Old Dec 30, 2012, 10:47 PM
Dragon Link/Labs Engineer
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
Where do you put your ESCs?
So, I am the proud owner of a brand new beautiful hexacopter build based off a SIXcopter from Jakub.
I have the frame almost fully assembled (though with the top off so I can put power distribution in), which means the top thing on my mind right now is wiring the electronics.
The next thing is, where to put the ESCs?
Right now the only decent looking option appears to be loading the ESCs on the top of the plate, surrounding the FCU. I really am not sure if the high freq, high power lines will interfere with the FCU in any noticeable way.
Thoughts? Pictures of other hexacopter ESC placement would also be much appreciated.
chris1seto is offline Find More Posts by chris1seto
Old Dec 31, 2012, 03:49 AM
CDW
CDW's Avatar
Vienna, Austria
Joined Jun 2004
I also have the Jakub frame but with the 16mm CF tubes.
It seems easier for the larger frame 21 or 25 but with the 16, there are not to much space between the plates.I tried many options, above the top plate, between the plates, side ways between, sticking out halfway etc. but yesterday I attached them below the bottom plate.
I am still in the process of installing as my APM etc. positions are not yet fixed. I am waiting for one ESC that was faulty which I had to send back to the UK so can't do anything further for now.
Regards
Chris
CDW is offline Find More Posts by CDW
Old Dec 31, 2012, 04:40 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
This is how I did mine https://picasaweb.google.com/1081737...14520392110098
You can also mount them between each arm across the face of the opening between the plates, there are actually holes in the plates for zip ties to do that. http://www.rcgroups.com/forums/showp...postcount=1641
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 31, 2012, 11:23 AM
United States, CT, Norwalk
Joined Nov 2009
THX Flitelab...
yes this is one of the best places to install ess
peoples is offline Find More Posts by peoples
Site Sponsor
Help! What do you use to put your boat in the water? kevin finn Dock Talk 21 Oct 19, 2012 11:26 PM
Discussion How and what ESC settings do you put on yours? prodriverex Scratchbuilt Multirotors 8 Sep 30, 2012 10:33 PM
Question where do you get your rubber noahapple Free Flight 5 Jun 01, 2012 04:57 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Where Do You Put the C50 Switch on Your Kwik-E kelvin Sport Planes 11 Aug 03, 2002 08:09 AM
