Any recommendations for video camera?
Looking for recommendations for a good value video camera for videoing at the flying field.
Ideally: not expensive, good image quality, 1080p, tri-pod mountable, light weight and small but large and heavy enough to get steady images while hand held. |
Latest blog entry: Powerpoles explained by Oz
inexpensive
Reasonable in price compared to the competition and in light of the features.Or, provides a good value for the money while leaving room to buy another plane. |
any canon PS will do but spend the cash and get the go pro
its just so easy and nice to have |
Thanks Maiden. You just reminded me of something. Are there any good handycams that have a hood for the lens? I know from still photography that can help out a great deal in image quality outdoors.
Otherwise, there is a DSC-HX10V out now. I wonder if that is as good or better when it comes to video. |
Any of the sony or canon handy cams are great. I personally love the HV series however they are tape based so a bit out of date if your looking for cheap go here: http://www.mustek.com/onlinestore/pr...roducts_id/309
I shoot pro, so i'd really recommend something worth the money though. It is just like rc you get what you pay for. Now if you get a dslr, just remember, the depth of field will be super shallow making it difficult to follow action zoomed in. |
Joined Nov 2008
I shoot and edit video professionally
I highly reccomend this one: - a traditional video camera http://www.dwidigitalcameras.com.au/...idProduct=3400 its well priced and will do 1080 p at 50 or 60 frames (which can be conformed to beautiful slo mo in a 25 / 24 or 30 p timeline) This will give you this sort of look
Go pros are no good as your only cam as they are simply too wide angle and your audience wont feel what is going on mid flight as the action is too far away. They are great for onboard action - you can generally get one on any well powered model heavier than about 800grams
and go pros can get tricky angles like this
I wouldnt recommend DSLR for action shooting (although i use one - but it makes me dance on all the controls) DSLR will give you the depth of field you tell it to - depending on what aperture you choose to shoot at - F16 or f .095 so the shallow DOF (awesome fro close ups of the model on the table) option is there but you control the image and can go for everything in focus too ALways try and shoot at shutter speed = double your frame rate - so if you are shooting 30 p - your sutter speed should be 1/60 too many DSLR operators try and control light by bumping up the shutter speed - this gives that choppy look as there isnt correct motion blur to belnd from one frame to the next. - better to set the camera shutter speed - and then control your light via a fader nd and using the histogram for best exposure / dynamic range - if all this sounds like gobbledeegook - then welcome to the world of shooting video on DSLRS (go faster on your shutter speed - up to 1/250 or even 1/500 if you are planning to Twixtor on your footage or use final cut x optical flow for 5 - 10 times slow motion) Hope this post gives you some ideas moving forward |
Thanks Rflex. That one you recommend is discontinued in the U.S. What about V500M
Go for the V700. http://www.bhphotovideo.com/c/produc...Camcorder.html It's the top of the Panasonic consumer line. Add your own SD cards to it, or else get the V700M which has some built-in memory but the cost of the built-in memory is high compared to getting your own cards. According to reviews the V700 gives noticeably sharper results than the V500. Oh, and the V700 has a 28mm (35mm film equivalent) wide end. I can't remember what the V500 has but think it's 35mm. For shooting plane you'll mostly be at 35 or more, but if you use the camera for other things I am sure you'll find the 28mm wide end comes in handy now and then without the cost and hassle of fitting a wide angle adapter.
I'm fan of gopro. Always have a couple ready to go:
They match up real well with dslr footage if you decide to go with a t2i or something.
As far as the panasonics go, you'll get a bigger sensor with the V700. so it should perform a bit better in certain low light conditions and more data is always nicer. there doesn't seem to be a big price diff over the v500. if you want to save go with this one. It has the same sensor the v500 does at less than half the price: http://www.bhphotovideo.com/c/produc...Camcorder.html |
| Thread Tools | |
| Discussion Recommendation for transmitting GoPro video | KGarrison | Aerial Photography | 1 | Mar 22, 2012 01:43 PM |
| Discussion Camera Recommendation for HD onboard video | Anatomist | Aerial Photography | 13 | Mar 18, 2012 02:03 AM |
| Discussion Quad recommendation needed for video | lbartone | Multirotor Talk | 1 | Feb 22, 2012 07:55 PM |
| Question Looking for a 64mm EDF, any recommendations? | kwiktsi | Foamy EDFs | 12 | Feb 19, 2012 10:56 PM |
| Discussion Recommend a good camera for filming moving aircraft? | bigo66 | Video Piloting (FPV/RPV) | 5 | Sep 12, 2011 01:34 AM |
