Old Mar 07, 2014, 12:52 AM
Joined Mar 2014
Can I link one Rx to 2 different transmitters
Hi,
I have 2 radios: Aurora 9x and I recently picked up a used Eclipse 7 Pro (for buddy boxing with my son).
I have a couple of planes setup on 9x (both have Optima 7 rx) and I wanted to test the Eclipse 7 to make sure it works properly. So if I have Optima 7 linked to A9x already and I go ahead and link this same Optima 7 to Eclipse 7 pro, would it keep the link and setting for A9x or it would loose that link? I guess the link should stay.
Also I started reading about setting up the training mode. I want to use A9x as master and E7 as slave. Do I need to setup E7 as independent transmitter to match all settings (trim, dual rates, expos, maybe mixes) with A9x before I start using E7 in slave mode? I still need to get Hitec 58320 cable to connect them.
jellysat524 is offline Find More Posts by jellysat524
Old Mar 07, 2014, 03:56 PM
Joined Aug 2002
Buddy Aurora 9X with Eclipse 7 Pro
Originally Posted by jellysat524 View Post
Hi,
1. No, unfortunately neither the A9X nor the Eclipse 7 Pro have modules.
(The module of an Aurora 9 can be swapped with that of an Optic 6 or Eclipse 7 so user did not have to relink each time.)
2. Yes, please refer to:
. Aurora 9 - Transfer Model Memory from Eclipse 7, Optic 6, Flash 4&5 and others
. Hitec Aurora 9 - Trainer / Buddy system Master & Slave function Set-up. - & Data Transfer A9<>A9 etc.
- Also covers Eclipse 7 Pro & other Hitec RCD transmitters.
ex Hitec USA Support Forum Sticky:
Aurora 9, 9 X AFHSS 2.4Ghz Module, Transceivers Receivers Telemetry
- FAQ, Setups & Tips
See also sub Section "Trainer (Buddy box) cables - DIY " under
"Buddy Boxes, Flight Simulator & Interface." at:
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Alan T.
A.T. is offline Find More Posts by A.T.
Old Mar 08, 2014, 01:28 PM
Joined Mar 2014
Thank you so much.
Speaking of re-linking with A9x and E7Pro, would I loose all settings for a specific saved model if I loose a link to corresponding rx? E.g. if I link to E7Pro and then relink back to A9x would I be able to choose which model this Rx link corresponds to?
Alan T.
Old Mar 08, 2014, 01:46 PM
Joined Aug 2002
Thank you so much.
The settings for each model remain unchanged when swapping receivers, simply re-do the ID-Setup each time.
Range check, as always before first flight of the day, and go fly.
Alan T.
Old Mar 08, 2014, 02:01 PM
Joined Mar 2014
Ok thanks A.T.
If I want to set up A9x as master (which is already programmed for a model) and E7pro as slave, do you I set up E7pro while it is in slave mode via cable or I should set it up independently first and save all settings under a model name and then correct them (if needed) in slave mode?
Also, if I setup a model in slave mode on E7pro from scratch, would I be able to save all settings under specific model name? (I'm planning to use it as slave tx for more than one model). I just don't understand how you would choose a model on E7pro in slave mode since Tx turns on automatically with training cable inserted and doesn't look like you can get into model select menu.
Alan T.
Old Mar 08, 2014, 04:32 PM
Joined Aug 2002
Ok thanks A.T.
Only one model can be flown at a time, no need to access Model Select or Telemetry screens once cable is inserted.
However, should a mistake have been made during initial programming for the selected trainer model,
user can still access programmable features such as Reverse & Trims for that model
Alan T.
Discussion Can you use any 2.4 receiver with one 2.4 transmitter? UAV_PILOT Electric Plane Talk 20 May 01, 2014 12:39 PM
Sold Traxxas TQI transmitter and traxxas link Telemetry 5ch rx - $40 snackdaddy185 Cars - Accessories (FS/W) 1 Nov 20, 2013 12:25 AM
For Sale Traxxas Link TQ 2.4Ghz transmitter & receiver tx/rx combo bflan2001 Cars - Cars and Parts (FS/W) 1 Oct 24, 2012 05:33 PM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Question Can any one tell the different between these 2? Dragonus Electric Heli Talk 4 Sep 09, 2006 09:07 PM
