Old Apr 02, 2012, 12:27 PM
United States, OR, Canby
Joined Aug 2011
Question
Where to mount ignition
I'm building a 91 inch wingspan Stinson 108 ARF with a gas engine that has a rear mount Pitts style muffler. I see that some people mount the ignition to the engine mount box, often on the top however I don't have room on the top so it would have to go on the side. My question is would heat be an issue for the ignition in that location or would it be best to mount it inside the airframe?
600Bob is online now Find More Posts by 600Bob
Old Apr 02, 2012, 01:56 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You can mount the ignition model in any attitude that you need to. Upside down, right side up, on either side or vertical too. I probably would ensure it has some airflow and is somewhat protected from the engine heat though, especially the muffler.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Apr 02, 2012, 07:53 PM
Jacksonville Fla.
Joined Mar 2007
I have mounted mine on the side with no problems......just keep it away from the receiver or the antenna
jetmech05 is online now Find More Posts by jetmech05
Old Apr 02, 2012, 08:20 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I have mounted them on the side of the engine box, Under the engine on the mount standoffs, inside the rear of the firewall. All the locations worked out well. Some manuals tell you to mount it where it gets cooling air. Some say that inside the firewall is OK. Some say wrap it in foam, some say mount it with velcro.......... RCxel makes most of the ignition systems in use and they are not too specific so I guess as long as you keep it away from the radio/servo's it is fine to mount it where you can.
Fokker DII is offline Find More Posts by Fokker DII
Old Apr 03, 2012, 12:25 AM
Joined Aug 2011
Well I guess I'll just try a few different places and see what works, maybe I could mount a heat shield below it to keep the muffler heat away. Below the fuel tank might work too. I have another plane that has a very narrow fuselage and space is tight and the ignition and the RX are maybe 6 inches apart, didn't seem to be a problem but only has 2 flights so far.
Old Apr 03, 2012, 04:25 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I had it mounted under the tank on a 60 Pulse. It worked fine there. Seems the only things to avoid, other than keeping it seperated from the rx , are vibration and muffler heat. I do use rfi filters on all my servo wires also.
Old May 28, 2012, 08:31 AM
RC Erik's Avatar
United States, FL, Naples
Joined Oct 2011
Fokker,
Where do you install the RF filter rings on the servos? Where it meets the servo, or where it meets the receiver? Thanks.
RC Erik is offline Find More Posts by RC Erik
Discussion Where to mount retracts rcnats Electric Ducted Fan Jet Talk 4 Mar 27, 2012 01:14 PM
Discussion where to get motor mounting plate chatch15117 Power Systems 1 Jan 25, 2012 11:37 AM
Evo 50, anodised gyro mount and tail mount, where to buy? OICU812 Fuel Heli Talk 1 Nov 20, 2005 06:43 AM
Where did you mount the elevator servo in the Twister Al P High Performance 12 Jan 02, 2002 07:28 AM
V-tail mount parts, where can I buy JoeR Electric Sailplanes 0 Apr 27, 2001 04:29 PM
