Old Aug 16, 2013, 09:20 AM
Joined Jul 2013
Help!
cross sectional plans
hello everyone
from last 3-4 months i am searching for plans
i need plans for f14 or f35 any one of them
scale 1/10 or bigger
can any one provide me or give me a link
abhayf14 is offline Find More Posts by abhayf14
Old Aug 16, 2013, 12:43 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Wecome to RC groups..have you tried airwar.ru
Old Aug 17, 2013, 05:36 AM
Joined Jul 2013
thanks
i searched on airwar got some good drawings
but i can only have 10 cross sections for f14 will
it be enough to build it.
Old Aug 17, 2013, 06:31 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Originally Posted by abhayf14 View Post
thanks
Not even close. I would think more in the area of at least 25- to 30.. I did a F-86F fuse last year, and it had 27.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 17, 2013, 07:19 AM
Joined Jul 2013
i had build f16 previously it had 45 of them it was a great build
now i need for f14
Old Aug 17, 2013, 09:14 AM
Joined Jul 2013
it would be great if anyone can give me templates.
for f14 or f35
Old Aug 17, 2013, 11:03 AM
Joined Dec 2008
Your asking or assuing a quite a bit---to think someone is just going to "GIVE" plans or templates.
Check this out, lots of F14's. You have to join--its free, to download. It also may take awhile to find one with enough sections- if there even is one.? You have to do the work now.
http://www.the-blueprints.com/bluepr...lanes/grumman/
Old Aug 17, 2013, 01:18 PM
Joined Jul 2013
i understand the point but i had very less time
i can make make cad model but it will consume much of my time
i started this thread to get some help
Old Aug 17, 2013, 03:44 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
The number of sections depends greatly on the method you plan on using to build your plane. If you are going to build a plug then you need formers spaced about 3" apart. Then strip plank using 3/16" balsa. At that spacing and balsa thickness you should be able to sand the planks without too much trouble. Any closer spacing just isn't necessary. So for a 30" long fuselage you would need 11 sections (one at each end). Remember though that when you make your sections you need to subtract the thickness of the balsa you plan on using for your planking. Others use different methods that may or may not require closer spacing.
As an example here is Matt Halton's F-14. This is 47" in length and as you can see from the build thread has way fewer than 40 sections!
http://www.rcgroups.com/forums/showthread.php?t=203163
The plans for this plane can be downloaded here in post #9:
http://www.rcgroups.com/forums/showthread.php?t=645874
and another build thread of this plane:
http://www.rcgroups.com/forums/showthread.php?t=1013118
Builds into a beautiful Tomcat!
http://www.rcgroups.com/forums/attac...mentid=2714796
SteveC68 is offline Find More Posts by SteveC68
Old Nov 23, 2013, 06:51 AM
Joined Jul 2013
finally got on ebay
http://www.ebay.com/itm/F-14-Tomcat-...item3386d2fcbc
thanks
coolerbythelake
turbonut
steve
Old Nov 23, 2013, 02:57 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I don't know what plan that is, maybe Model Airplane News, but just remember to study some EDF F-14 designs before planning the fan installation in a plane designed for glow ducted fans. On most jets, the fans will need to be placed farther back than they'd be on a glow fan because you need to counteract the weight of the batteries in the nose. On some designs you can place the packs on either side of the fan but with an F-14 the swing wing mechanism will get in the way. Jet Hangar Hobbies has an F-14 laser cut kit in two sizes, you might want to check that out. Search of posts by jetmang on here.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Nov 23, 2013, 03:26 PM
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
short route:
http://www.rbckits.com/shop/index.ph...od&productId=3
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Nov 23, 2013, 03:27 PM
Joined Dec 2008
I looked at them from the link--might be from M.A .N. as I have a set. Total of 9+ sheets, each sheet is labled as 1/2, 3/4 etc. If I can. I'll dig them out a post a pic.
Should be 18 pages 2 to each sheet.
Old Nov 26, 2013, 07:34 PM
unclecrash's Avatar
white lake michigan
Gotta love it! don't got time to do the CAD but can find the time to do the build!! Geez
I have heard them all.
unclecrash is offline Find More Posts by unclecrash
Discussion Derrell Cross Free Sterling Corvette Plans Derrell Cross Scale Boats 2 Jun 26, 2013 05:23 PM
Discussion plans or cross sections of the Dehavillan Q400 turbo prop airliner peterpont Scale Kit/Scratch Built 3 Dec 07, 2006 09:22 AM
Yippee! I need plans/3 views with cross sections for P-51D Mustang Daniel11 Scale Fuel Planes 3 Sep 01, 2004 04:49 PM
F-100 cross sections Magnaflux Electric Ducted Fan Jet Talk 7 Nov 29, 2001 07:50 AM
im looking for some good f-16c cross sections... i-fly Power Systems 1 Oct 21, 2001 02:54 PM
