Old Aug 08, 2014, 01:45 PM
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
Question
How to/ What SW to make foam "slice" or "tetris" style fuselages on 4 axis hot wire
Folks:
I have a 4 axis hot wire cutter that is in good working shape, set up to do wing panels with Profili and Mach3. Works pretty good.
I am trying to identify what software/ how to go about cutting fuselages and nacelles from a constant sheet thickness of foam so I can stack up the layers and have a fuselage. I see this is a somewhat popular method, but have not seen a thread that really just deals with the how-to of getting this done.
I have downloaded Stefano's DevfusFoam, but I guess if it has the capability to do what I want, it is hard to find that out from the documentation. I would like to find out about any and all foam cutting apps that will do any or all of what I want (see list below)
If someone has done a "build thread" like this, please point me to it.
What I want to do / What SW does this? :
A) Get a 3 view of a plane with cross sections - no problem, I can do this
B) Trace the cross sections and side/top view - I can do this on CAD, but is there a better foam app with integrated tracing?
C) Take those cross sections and using the thickness of foam I plan on using, extrapolate/ interpolate/loft to get profiles at the locations needed - i.e., with 3/4" thick foam - generate a profile set with 3/4" spacing. - I can use CAD to do this, but it seems like this is where a more specific "foam" app should make this easier and more automated. This kind of functionality is what I would find most important in a "foam cutter" app. Does it exist as such?
D) Now with the cross sections the app would do a layout within the cutting area and generate G-code so I can fit the different layers on a piece of foam to be hot-wire cut.
E) This one is kind of a fantasy - a nice to have. If there is an app that does this I would be sold immediately: Instead of making a single cut between profiles, the software analyzes the slope of the mold line at each profile, and cuts to that slope on each face of the foam. - making 2 passes for each layer. THis would be extremely useful and more precise for segments with a convex profile, which most fuselage sections will be.
So that's it. Links, advice, taunting, whatever, is welcome.
bigjohn is offline Find More Posts by bigjohn
Old Aug 08, 2014, 07:11 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I use Sketchup at the moment but have used Inventor to do the same thing.
With inventor it's making the fuselage solid model and ding sections as needed.
Sketchup is more involved, look up D-fast here on RCGroups, he has videos on how to do what you want.
Eric B.
AirX is offline Find More Posts by AirX
Old Aug 08, 2014, 11:14 PM
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
Would you double check that username? D-fast comes up empty...
THanks
Old Aug 08, 2014, 11:24 PM
Denver, CO
Joined Dec 2005
His blog
http://www.rcgroups.com/forums/member.php?u=207312
Roto Rob is offline Find More Posts by Roto Rob
Old Aug 09, 2014, 03:54 AM
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
Devfuzfoam
dpot is online now Find More Posts by dpot
Wanted 4 axis cnc hot wire foam cutter Joel K. Scholz Aircraft - General - Miscellaneous (FS/W) 2 May 23, 2010 12:51 PM
Wanted 4 axis cnc hot wire foam cutter Joel K. Scholz Aircraft - General - Miscellaneous (FS/W) 0 Feb 08, 2010 09:01 PM
For Sale CNC 4 Axis Hot Wire Foam Cutter what the helli Aircraft - General - Miscellaneous (FS/W) 2 Aug 22, 2009 09:20 PM
Discussion how to make hot wire foam cutters Yellow Baron Foamies (Scratchbuilt) 2 Oct 08, 2007 11:28 AM
a 24 inch hot wire setup to cut 1/4 inch foam slices enigmabomb Electric Plane Talk 1 Nov 18, 2003 01:11 AM
