Old Oct 06, 2014, 07:16 PM
Joined May 2013
Extreme climb
I'm having an issue with a scratch built foamie, pusher delta I put together.
Basically the issue is related to the rate of climb the delta has when throttle stick is applied. What I'm seeing is as the throttle is increased the delta goes into an ever increasing steep climb. I have to throttle back to below half throttle to get the bird to level off or try to counter the climb by adding down elevator.
I end up with a lot of throttle management and a slow flying bird.
The bird is basically $ tree foam with a wing span of 30 inches and a length of 20 inches, with power being provided by a 1700kv motor.
Any help would be appreciated.
HeliMinion is offline Find More Posts by HeliMinion
Old Oct 07, 2014, 12:41 AM
Joined Apr 2013
Try moving the CG forward in tiny increments (like 1/8 inch) and retest till you get it where it feels right for you.
Also: Make sure your thrust line passes through the vertical CG (this has been discussed in many posts - do a search). If it is passing below the vertical CG, that could be another cause of the symptom you're seeing.
nuteman is online now Find More Posts by nuteman
Latest blog entry: My youtube channel
Old Oct 07, 2014, 12:37 PM
Joined Aug 2005
Need to confirm planform before offering suggestions. Does your wing look like the one in the linked cg calculator? If not adjust the factors in the calculator and post a link in this thread. (Deep link - This specific wing at lower right of calculator)
http://fwcg.3dzone.dk/?wing_span=30&...ow_mac_lines=0
DT56 is offline Find More Posts by DT56
Old Oct 07, 2014, 09:48 PM
Joined May 2013
No Sir (DT56), my wing does not have this delta shape. The bird has the shape of a chevron (traditional flying wing). Additionally, the elevons are 2 inches wide and the 1700 kv motor is affixed to the fus with a stick mount. I've added a photo of the bird.
The following are its dimensions:
Wing span: 30 in. / Root cord: 13 in. / Tip cord: 11 in / Sweep: 10 in.
Tried to get the Deep Link to show as yours did but I'm not savey enough with the computer to get it work properly.
Using the numbers above I got a CG of 7.27 inches, which is close to the build suggested cg of 7.
If I've done things correctly with the cg calculator it appears to me the bird is about right on.
I appreciate your time....
Old Oct 08, 2014, 02:16 AM
Joined Apr 2013
Lots of times what the calculator and/or the plan recommendation suggest for CG will not perfectly suit your particular build. And as you pointed out there's a quarter inch difference between what the calculator and the plan suggests - a world of difference in the chevron wing situation.
Have you tried moving CG forward in small increments and re-testing?
Old Oct 08, 2014, 07:39 AM
Tree hopper
gabe221's Avatar
United States, TN, Dresden
Joined Sep 2013
Your tail heavy. These wings need to be nose heavy. As for what the cg is ?? It'll fly with the battery on the nose.
gabe221 is offline Find More Posts by gabe221
Latest blog entry: The air show
Old Oct 08, 2014, 07:31 PM
Joined May 2013
nuteman / gabe221 -
Yes, I have attempted to change the CG by moving the batt forward. If there was a difference in the flying attitude it wasn't noticeable. I don't have much more room for forward movement but I'll use what I have up. I suppose I could at weight and see how that turns out.
Thanks for the replies gents...
Old Oct 08, 2014, 07:43 PM
Tree hopper
gabe221's Avatar
Joined Sep 2013
Use a heavier battery --30" span 3s 2200-3300
Old Oct 09, 2014, 07:49 PM
Thailand
Joined Aug 2010
Many models climb when the CG is too far forwards. I know this is not what some people have said but, if the CG is too far forwards then you need to fly using more up elevator to balance the nose heavy airframe in straight and level flight.
As the speed increases the up elevator becomes more effective and the aircraft climbs.
Many people make this mistake.
You can alter the motor thrust line which can help.
One way you can check the CG is to fly it inverted and see how much down is required to hold it level.
If you have to push lots of down then it is nose heavy. If it climbs when inverted you are in a dangerous situation because the CG is too far back. This is an easy test to do.
