Old Mar 05, 2003, 09:56 PM
Joined Mar 2003
Herr Mini Sport setup? please help
I am getting ready to build a mini sport and I have a few questions.
I plan on putting alerions on but I am not sure what the best way to go about this is. Should I just add a solid piece of balsa to the trailing edge and tapper it? Any advice would be helpfull.
Now to the more important question, the power system. I was thinking about using an astroflight 010 with a 6x4 prop and 6-8 600 mah cells. I was wondering what power system setup would give me good performance (loop from level flight) and what type of flight times I could expect.
any input on either issue would be gretly appriciated!!!!!!!
thanks, Jason
jrh3574 is offline Find More Posts by jrh3574
Old Mar 10, 2003, 08:56 AM
die fliedermaus's Avatar
Kansas
Joined Jul 2002
Looks like you got no responses.
I have the Herr Rally which is not the same plane as the Sport but I am running an Astro 010, 6x3 folder, in it.
I have flown this plane more than 30 times.
Last time out these were flight times;
6 cell 2/3 AA battery pack 8 minutes
6 cell 2/3 AA battery pack 7 minutes
7 cell sub c battery pack 11 minutes (ton 'o power)
8 cell AAA battery pack 12 minutes
Pros say the 010 likes more cells so you might consider that too.
I can loop from level flight early on, when the battery has lots of snot. The Rally is kind of an 80% scale Skimmer so not great for aerobatics.
You can build ailerons out of solid balsa. Doesn't take a huge aileron movement to turn a plane either. On My Zipper I used monocote for the hinge all the way along the aileron. They only deflect up and down about 3/16" but that is plenty.
Herr kits build great. Have fun!
die fliedermaus is offline Find More Posts by die fliedermaus
Herr Mini Sport from Start to Finish Jim Walker Parkflyers 54 Nov 04, 2002 05:26 PM
Herr Mini-Sport JeffD Parkflyers 3 Oct 23, 2001 09:09 AM
Herr Mini-sport russ6421 Parkflyers 7 Sep 06, 2001 09:14 PM
Herr Mini Sport - Speed 280, Laser Cut Kit hoppy Electric Plane Talk 19 Jul 29, 2001 12:43 PM
Herr Mini Sport info Dauntae Electric Plane Talk 0 Jul 03, 2001 09:38 AM
