Old May 31, 2012, 03:10 PM
Fly, tinker, fly, tinker....
numba's Avatar
United States, WA, Snohomish
Joined May 2012
Spray foam sealant?
I searched for this, but could find any relevant threads. Has anyone ever tried using spray foam sealant in their pod/fuse/boom? I'm referring to the type used to seal gaps during residential and commercial construction. My thought is using it to hold components, like pushrods (rod and tube) in the boom, or making molds for the receiver/battery to sit in inside the pod. The stuff sticks to anything, it's lightweight, and it carves easily with a sharp blade. Thoughts?
numba is offline Find More Posts by numba
Old May 31, 2012, 03:38 PM
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Puslinch
Joined Apr 2010
http://www.rcgroups.com/forums/showt...+foam+dlg+tail
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old May 31, 2012, 05:25 PM
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I've used it for years to hold pushrods in place inside booms, provide a bit of buckling resistance on older 3m fins, etc. It's very handy stuff in some situations.
I've used it inside clown balloons to apply pressure like a bladder inside a fuselage under repair as well.
Be careful not to use too much. Expansion can ruin stuff quickly if confined.
On a side note, gorilla glue is urethane as well and has similar properties when applied to a wet surface. I've used it similarly.
tom43004 is offline Find More Posts by tom43004
Old May 31, 2012, 07:49 PM
United States, MA, Waltham
Joined Dec 2001
If you mix Gorilla or other, similar polyurethane glue with a little bit of water (1 part in 10 or 20????) you can get a nice, flexible foam out of it. Recently used this when the foam under a spar cap got too crunchy. It's thin so you can inject it with a syringe, but doesn't have gobs of working time. Much slower than the stuff from the can or the two part mix, though.
A friend of mine used to use the spray stuff (or maybe it was the two part stuff?) in the fuselages of his Dodgson gliders. They had a taco shell style fuselage, so he could leave one side open and carve the overflow to shape afterwards. Worked for him.
However, it is possible to run into trouble with continuing expansion. I read an article by Stan Hall about a bad experience he had filling in surfaces on a full sized sailplane using the two part stuff.
If you have pushrods and tubes in the tailboom, you can also just stuff in moderately flexible foam plugs at intervals.
lincoln is offline Find More Posts by lincoln
Old May 31, 2012, 10:17 PM
numba's Avatar
Joined May 2012
Wow, I must suck at searching threads! Thanks for the great insight.
Question foam safe spray paint. planepainter Thermal 20 Mar 17, 2012 01:09 PM
Discussion What's the best foam sealant? faststick Foamies (Scratchbuilt) 3 Mar 03, 2012 07:25 PM
Question Best spray primer for foam ajreynolds Foamies (Scratchbuilt) 6 Feb 12, 2012 07:09 PM
Discussion Foam, Regular spray paint, no problem... windwalker Painting and Finishing Tips 4 Feb 06, 2012 10:28 AM
Has anyone tried Expanding Foam Sealant? the#1 Foamies (Kits) 7 Jan 07, 2002 03:57 AM