Flying wings tend to need a slightly more nose heavy CG than airframes with tailplanes.
If you cannot fly inverted get some help from someone.
Jim
Fox-composites is offline Find More Posts by Fox-composites
Old Oct 09, 2014, 08:35 PM
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
Here is another data point for CG that has worked well for me (click on the diagram): http://www.charlesriverrc.org/articl...GMarkDrela.htm
1fullbird is offline Find More Posts by 1fullbird
Old Oct 09, 2014, 09:10 PM
Joined May 2013
Fox-c / 1fullbird-
In reading yours and the other posts i find myself asking what constitutes too far forward/too far back? It was and has been my understanding that each model has it's specific CG location. In my model the CG location is suggested to be 7 inches back from the nose. The CG calculator (using my model's dimensions) indicated the CG should be 7.27 inches back.
Are you saying I can/should be balancing the model to change the location of the CG?
Old Oct 10, 2014, 01:08 AM
Thailand
Joined Aug 2010
CG problem
Hello, what I am saying is that you can work it out on paper and get an approximate CG position that will allow you to fly the thing but,, the only real way to find the perfect CG is to fly it. Even full size get it wrong sometimes and have to shove a load of weights in the fuselage to get it correct.
A very good way to check if it is correct is to fly it inverted. If you are flying a forward CG then you will have a lot of UP elevator to fly level the right way up but when inverted you will to push a lot of down elevator to fly level.
The more down you have to push in then the more nose heavy it is.
You can get to the point where you have moved the CG back too far and the model will need no down elevator to fly level and will probably be unstable. Deltas can go into a flat spin in this condition.
Most people think you should move the CG forwards to correct your problem but this is not correct.
If the CG is correct then it could be the engine thrust line and you could raise the motor above the wing centre line which would push the nose down with power or angle the back of the motor down and try it.
Regards Jim
Old Oct 10, 2014, 03:45 AM
Australia, VIC, Mitcham
Joined Dec 2011
I'd say it's not a CoG problem as much as a thrust axis problem. If the thrust vector from the prop isn't passing through the CoG then it will create a pitching moment which will need to be counteracted by elevon deflection. More thrust = more pitching moment.
Hang the aircraft by a thread from the prop like a plumb-line and see if the thread and the prop axis line up somewhat.
Even so, any aerofoil will generate a pitching moment to some degree, so there's complicating factors, as always...
Andy_RR is offline Find More Posts by Andy_RR
Old Oct 10, 2014, 05:21 AM
Joined Apr 2013
Looking at your motor mount in the pic, it's hard to tell if there's any appreciable thrust line issue (below vertical CG). First make sure that's sorted out and re-test.
You said you moved the CG forward and no discern-able change resulted, but by how much did you move it?
It is also normal to have at least some mild pitch up on power increase, so it's a matter of getting it to a level that you feel comfortable with.
Unless you have a lot of reflex trimmed in (up-trim), it almost certainly not nose heavy, but there's nothing like empirical evidence, so here's what I would do:
First try moving CG back a bit from where it originally was. Is it better or worse?
Move CG forward (you ran out of nose room, so use some dead weight or heavier battery). Is it better or worse?
You will eventually find what you like with this method.
Old Oct 10, 2014, 06:51 PM
Thailand
Joined Aug 2010
If you really can't fix it with the motor thrust line or the CG you can mix in some down elevator with throttle. Not a great idea but it can work for some models.
What is the wing section like.?
Jim
Discussion Mini-Air SU-26 Won't Climb Bob6831 Beginner Training Area (Aircraft-Electric) 3 Sep 26, 2014 07:55 PM
Link Losi micro rock crawler EXTREME hill climbs vid!! aking720 Micro Cars 6 Jul 07, 2012 08:01 AM
Discussion Best angle of climb and best rate of climb Daniel Wee FPV Talk 31 Apr 28, 2009 04:42 PM
Discussion Climb angle for best rate of climb? mnowell129 Modeling Science 113 May 03, 2008 01:29 AM
Cool Extreme AP'ing. Climbing a mountain and flying from the peak. Lynxman Aerial Photography 13 Aug 21, 2006 04:46 AM
