Old Apr 08, 2004, 01:29 PM
HeyLuc's Avatar
Australia, VIC, Traralgon
Joined Nov 2003
Question
F-35 Mini Fan
Hello,
can somebody give me a hand with the C of G on this plane?
Luc
HeyLuc is offline Find More Posts by HeyLuc
Old Apr 08, 2004, 03:53 PM
How fast can balsa go?
rogwinger's Avatar
Chilliwack B.C.
Joined Jan 2002
Perhaps some of the experts around here will chime in. If you don't have to worry about fuselage lift then this should be close. C of G set at 23%. You can always build a chuck glider to confirm. I will be building a fan fold foam chuck glider of the same size as my F-18 before I commit it to the catapult. I may even put servo's in it as well to test out the taileron controls.
rogwinger is offline Find More Posts by rogwinger
Old Apr 08, 2004, 08:40 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I wanted to check this out before I said anything, but you always want to carry the wing planform all the way to the aircraft centerline. Failure to do so will almost always result in a tail-heavy condition.
I've re-calculated the CG using the full wing planform instead of just the exposed wing area. The CG shown is 23% MAC. You also want to do this for wing area calculations.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Apr 08, 2004, 09:23 PM
rogwinger's Avatar
Chilliwack B.C.
Joined Jan 2002
Thanks for that Dan. I will write that down.
Old Apr 09, 2004, 01:02 AM
HeyLuc's Avatar
Joined Nov 2003
Thanks, I'm still in the design stage, but I need to now where to place the batteries.
Does it look real?
Luc
Old Apr 09, 2004, 03:44 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
No problemo. I hate to see a perfectly good airplane crash for something as preventable as this.
Luc, No, it doesn't look real. It looks real cool.
Dan
Old Apr 09, 2004, 06:32 AM
Harry v. Melick's Avatar
Altea la Vieja, Spain
Joined Mar 2004
This is what I found on internet. (ZIP-File)
http://home.germany.net/100-173822/schwerp.htm
It is a more comprehensive method but in this case the fuselage isnít part of the calculate either.
In my opinion, the fuselage, especially when talking about modern Jet-fighters, becomes more and more important if you calculating the C.G.
I am following your project with great interest, please keep us in touch.
Best regards,
Harry
Harry v. Melick is offline Find More Posts by Harry v. Melick
Old Apr 09, 2004, 10:22 AM
Mustang5's Avatar
Joined Jan 2004
Hello,
Nice model By the looks of it, its the C version. I was just wondering what program did you use to make that? 3ds max? looks nice!
thanks
Mustang5 is offline Find More Posts by Mustang5
Old Apr 09, 2004, 12:41 PM
Doc Watson's Avatar
UK
Joined Mar 2000
I used the method above in the diagram but with the wing projected to the centerline of the aircraft. I also calculated the effects of the stabs and nose and they effectivly cancled each other out so find the mean aerodynamic chord (MAC) and choose your CG point (mine is at 15% MAC). I discussed this with Kevin Cox about a year ago and he confirmed this was about right, he has built and flown a midi fan f35 already. Do a search it should still be here.
Doc Watson
Doc Watson is offline Find More Posts by Doc Watson
Rave RBC F-35 Mini Fan 480 Prototype HeyLuc Electric Ducted Fan Jet Talk 141 Mar 23, 2009 02:41 PM
Sold het f-16 and mini fan steve morris Aircraft - Electric - Jets (FS/W) 6 Dec 10, 2007 11:27 PM
Discussion F-35 Mini Park Jet flyguide7 Pusher Prop Jet Models 5 Mar 19, 2006 07:34 AM
$35 Mini-B mini flying wings F/S Moter&prop included pics shown on post sylair Aircraft - Electric - Airplanes (FS/W) 77 Nov 25, 2003 06:32 AM
$35 Mini-B micro flying wing f/s moter & prop included (i got pics) sylair Aircraft - Electric - Airplanes (FS/W) 26 Apr 08, 2003 09:46 PM
