Old Feb 26, 2012, 09:42 PM
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
Build Log
f-22 inditification/ starting restore
start with who made this.. then does anyone have pics of another one setup or manual..plans.. etc.
would like to get to this soon... i need to make elevators and canopy.
thanks
rcshirt is offline Find More Posts by rcshirt
Old Mar 02, 2012, 04:25 AM
SpeedFreak at heart....
molo_30's Avatar
Joined Aug 2006
Whats inditification?
molo_30 is offline Find More Posts by molo_30
Old Mar 02, 2012, 07:21 AM
rcshirt's Avatar
Joined Oct 2007
Really, thats all you have, a mispelling..
Thanks for nothing..
Old Mar 03, 2012, 04:57 AM
molo_30's Avatar
Joined Aug 2006
Ok then, maybe an early Yellow Aircraft F22?
Old Mar 03, 2012, 10:29 AM
United States, FL, North Port
Joined Mar 2004
The YA is all composite.. that one looks to be foam cored wings tail... I can't remember who designed the YA F-22, but it could possibly be one of the very early prototypes from the designer.
Best bet would be to take more photo's of the airframe, as one doesn't help anyone see exactly what you have..
I to was wondering what inditification is?
invertmast is offline Find More Posts by invertmast
Old Mar 04, 2012, 04:55 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
based on the appearance of the main hatch...I would have to say its a Yellow. The hatch is half the size of the FEJ
vettster is offline Find More Posts by vettster
Latest blog entry: 3DTRYER ripped me off!!!
Old Mar 04, 2012, 06:30 PM
rcshirt's Avatar
Joined Oct 2007
thats the closest i can figure. the ducts and formers looked like it was to be d/f not a turbine model.
but all else it too close to YA ...
Old Mar 04, 2012, 06:33 PM
sideshow's Avatar
United States, CA, Pleasanton
Joined Mar 2003
I believe that is the Christian Diffusion kit.
sideshow is offline Find More Posts by sideshow
Old Mar 04, 2012, 08:50 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
contact YA....Or who ever... maybe there is a product # or something embossed somewhere in the jet to confirm. They can tell you where to look
Old Mar 05, 2012, 05:54 PM
Joined Mar 2004
Its definitely NOT a Yellow Aircraft one.
The exhaust nozzle "points" are not the same, the panel lines and small hatch's/openings are missing.
The engine hatch is wrong (the YA one isn't square).
The canopy flange isn't the same.
No flaps, Wrong shape ailerons
Old Apr 12, 2012, 10:27 PM
rcshirt's Avatar
Joined Oct 2007
while its close to a yellow.. i can ask... where is the yellows CG. and i have started to work on it.
Carbon fibered the landing gear plates(mains) and now have the retracts working. i will add the doors after a maiden flight.
the ailerons are hooked up ,rudders,stearing.
will need to do the elevators, getting the diminsons and making some foam cores, etc.
there are bearing blocks in the tail cones and servos. it looks as though it had an external control arm. thinking similar to a avonds f-15 or byron f-16.
will also make a foam canopy shape , then glass. i wil not worry about a clear canopy. just paint it.
Old Apr 15, 2012, 09:24 PM
rcshirt's Avatar
Joined Oct 2007
made a base plae for the cockpit. will open it back up after the canopy is shaped.
also made a wire bow and made the other wing tip that was missing.
have some elevator blanks cut. will cut those soon.
Discussion SO I have the PROEDF F-22 same as hobbyking fiberglass F-22 sherlockshah Electric Ducted Fan Jet Talk 31 Feb 29, 2012 08:00 PM
Question Anybody that knows of a good flying F-35 or F-22 that is 4ch with rudder! skarface Electric Ducted Fan Jet Talk 6 Jan 13, 2012 07:08 PM
For Sale Fly Fly F-22 and F-86 NIB LBJ Aircraft - Electric - Airplanes (FS/W) 0 Apr 11, 2011 07:00 PM
Custom built Depron jets. F-4, F4D, F-5, F14, F-15, F-18, F-22, and more, prop or EDF ram3500-rcu Product Announcements 37 Jan 22, 2009 02:36 PM
Depron drawings: F-16, F-15, F-22, F-18 Ron van Sommeren Foamies (Kits) 1 Nov 09, 2005 04:14 PM
