Old Jan 05, 2014, 05:12 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Build Log
Another hacksaw special...
I've decided to use DowCAD to develop this highly sophisticated model. In other words, I freehand sketched it on a scrap of 1" foam with a magic marker!
vtdiy is offline Find More Posts by vtdiy
Old Jan 05, 2014, 05:18 PM
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
DowCAD? I call This hwpCAD (Hand with pen)
ttersu is offline Find More Posts by ttersu
Latest blog entry: My builds
Old Jan 05, 2014, 06:50 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
ttersu, what version do you use? I've only got 1.0, and it's full of bugs!
So, I cut it out, and then cheated on the hollow part -- I spied a coping saw I hadn't used for years hanging on the wall, and thought hmmm, bet that would be good on foam. And it was.
Of course all this could be done with a hot wire, but I'm off those these days. Don't like the smell in the house, and it's too cold outside to move out there. Besides this has to be the simplest model imaginable. So what better to attack with blunt instruments?
Drew a line around a best-guess add on layer shape -- I'll be adding a piece of scrap pink 9mm Owens-Corning fanfold foam both sides.
Old Jan 05, 2014, 08:38 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Marking the cheek pieces out:
Old Jan 05, 2014, 08:41 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Cut them out:
Old Jan 05, 2014, 08:45 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Glue them together with rubber cement -- let dry for 5 minutes before bringing the pieces together:
Old Jan 05, 2014, 08:49 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
After sanding the profile edges smooth, mark out some rough cutting lines to taper the aft portion: and start hacksawing:
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
Cute, but not much wing area :-(
Marty
mbpetri is offline Find More Posts by mbpetri
Old Jan 05, 2014, 08:53 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Sand the tapers with a sanding block. I use 8o grit for this kind of thing:
Old Jan 05, 2014, 09:02 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
About 144 square inches, I'm thinking, Marty....
Mark out rough bevel and cut wth Xacto..
Old Jan 05, 2014, 09:18 PM
Su-27's Rule!
Su-33's Avatar
Philippines, NCR, Pasig City
Joined Nov 2012
Can't wait to see what this turns out to be! subd.
Su-33 is online now Find More Posts by Su-33
Latest blog entry: A cheap way to measure Kv
Old Jan 05, 2014, 09:59 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Hi Su33 -- I bet someone will guess it pretty soon!
Sanded the bevels all around:
Old Jan 05, 2014, 10:00 PM
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Beveled the nose in further:
Old Jan 06, 2014, 01:09 AM
United States, CA, Folsom
Joined Jun 2011
A pusher like this one ? http://www.hobbyking.com/hobbyking/s...h=Dragon%20fly
radhav is offline Find More Posts by radhav
Old Jan 06, 2014, 06:36 AM
ttersu's Avatar
Joined Oct 2013
Lucky you are, I have beta 0.9 one and I'm unable to update
Seriously, what are you planning this time?
For Sale RadioShack HackSaw and Nikko Hummer H2 Spidey2011 Cars - Trucks and Parts (FS/W) 0 Jun 20, 2009 01:34 PM
For Sale Another Katrina DONATION Herr Pitts Special! turbojoe Aircraft - Electric - Airplanes (FS/W) 23 Sep 04, 2005 11:36 PM
Corona Blades + Hacksaw = 2nd Life JIMJAM Electric Heli Talk 3 Jul 01, 2002 11:06 PM
Another Walmart $2.99 special tears up the sky. NewbieX Foamies (Kits) 7 Jun 21, 2001 08:40 PM
