Old Sep 12, 2012, 02:09 PM
UAV Guy
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
I just ordered mine today. I plan on installing a Ardupilot APM2.5 to create a easy to fly UAV system. It seems to be very stable and if it is anything like my EZ 1500 from HK it should be easy to repair too..
UAVJOE is offline Find More Posts by UAVJOE
Old Sep 12, 2012, 02:10 PM
Joined Sep 2004
Originally Posted by seojeff View Post
Got my carbon tube today to replace that heavy fiberglass rod. This tube is nearly the same diameter (tiny bit thinner) and only 1.25" shorter. It also weighs only 72 grams vs the fiberglass rod which weighed 309 grams. Fits inside the wings even better than the fiberglass rod - less force required to push them together but still snug.
This is part # 020039 from Goodwinds, you can find it here:
http://www.goodwinds.com/merch/list....ultrudedcarbon
Ordered two as well, thanks for the find.
ssgtakeo is offline Find More Posts by ssgtakeo
Old Sep 12, 2012, 02:42 PM
United States, ID, Burley
Joined Mar 2012
got a 55amp esc with 4amp bec coming, don't want any problems with this baby !
fastfwd is offline Find More Posts by fastfwd
Old Sep 13, 2012, 07:17 AM
United States, CT, Hartford
Joined Jun 2009
Did anyone else see this? Another member of the family, little baby Sky Surfer
http://hobbyking.com/hobbyking/store...dProduct=18473
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Sep 13, 2012, 10:38 AM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Please report back your progress. I would love to see how that works out.
compuatic is offline Find More Posts by compuatic
Old Sep 13, 2012, 03:52 PM
UAV Guy
UAVJOE's Avatar
Joined Feb 2012
I will report the build progress and the test progress.
Test and Flight Plan:
1: Build and fly as stock RC
2: install APM 2.0 and test stabilized Flight modes.
3: Tune and test Autonomous Flight modes.
4: Install RC video source switch and mount pilot view cam in nose.
5: install GoPro stabilized mount under wing and flight test with Vtx
This is subject to change but my goal is to produce a stable platform for video and long range UAV flights.
Old Sep 13, 2012, 04:35 PM
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
I have the apm2.5 as well. Wondering if the Bixler profile is going to work for the SSS. I may install mine tonight & find out. Installed my LRS today & will be testing that this afternoon. I'm using the 433 version of ezUHF.
seojeff is online now Find More Posts by seojeff
Old Sep 14, 2012, 03:23 PM
howieb38's Avatar
United States, NJ, Kinnelon
Joined Aug 2005
I built mine, it's really great, but not my kind of plane. Five flights, no problems. I have it listed here on RCGroups.com. Unfortunately local pick up in North NJ. I'm asking only what I have in it.
howieb38 is offline Find More Posts by howieb38
Old Sep 14, 2012, 04:38 PM
Chilliwack, BC Canada
Joined Mar 2010
And here is another. Unfortunately I can't find anyone who carries it in the western hemisphere yet..... or anywhere else actually. A 2M Sky Surfer.
http://www.x-uav.cn/product_view.asp?id=10
http://ycfeida.en.alibaba.com/produc...ky_Surfer.html
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 14, 2012, 05:03 PM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
PRC (People's Republic of Commiefornia)
Joined Jul 2005
Yes, I have that one also, it's the BridgeSky Vector 850, I don't know why they put "SkySurfer" decals on the wing, but it is manufactured by BridgeSky and it is officially named the Vector 850. BTW, it is a superb mini sub-1 meter EZ style sport plane, it is one my favorites. it's in stock at the USA warehouse btw:
http://hobbyking.com/hobbyking/store...arehouse_.html
Doubletap is offline Find More Posts by Doubletap
adgnade's Avatar
United States, TX, Midland
Joined Feb 2009
You can use regular CA on this correct
adgnade is online now Find More Posts by adgnade
Old Sep 14, 2012, 05:21 PM
Doubletap's Avatar
Joined Jul 2005
That's correct, as it is molded from EPO, not EPS.
Old Sep 14, 2012, 05:22 PM
Vern1960's Avatar
United States, VA, Richmond
Joined Apr 2012
Originally Posted by AussieHoppy View Post
righto... back to our illustrious giant bixler...
does anyone know if the tail boom part of the fuselage is solid foam or if there's a cavity?
i'm not sure if it is or not, holding light behind & such, i dont want to start cutting savagery unless i know before hand...
i'm probably going to mount my esc immediately in front of the motor, on top...
if you are using the built in bec, a failed esc is a doomed plane, i wouldnt take the risk cool that sucker by putting it in external air flow or vent the interior
I am also considering making some vents, there's no interior ventilation- battery, rcRx and any other electronics should have at least some fresh air circulation
Just got back from the flying field today for the first flight after cutting three 1/2 holes, one on each side of the nose and one in the bottom just in front of the wheel for cooling.. Worked Great..was up for 12 minutes with a 4000 lipo and upon landing the ESC was not hot at all and the entire interior was nice and cool.. Maybe version 2 will make these improvements.. Very happy to move on now with installing more video equipment...
Vern1960 is offline Find More Posts by Vern1960
Old Sep 14, 2012, 06:24 PM
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
great to hear you've had success
i'll be putting a vent either side of the nose & one somewhere rearward, once I work out what's in the sealed tail section
my Bix2 has the vent under the nose and i've already accumulated a enough grass clippings inside the fuse to start a lawn mulch pile lol so I wont be making any vents under the fuse anywhere. I actually sealed the underside vent on my bix2
just like the Bixler2, the fuse comes factory glued, with soooo much wasted space in the fuselage
thought I'd look on BH site, they have the fuse listed as a spare, out of stock, and no photo to see of the fuse comes seperated... frustrating...
AussieHoppy is online now Find More Posts by AussieHoppy
Latest blog entry: Back street quad cruisin'
Old Sep 14, 2012, 07:04 PM
adgnade's Avatar
Joined Feb 2009
OK got mine yesterday and here is what I have decided it is big and beautiful. I went to the local hardware store and bought music wire to upgrade the pushrods for the elevator and rudder don't know what size it was not marked but it was almost twice as big and slid in the existing tubes no problem. I was then going to update the esc but decided to put the whole power system I had in my fun cub. Bp2814_6 1400 kv 60 amp speed control and 5 amp bec. And ordered cf spar tube.
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
