and Parts (FS/W) 6 Dec 01, 2008 09:23 PM
Sold Losi Insane motor upgrade for Mini LST/2 with ESC RevToTheRedlin Cars - Cars and Parts (FS/W) 1 Mar 01, 2008 10:02 PM
