Old Aug 22, 2014, 03:08 PM
oshawa ont canada
Joined Feb 2010
Carb lifting off dynamite .15
as the title states,cant seem to solve this problem.i have run my boat (proboat fastech nitro)numerous times this season,runs very well.as of late,i have had numerous incidents where the carb keeps lifting off the intake.the first sign of trouble was earlier in the season while after an afternoon of running,i noticed the screw which clamps on the dowels to hold the carb in place,was loose.i removed it and used threadlock to keep it tight.ever since then,the carb keeps working itself off while running.i have had the engine out numerous times,reinstalled the carb and screw and it was good and tight.just this afternoon the same thing happened.im getting a tad frustrated.if anyone has any tips or a solution,it would be greatly appreciated.thanks.
bigcam406 is offline Find More Posts by bigcam406
Old Aug 25, 2014, 09:57 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
It may have developed a taper or damaged the carb from overtightening. They only tighten the opposite side of the nut.
I just thought of something that might do the trick. It's been awhile since I've been around any Dynamite .15's but if the tightening nut is on the right side, see if you can put it on the left by turning it around. What I'm tihnknig without being there is that maybe, just maybe that when the nut is tightened on the right side that when you tighten down on it, it's pushing the carb up.
Ron Olson is offline Find More Posts by Ron Olson
Old Aug 26, 2014, 08:17 AM
oshawa ont canada
Joined Feb 2010
thanks for the response.i'll try what you suggest.i find that when i reinstall the carb,its really a struggle to press back on,very tight.takes alot of effort.i find it hard to believe that i have overtightened it and caused a warp.but what you say makes sense.i was thinking of doing a carb swap(i have another Dynamite sitting around) to see if that works.i'll try your solution first,and if not,try the carb swap.i'll let you know.thanks again.
Old Aug 28, 2014, 10:51 PM
oshawa ont canada
Joined Feb 2010
i removed the clamps and screw completely today.i found that the problem was the clamps wernt positioned properly,how they got moved i dont know.anyways,the carb was pushed on with no problem were as before,it was a pain to push on.tightened the screw and all seems good for now.we'll see when i run it this weekend.thanks.
Discussion V450do3 will not lift off Vmoon Electric Heli Talk 14 Oct 17, 2013 11:10 AM
Discussion Push for lift-off on drone deliveries in Australia ! Mrhide Multirotor Talk 3 Oct 15, 2013 10:09 AM
Sold NIB Dynamite .15 motor, w/ TigerDrive, RotoStart, tank $100 shipped / 48 Gabe_BigApple Boats (FS/W) 1 Oct 09, 2013 02:42 AM
Help! honey bee fpv2 lift off problem thegrill77 Beginner Training Area (Heli-Electric) 15 Oct 01, 2013 10:25 AM
For Sale 15% off on Composite Pods and E-Pods, 20% off for fuselage pod sets ClmPro Aircraft - Sailplanes (FS/W) 0 Sep 24, 2013 09:45 AM
