Old Aug 07, 2007, 11:59 PM
sairaghi's Avatar
Switzerland -Stabio
Joined Nov 2004
Max current
Hi, I would like to know how much is the max. current carried by the 10CH receiver. I am planning to use the 10 channel receiver with 5 HS 5955TG and 2 std servos. Do I need something like a "power box"?
Thank you
Stefano
sairaghi is offline Find More Posts by sairaghi
Old Aug 08, 2007, 01:18 AM
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
If I remember correctly its something like 70 amps, a lot more than those servos will pull or the connectors could handle. You will have to worry more about the batteries and what connectors you use than the Rx.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Aug 08, 2007, 10:18 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
70 amps @ 30 volts. However, the servo pin won't handle more than about 5 amps of current. This is why it is recommended that you have two battery inputs into the receiver if you are driving high amperage servos.
JimDrew is offline Find More Posts by JimDrew
Old Aug 08, 2007, 01:32 PM
early retired & loving it
USA, AZ, Kingman
Joined Aug 2005
Hi again Jim,
I hope I'm not being a bother but this is another note that would be good under "Important News and Information"
Receiver design notes:
bnrusso is offline Find More Posts by bnrusso
Old Aug 08, 2007, 01:38 PM
Lake Havasu, AZ
Joined Jun 2005
I added the information you suggested... thanks.
Old Aug 09, 2007, 02:46 AM
sairaghi's Avatar
Switzerland -Stabio
Joined Nov 2004
Thank you. Summarizing: the amperage is not a problem for the receiver but is a problem for battery.
Max current into speed 280 and speed 300? rcastab Power Systems 2 Sep 20, 2001 10:33 AM
480 max current/cells moorej Electric Plane Talk 1 Sep 13, 2001 10:55 PM
Sanyo 720mah NiMH max current drain? Ben74 Power Systems 8 Aug 03, 2001 12:52 AM
What's the max current from 1800 NiCads? Steve H. Power Systems 4 Aug 01, 2001 12:20 AM
Max Current for Zapped RC2000s? ScotY Electric Sailplanes 3 May 05, 2001 08:01 AM
