Old May 18, 2011, 12:38 PM
HaoleboyRC
HaoleboyRC's Avatar
United States, CA, Auberry
Joined Apr 2009
Module swap in Futaba 8UHS
I tried several different searches but did not find what I want. I have a Futaba 8UHS and it came with a Ch 54 module. I want to put a Ch 25 module in it to be compatible with other flyers at our field. Will changing the module from a Tx with a high band module to a low band module change the range on the Tx? I thought I read somewhere that you should not change from high to low or vise versa. That may have been in documentation on my Futaba 6EX and changing the Tx crystal on that radio. So I am changing the complete module not changing a crystal. Thanks for any help with this swap.
HaoleboyRC
HaoleboyRC is online now Find More Posts by HaoleboyRC
Old May 18, 2011, 12:49 PM
Staffs, UK
Joined Nov 2003
Changing a complete module for one on a different channel will not affect the range.
Anyway the low band/high band thing only applies to certain Futaba receivers NOT to transmitters.
Steve
slipstick is online now Find More Posts by slipstick
Old May 18, 2011, 01:05 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, BC, Vancouver
Joined Sep 2006
Or even better deal, an Hitec Spectra which can do any channel between #11 and #60,and fit the Futaba radios:
http://servocity.com/html/spectra_module__air_.html
http://www.cermark.com/products/SPEC...Hz-MODULE.html
coriolan is offline Find More Posts by coriolan
Old May 18, 2011, 01:16 PM
Champaign
Joined Apr 2003
You can also purchase the Futaba Synthesized module which also allows you the choice of any channel from 11 to 60:
FUTL8910 TP-FSM 10C 9CS 9C SYN MOD
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
service@futaba-rc.com
krysta is offline Find More Posts by krysta
Help! Problem with FrSky V8HT DIY module in Futaba tx RobEm Radios 5 Mar 30, 2011 11:21 PM
Discussion Futaba 7c Module swap out question skaterpeep94 Beginner Training Area (Aircraft-Electric) 3 May 16, 2009 03:40 AM
Hi-tech 555RX Questions/Futaba 8UHS? LJH Radios 2 Nov 04, 2002 08:41 PM
Futaba TX crystal module swap ? johntbyrne Power Systems 6 Jul 22, 2001 06:22 AM
