Old Mar 09, 2009, 05:35 PM
fast chevron foam
WingmanDan's Avatar
United States, CA, Laguna Niguel
Joined Jun 2005
Suggestions for FunJet power system
So I have a Multiplex funjet here and I want to make it go fast. I've built several fast wings so I do know some stuff about power systems. Please let me know how this would work out:
4s lipo ... what size is best for the weight ratio of this plane?
45A CC ESC ... is this beefy enough?
HET-4W 2200kv ... good motor choice?
APC 5.5x5.5 ... appropriate prop?
Thanks!
WMD
WingmanDan is offline Find More Posts by WingmanDan
Old Mar 09, 2009, 05:58 PM
almost slackin
Joined Dec 2005
If you're gonna use the stuff you listed then a 2100-2500 mah 4 cell would work fine, use a external BEC with that esc.
I had the exact same setup you quoted and got about 110 mph using a 6x4 APC sport prop.
This setup is still light enough to retain slow speed handling and have awesome vertical performance.
Piledriver is offline Find More Posts by Piledriver
Old Mar 09, 2009, 06:00 PM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
Thanks, I just might do it then. Definitely separate BEC. I learned the hard way on my Ritewing... lost power to the Spektrum Rx and crashed.
Old Mar 09, 2009, 07:01 PM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
Did you ever test the AMPS with this setup? A 6x4 seems like it would work the 45A ESC pretty hard.
Old Mar 09, 2009, 08:11 PM
almost slackin
Joined Dec 2005
I seem to recall about 40 amps max, just under 500 watts. The esc should have a little headroom left. The motor also can handle it, I even tried a 6x5.5 but then the motor was getting too warm.
Old Mar 10, 2009, 06:21 PM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
-bump-
Anyone else care to share their killer funjet 4s setup? I want to know all my options beforehand. Thanks!
Old Mar 10, 2009, 07:20 PM
almost slackin
Joined Dec 2005
I also have a Funjet with a NEU 1110 running on 5 cells and an 80 amp esc and a 6x5.5 prop, that setup is Killer.
Old Mar 10, 2009, 07:58 PM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
Sounds fast, but a bit much for me
Is this setup better than the original I posted?
HET 2W-23 (2850kv)
CC60
5x5
4s3000 30c
Old Mar 11, 2009, 06:29 AM
almost slackin
Joined Dec 2005
I have that motor in a 40" wing and will tell you it really sucks the amps, it is really an edf motor.
I have gotten high amp readings using just a 4.75x4.75, your 60 amp esc will be overloaded with a 5x5.
The 2w-25 will be a better choice.
Old Mar 11, 2009, 08:04 AM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
Ok, what about this vs. the HET-4W setup?
Old Mar 11, 2009, 07:18 PM
almost slackin
Joined Dec 2005
The 4w is a lighter motor than the 2w-23 or 2w-25, also a lower kv, 2200.
The 4w is a good choice for up to about 110 mph running 4 cells and a 6x4 prop
Old Mar 13, 2009, 03:21 PM
fast chevron foam
WingmanDan's Avatar
Joined Jun 2005
I am going with the HET-4w setup but it seems to be out of stock everywhere
Old Mar 22, 2009, 12:43 AM
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
micro dan
A real sleeper is the micro dan 2505 speed. 38 grams!!!
4.75x4.75 on a 2100 4s. Pulls 37 amps and it is screaming fast. You won't believe that such a small motor
could be that fast. I just put a egale tree speed meter in but don't now how fast yet. When it landed at the feild it drew a big crowd to look at it. Jaws dropped when they saw the motor.
Lammergier is offline Find More Posts by Lammergier
Discussion Plane suggestions for this power system? swhitebc Electric Plane Talk 8 Sep 03, 2007 09:14 PM
Need suggestions for a power system Sparr Power Systems 0 Apr 24, 2004 02:26 PM
Aspire RTF - suggestions for more power? ekflag Electric Sailplanes 15 May 27, 2002 01:33 AM
Maximum Voltage for GWS Power system lrjoyce Parkflyers 11 May 08, 2002 02:28 AM
Help for SF power system? hardlock Parkflyers 3 Jan 03, 2002 10:52 PM
