Old Jun 07, 2007, 10:44 AM
Speed cost money.
highflier's Avatar
United States, FL, Marathon
Joined Dec 2002
Question
Question (Batteries and Throttle curve) align trex v2
I have recently started flying a Trex 450 se v2 ( the real v2)
I have a lot of less expensive lipos and of course the 20-22C that comes with the V2. Wow the performance diff is huge! Anyways I have actually had to adjust throttle curves acording to the battery. Just for hover and that type of flight. (I am still learning) That did not make sense to me until I realized that the V2 ESC did not ship defualted to Governer mode. I beleive if I put it in Govener mode that the Throttle curves should be common between the good and cheap batteries.
Is there a reason that Align does not defualt the ESC to Govener mode?
Is there any reason that I should not change it to Govener mode?
I fly a Revo (shogun clone) with a CC25 in govener mode and have had no issues at all.
Thanks for the input you post
Highflier
highflier is offline Find More Posts by highflier
Last edited by highflier; Jun 07, 2007 at 02:10 PM. Reason: updated title more discriptive
Old Jun 07, 2007, 12:00 PM
United States, GA, Roswell
Joined Mar 2007
Why (or how) would the battery affect your throttle curve? I ask as a novice myself
hurleybt is offline Find More Posts by hurleybt
Old Jun 07, 2007, 12:08 PM
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Highflier
first off if your running the XL motor from the v2 kit you will need higher end batteries... The 22c that comes with the kit is great if your using a 11t or 12t pinion... Forgot about it if your using a 13t.. you will need TP's or EV's.
Regarding aligns esc gov function... they dont work that well! Some have no problems some do. I cant seem to get them to work without racing with the gyro (high speed tail wag).
I use a 12t with the following thr curve:
100-95-90-95-100
blade strike is offline Find More Posts by blade strike
Site Sponsor
Latest blog entry: GenAce Tattu 25c 22,000mah 6s1p
Old Jun 07, 2007, 12:09 PM
Joined Jan 2006
Since his older lower-end batts dont give the same power as his align 22c. So his batteries are pretty much changing the thr curve, if that makes any sense
Site Sponsor
Old Jun 07, 2007, 02:09 PM
Speed cost money.
highflier's Avatar
Joined Dec 2002
Due to voltage drop the head speed changes unless you use Governer mode.
I am using the smallest pinion that came in the kit, (I think it is 11 tooth).
Before I say this I thought the govener mode was enabled
My throttle curve was 0,60,60,60,60 (headspeed was 2400 align battery)
My throttle curve was 0,70,70,70,70 (headspeed was 2200ish with 12C-016C batteries) 100,95,90,95,100
If I used the 0,60,60,60,60 with the cheap batteries, The climb was almost non existant. To the point I was afraid if I decended to fast I would not be able to stop before I hit ground.
When I look at above throttle curve 100,95,90,95,100 I got to wonder what headspeed does that give you..... Wow got to be a big diff from the 60 that I am running.
Of course I wanted longer flight and less damage if a screw up so I am happy with the 60% throttle right now.
Highflier
Old Jun 07, 2007, 05:16 PM
Certified
jgoodwin's Avatar
Joined Sep 2006
FYI. As Highflier loosely implied, governor mode does not like throttle curves. it like flat throttle 'levels'. Normal can be like 0-70-70-70-70. But Idle 1 and 2 should be flat if you are using governor mode. Like 100-100-100-100-100. If you want a curve, do not run Governor mode.
I had it is governor mode with curves before I knew this and when I went to mid throttle and then back up it would not spin back up to full speed. I finally figured it out though...
-J
jgoodwin is offline Find More Posts by jgoodwin
Sold Align Trex V2 2100 pack NIB mavdriver Aircraft - Electric - Helis (FS/W) 2 Jun 11, 2007 12:33 PM
For Sale Align Trex V2 2100 pack NIB mavdriver Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 11, 2007 12:28 AM
Sold Align Trex 450x V2 + 2 Li Poly Batteries & Charger karl51 Aircraft - Electric - Helis (FS/W) 1 Nov 29, 2005 05:01 PM
Pitch/Throttle Curve Question? endeavor_635650 Micro Helis 6 Oct 05, 2005 03:33 PM
HB CP Throttle Curve Question aplphabandaid Micro Helis 0 Jul 08, 2004 12:56 PM
