Old Feb 19, 2012, 04:01 PM
USA, VA, Virginia Beach
Joined Nov 2011
Help!
Paparazzi PPM encoder board build
Hi,
I build the Paparazzi PPM encoder board according to the information on this site: http://paparazzi.enac.fr/wiki/ATmega..._Encoder_Board
The schematics and the firmware that can be found at the bottom of that site are made for an ATmega168. I used the schematics Version 2 (ATmega168 with 16MHz crystal).
To upload the firmware I used this command:
Code:
avrdude -p atmega168 -P USB -c usbasp -U lfuse:w:0b11110111:m -U efuse:w:0b111:m hfuse:w:0b11011001:m -U flash:w:ppm_encoder_v4_3+bootloader_16Mhz.hex
(same as on the mentioned website)
The upload went ok but it seems like the program is not running. The bootloader is not responding, the LED is not coming on and there is no signal on any of the pins.
Any ideas what might be wrong?
Robin
FlyRobin is offline Find More Posts by FlyRobin
Old Feb 20, 2012, 06:33 PM
United Kingdom, Bristol
Joined Aug 2008
did you try this....
SadSack is offline Find More Posts by SadSack
Old Feb 21, 2012, 06:32 PM
Joined Nov 2011
If you mean this:
avrdude -p atmega168 -P <Insert port here> -c <Insert ISP type here> -U lfuse:w:0b00100010:m -U efuse:w:0b111:m -U flash:w:servo2ppm+bootloader.hex
No. Because on the page in my previous post it says:
"Fuse settings shown above may give unpredictable results and strange behaviour, depending on device and crystal."
And another thing is irritating me. A bit further down on the page you mention is this:
...edit the makefile. Find this:
# The below fuse settings are for the 328p
#Low fuse is the same for the mega 328 and mega 168
LOW_FUSE_328 = 0xDF
and replace with:
# The below fuse settings are for the mega168
LOW_FUSE_168 = 0xC2
First: I searched in the makefile but did not find these lines
Second: It says "Low fuse is the same for mega 328 and mega 168" but the following line is different.
I'm using mainly Arduino so this is a bit confusing for me.
Sold FPV Misc stuff (PPM encoder/servo stretcher/HK board camera mrfliboy FPV Equipment (FS/W) 5 Jan 12, 2012 05:51 PM
Sold Quadrino Board & PPM encoder Like new badbill Aircraft - Electric - Multirotor (FS/W) 1 Oct 31, 2011 09:21 PM
Discussion Using a PPM encoder board with the 9C trainer port? AnnihilaT DIY Electronics 12 Apr 07, 2010 03:37 AM
Discussion PPM Encoder Board arminm UAV - Unmanned Aerial Vehicles 0 Aug 12, 2009 01:43 AM
