Old Aug 20, 2013, 06:09 PM
United States, GA, Atlanta
Joined Apr 2013
Stock Parkzone T-28 Power system use in other Parkzone Birds?
I have the Stock Motor and ESC for the Park zone T-28 Trojan. I am currently not using the power system as i have upgrade to a larger motor and ESC. Is there any plane or kit that I could purchase and use this power system with? See links below for power system specs. Thanks
480 Brushless Outrunner Motor, 960Kv by ParkZone (PKZ4416)
http://www.horizonhobby.com/products...-960kv-PKZ4416
30-Amp Pro Switch-Mode BEC Brushless ESC (V2) by E-flite (EFLA1030B)
http://www.horizonhobby.com/products...-v2--EFLA1030B
eddyalce is offline Find More Posts by eddyalce
Old Aug 20, 2013, 06:43 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
there are other PZ planes you can use that in. just buy the replacement airframe and build it.
cmdl is offline Find More Posts by cmdl
Old Aug 20, 2013, 06:50 PM
The Sweet Aroma of 92 Octane
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
My Parkzone P47 used that same power system.
electricrc68 is offline Find More Posts by electricrc68
Old Aug 20, 2013, 07:05 PM
1st to the scene of the crash
Laneritc's Avatar
United States, GA, Dalton
Joined Jul 2012
Sounds like the right set up for a Mini Ultra Stick
Laneritc is online now Find More Posts by Laneritc
Old Aug 20, 2013, 07:06 PM
Foam Wrecker
voidmix's Avatar
United States, NY, West Babylon
Joined May 2012
I don't believe the P47 uses the same motor as the T28. At least mine didn't. Mine came with a BL15 motor whereas the T28 comes with a 480 size motor.
voidmix is offline Find More Posts by voidmix
Old Aug 20, 2013, 07:09 PM
Joined Apr 2013
The stock p47 uses BL15
Old Aug 20, 2013, 07:40 PM
Joined Apr 2013
Just looked at the Mini Ultra seems like the perfect power system for it. I can not get over the looks of the mini stick though. It's one ugly beast and no rear landing gears.
Old Aug 20, 2013, 09:13 PM
Joined May 2011
Oh oops! I was looking at the KV rating. Didn't see the motor size.
Old Aug 20, 2013, 09:51 PM
aurorae's Avatar
Joined Sep 2008
I think the Parkzone Wildcat, Albatros and Stinson all use that motor. Corsair, too, probably others.
aurorae is offline Find More Posts by aurorae
Old Aug 21, 2013, 02:45 PM
Joined Apr 2013
The WildCat Looks like the best option so Far. I can also use the Extra 300 Prop for some increased performance. I guess this will be my next project! They sell the airframe only for about $70 to $80 online. I have not flew a belly lander before. This will be interesting. My Plane count is getting out of hand now.
Old Aug 21, 2013, 05:54 PM
Where did that tree come from
kid at 55's Avatar
United States, SC, Lancaster
Joined Nov 2010
Also the P51 Mustang. http://www.horizonhobby.com/products...ang-bl-PKZ1870
kid at 55 is online now Find More Posts by kid at 55
Old Aug 21, 2013, 11:15 PM
Joined Jan 2012
RE: Power setup
I am going to explain this the best that i can, so i hope that you/understand what i m saying
1) the actual size of the motor . depending on the size of the plane that your t-28 was. I.E 900mm, 1000mm,1200mm,1400mm.if the new plane was the same size the motor should fit. the motor fits the mount and fits the fire wall
2) the KVis a personal thing. the higher the KV the more power and torque it has.
3)what ever AMPS the motor use's for safety sake you want the ESC to be able to handle twice the amount. Here is an EXAMPLE (with the safety thing). you have a motor that pumps out lets say 15 AMPS....you want an ESC that has 25-30AMPS.even with a motor that uses 15 amps you can go as high as you want for an ESC will not harm it
helifreak1 is offline Find More Posts by helifreak1
Sold Parkzone T-28 Stock MIKEYOUR Aircraft - Electric - Airplanes (FS/W) 2 Mar 06, 2013 04:34 PM
Sold Parkzone PKZ1060 Servos (Used in Radian, Radian Pro, T-28 Trojan, Super Cub) Paul1PA Aircraft - General - Radio Equipment (FS/W) 0 Feb 23, 2013 07:14 PM
For Sale Stock Parkzone T-28 Power System, 30 Amp ESC & 480 motor FLAME747 Aircraft - Electric - Power Systems (FS/W) 0 Jul 26, 2012 09:20 AM
For Sale MAKE OFFER: Stock Parkzone LiPo and other T-28 Components N62350 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 24, 2009 10:04 PM
Sold Stock Parkzone T-28 power system phayes526 Aircraft - Electric - Power Systems (FS/W) 2 Nov 13, 2008 11:33 PM
