Old Oct 11, 2004, 05:22 AM
dogjumpjump's Avatar
Hong Kong Intl, Hong Kong
Joined Apr 2004
NEW!! M2000 Electric pushed!!!
Here I modified the kamdax glow fuel version to electric-pusher
Motor: himax 2015-4100kv
Battery: flytosky.net E-power 11.1v 2200mah li-poly(7-8C)
Two servos with Elevtron mixing
Good flying performance, but can do loop, maybe CG is not located good enough
dogjumpjump is offline Find More Posts by dogjumpjump
Old Oct 11, 2004, 07:00 AM
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
sweet looking mirage there dogjumpjump
Frenche is offline Find More Posts by Frenche
Old Oct 11, 2004, 08:48 AM
flanker's Avatar
Lowell, MA
Joined Feb 2004
which prop are you using with 2015. What is the AUW? Can you post build photos and video?
Great looking jet!!!
flanker is offline Find More Posts by flanker
Old Oct 11, 2004, 10:30 AM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Well that doesn't sound like a lot of motor and your prop is barely sticking past the sides of the exhaust! You probably don't have enough power to loop, plus delta wings have a lot of drag at high angles of attack so when you pull up you need a lot of energy to begin with. You don't have much more prop area than you'd have with a ducted fan! Maybe put a gear drive on it to swing a larger prop, but more power might help as well.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Oct 11, 2004, 09:59 PM
Joined Apr 2004
Thanks, I use GWS4025 propeller,
Old Oct 11, 2004, 10:57 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
I'm with ED on this one. It's a delta wing, so it needs a certain amount of power just to get on step. If it seems to fly around with the nose up in the air then you probably dont have enough power. And not too familiar with all the himax but isnt that the really small B-20 type motor size? And isnt that basically a 4x2 prop?
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Oct 15, 2004, 09:14 AM
Joined Apr 2004
yes, it is a B-20 size motor with 4x2 prop, I may change 5x3 to test it
Old Oct 15, 2004, 10:52 AM
Joined Aug 2002
I have a much smaller wattage mirage on a astro 020 and I'm running a prop that size and on slow speeds it wont drop the nose till it gets going. Your motor will be putting out alot less watts so it's probably low on power.
Barry
Old Oct 15, 2004, 10:55 AM
Joined Aug 2002
Oh also my Mirages have about 2 or 3 degrees up thrust, you might want to try this to see if it helps. They also have about 2 degrees uf reflex in the elevons.
Barry
Old Oct 15, 2004, 11:47 AM
Joined Apr 2004
Thanks Barry,
let me modified my plane, hope can do looping!!
Old Oct 15, 2004, 06:36 PM
Permanently Banned
Joined Apr 2003
Folks, Please let me know who is carrying
this Mirage 2000 in US????
maybe www.Towerhobbies.com
rcguy01 is offline Find More Posts by rcguy01
Old Oct 15, 2004, 07:00 PM
Permanently Banned
Joined Apr 2003
Barry
The wattage Mirage 2000 has some wash out at the wing tip.
We may need to add some wash out on this Mirage 2000
to make it fly well. ALso, the power for that little Wattage
Mirage is about 200 watts. This Mirage 2000 seems bigger, heavier
so that "rated 100 watts" 2015-4100 may just barely drag this jet
around in the sky.
Want to make this Mirage 2000 sings? get some good power on it then.
At least as good as the power on the Wattage Mirage 2000 :-)
Old Oct 15, 2004, 08:12 PM
Joined Aug 2002
Yeah I would have gone 2T and 2s for alot of power but light weight, and would go 5x5 for spped or 6x3 foe good speed but with major vertical.
Barry
New HOB Electric J3 Cub kit Bill Germanson Parkflyers 24 Jun 15, 2002 12:54 AM
GWS just finished a new Micro Electric Duct Fan Unit: GWS EDF50 GWS4CEO Electric Ducted Fan Jet Talk 28 May 10, 2002 09:03 AM
New line of electric models and parkflyers arrived. Great prices!!!!! modest-master Aircraft - Electric - Airplanes (FS/W) 13 Nov 12, 2001 04:35 PM
3 new scale electric kits from Sig Airnut 2 Scale Kit/Scratch Built 4 Nov 07, 2001 10:39 AM
How to make the new APC Electric props fit your adapter Joe Elston Electric Plane Talk 6 Jun 17, 2001 01:56 AM
