Old Nov 15, 2012, 12:06 PM
BDK74's Avatar
United States, CA, Redondo Beach
Joined Sep 2012
Futaba 8FG crow/flap question
I am currently using an SD-10g on a 4 servo wing. I can't say I am completely happy with the feel and switch layout (porcupine) of the 10. I am looking into the futaba 8FG and have a question on crow/flap/flaperons mixing.
Here is what I have set up on the 10 and would like to emulate it with the 8fg if possible.
Flap on stick.
100% (stick up): flaps/ailerons up
85% - 25% proportional full span flaps (flaps + flaperons)
<25% crow. Flaps down, ailerons up
Can I do it with the 8FG?
Thanks!
BDK74 is offline Find More Posts by BDK74
Old Nov 15, 2012, 03:04 PM
Fit to CFIT
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
I haven't done this but I believe it is very easy using a combination of two tricks:
First, the crow function has a configurable deadband -- you can define the first 25% of stick travel to do nothing.
Second, you can assign camber to whatever switch/lever you want -- in each mode. So for landing mode just put camber on the stick and set the travel to give the range you want in 25% stick.
You'll have camber adding/subtracting to your crow thru the whole range but you can adjust the crow volumes accordingly.
The 8FG does have two major shortcomings with sailplanes that you should be aware of:
- Snap flap cannot be adjusted in flight
- Aileron differential and ail-rud mix cannot be adjusted in flight
vespa is online now Find More Posts by vespa
Old Nov 15, 2012, 03:44 PM
BDK74's Avatar
Joined Sep 2012
It sounds like I may need to get my hands on one to figure out.
I could then program the crow to override the camber of the ailerons?
Are there mixing curves available for crow settings?
Old Nov 15, 2012, 04:08 PM
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
AFAIK there is no mix curves for the crow (butterfly) but free mixers have the curves so you can do that, full span flaps for 25-85% and crow for the last 25%, with the curves. There is only 5 free mixers so I suggest that you use butterfly mixer for the flaps and two free mixers for the ailerons (or one mixer with link - or + option).
Harri Pihl is offline Find More Posts by Harri Pihl
Old Nov 15, 2012, 04:29 PM
BDK74's Avatar
Joined Sep 2012
It looks like it may be possible. I have been looking at the manual. But I know how those things can be. Experimentation is the key I think.
For Sale Futaba 8fg Super and 8fg bbrown2828 Aircraft - General - Radio Equipment (FS/W) 4 Oct 09, 2012 08:21 PM
Help! help with crow flaps and throws. nemoskull Sailplane Talk 1 May 15, 2012 07:54 AM
Discussion Futaba 8FG and flaps rmmoorejr Radios 11 Jan 10, 2012 06:03 PM
Discussion Futaba 8FG and flaps rmmoorejr Sailplane Talk 0 Jan 08, 2012 12:24 PM
Discussion Futaba 12FG Crow Flap Travel ThermalBoy Radios 4 Mar 15, 2010 08:12 AM
