Old Sep 09, 2012, 04:52 PM
United States, FL, Bradenton
Joined Jan 2012
PL6 charging without balance leads connected?
Do any of the modes allow you to charge without having any balance lead plugs connected?
I tried using a generic charge board to parallel charge 4 packs (without any balance taps connected to the PL6) in the Faster Charging mode" and it says "bad cell count node wiring" and says the same thing when I am in High Power mode? I remember reading about a balance dummie plug for certain Powerlab models to get around this but can't find it again and don't want to mess anything up Lol.
Thanks.
overmyhead is offline Find More Posts by overmyhead
Old Sep 09, 2012, 05:26 PM
Seattle
Joined Sep 2007
For LiPos there is the LiPo 1s/2s Small Non Balanced preset, but its limited to 2 amps. The "plug" was for the Cellpro10s and allowed you to charge using only the balance connector vs charge with only the charge leads.
Gregor99 is offline Find More Posts by Gregor99
Old Sep 10, 2012, 06:07 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Same question asked many different ways for years now.
Simple answer with Power Labs and most other balancing chargers both main leads and balancing lreads need to be connected and balancing leads have to be the correct sequence as brands use different wiring orders.
Power Labs have Non Balanced Presets which can be used for 1-2S LiPolys at lower power.
One should learn how LiPlys are wired,the Power Lab Manual has wiring drawings for 1- X S for both FMA and JST sequence. I suggest one study the drawings.
Recent thread here
http://www.rcgroups.com/forums/showthread.php?t=1721491
everydayflyer is online now Find More Posts by everydayflyer
Old Sep 10, 2012, 08:16 PM
Joined Jan 2012
Thanks guys appreciate the help.
Discussion How to charge only using balance leads on Accucell 6? Koo Batteries and Chargers 7 Aug 03, 2012 08:50 AM
Discussion charging a 3s battery without balance widget2k4 Batteries and Chargers 33 May 18, 2012 03:39 PM
Question charge through balancer without main wires connected? sandal Batteries and Chargers 16 Jul 04, 2009 10:37 PM
Discussion Charging packs without balance taps with balance charger? jbarr2000 Batteries and Chargers 18 Oct 13, 2008 07:59 AM
Question Lipo without balancing leads acidla Batteries and Chargers 21 Feb 05, 2007 12:50 PM
