Old May 17, 2007, 09:57 PM
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
How to locate a Local Historical place
This thread is for discussion for "History", How to locate a Local Historical place.
The working thread is located here.
http://www.rcgroups.com/forums/showthread.php?t=687319
Dan
kd7ost is offline Find More Posts by kd7ost
Old May 18, 2007, 01:10 PM
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Kd7 ...I would urge all your flying observer's to remember timing for their sorties...........
first on the day ........the direction and angle of light can throw small changes in relief or vegetation into surprising contrast.
In terms of changes in the climate long dry spells can show up patterns of disturbance under on and under the surface .........aerial archaeology surveying -standard practice, the first flush of growth following a break in a drought can also yield other signatures.
Season - tree cover is obvious but the seasonal patterns of growth can also tell there own stories about the ground beneath .............. if your using IR sensitive film or cameras sudden changes in temp gradient can indicate where mine water enters streams /rivers.. or natural underground waters emerge ............
The contrast is best at the likely surface water extremes the ground-waters usually remaining relatively constant. Seasonal or diurnal.
Simple optical filters polarizing UV and colours can give some amazing results at very low costs............ Ive bought handfuls of 35mm \SLR filters for a few $ equiv because lots of people have offloaded their film cameras and gear for often short lived and sometime inferior digitals.
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old May 18, 2007, 01:22 PM
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
Good advise all around.
In the example I used on the working thread I'm going to go late in the year. Not just because summer time is busy at my day job, but because the snow on Juniper Mountain will be melted and the river water level will be low. If it's low enough I'll be able to drive across the ford and get a good deal of exploring in on both sides of the canyons. I intend to make at least a two overnight stay of it out there the first time around. I'll take a lot of pictures, early morning and late afternoon as well as midday. That should give me enough time to cover a fair amount of ground and get a general overall feel for the place. Then if I see areaís that I would like to dig further into, I can go back and focus more attention and resources on that spot.
Thanks for the great input. I agree with you 100 percent.
Dan
Old May 18, 2007, 01:46 PM
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
Yes, the angle and direction of the lighting is important, as is presence and absense of vegetation. Although the magority of my AP is technical and construction-related, I try to get out often and photograph old homeplaces and towns.
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old May 19, 2007, 10:10 AM
Did You Hear That?
wattnoise's Avatar
Tucson, Arizona
Joined Aug 2003
Web Research
Some info is better than others on the web... Best bet is to corroborate information from 2 or 3 different sources with credentials... Don't just use Wikipedia exclusively for example... One that is good is a project using the US census... The link below is a compilation done a few years ago that is useful to me and the historian of the museum I work at for a field project we're planning in the fall... You can use the info in the header of the text to request your own research for genealogical and historical reference...
http://www.rootsweb.com/~cenfiles/az...dex/indx02.txt
Kevin
wattnoise is online now Find More Posts by wattnoise
Old May 20, 2007, 06:03 AM
B'ham UK
Joined Oct 2005
Yep watch out for wiki it depends who last edited it they might be wrong.....the more specialist the area your looking at the more you can run into problems......... .old maps surface and Geological, surveys, photos, drawings and word of mouth can all give you clues .......... reading the environment is incredible mix of dynamic and constant - the trick is to approach it with eyes open and your mind even more open but forearmed with possible clues.
Old May 25, 2007, 05:20 PM
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
Kevin
Kevin,
I had luck with the link after I chaanged it to this.
Dan
Mini-HowTo "History", How to locate a Local Historical place kd7ost Aerial Photography for Scientific and Historical Discovery 1 May 18, 2007 08:37 AM
how to locate the CG??? submarco Parkflyers 1 Apr 27, 2005 08:15 AM
Question How to locate a bad cell? 94ZA4 Batteries and Chargers 6 Feb 09, 2005 09:05 AM
Local Flying place daryl GWS (Grand Wing Servo) 4 Mar 27, 2004 09:25 AM
