Midwest Products USCG 47' MLB ARF Build
I have had this boat, purchased new about 3 years or so ago, sitting on my reloading table gathering dust. It's time I got it running.
First thing was to move it from the spare bedroom to the workshop, but stop outside for a minute to blow the dust off. Then use some rubbing alcohol to remove the 'factory fingerprints' and smeared adhesives. Second step was to open all the hatches, and locate the fitings that had broken off. The tripod mounted bollard was already broken off when the boat arrived in the box and I epoxied that back in place years ago. Today I had to re-glue the overhead spotlight and one of the chairs armrests. I then installed the servo. Next I removed the rudders and linkage. Bone dry on the rudder shafts, no lube. Typical soft crappy hardware and the screws were already peeling their threads as soon as I loosened them. I replaced them with 18-8 stainless steel socket head screws. The rudder tiller brass bushing was not drilled and tapped at 90*, it is more like 100*. I am not sure if this will cause an offset steering problem so I may go ahead and make a new bushing. I noticed the large red decal on the port side had a tear in it. I was going to place a piece of clear tape over it but as soon as I touched it more of it broke off. I then used the tape to 'suck' the decal right off. Will get some others made by Callie Graphics if possible. Overall this boat is light years ahead in quality compared to their PT-109. They really dropped the ball on that one. This one looks so nice already and it will be fun to work on it and get it rigged for running.
Did a little more poking around on the boat today. I removed the motors and prop shafts today. The shafts did have a trace amount of vaseline on them. More as an anti-rust protectant than a lube. I give credit to the factory Midwest Products Co used for the prop shafts. They are absolutely true. I rolled them on my milling table and they are straight as can be. Not so the plastic props. They are going in the junk box along with many others. I ordered some 4-blade Raboesch props from Loyalhanna Dockyard. The motors, once out of the boat, I could see are labeled "FULLY" and made by the Fully Motor Co Ltd of China.
I pulled out some electronics from the toy box that I am going to use in this boat. An XTM Sportsman esc; a 60mm muffin fan; a piezo warble siren; and a JJC Electronics Turbo Cat Diesels sound module. I have some small speakers. I am going to start with a 2" speaker and see how it sounds. I also have a couple 4" speakers. Some other things I have been noticing on the full size 47'MLB are the exhaust ports. I think I will make some for this model and have the cooling water flow out like in the 1:1 version. I also noticed the rudders are tilted outward on the 1:1 but straight up and down on the model. I don't know if it would be worth it or if it even matters enough to reposition them. I am thinking about doing this in the Canada Coast Guard livery. But I need to find some good pictures online. There are very few and none show the deck from the top looking down. |
Halifax
heres some pics i found at http://www.hazegray.org/navhist/canada/ccg/
those should be useful.. no longer directly linked |
| Thread Tools | |
| Midwest Products Foam ARF Cessna Cardinal | towlebooth | Foamies (Kits) | 5 | Feb 15, 2010 04:44 PM |
| Dazzler ARF build | Up&Away | 3D / Fun Fly Fuel Planes | 5 | Aug 05, 2003 03:44 AM |
| Alfa P-47 Thunderbolt ARF | dave_lilley | Site Chat | 0 | Jan 27, 2003 03:55 AM |
| Midwest 47' MLB Question | Rudderman98 | Scale Boats | 7 | Oct 31, 2001 07:12 PM |
| Cessna Cardinal from Midwest Products | towlebooth | Electric Plane Talk | 11 | Jul 13, 2001 03:36 PM |
