Old Jul 08, 2004, 03:45 PM
TS250X is offline
Find More Posts by TS250X
Shropshire UK
Joined Jun 2004
Advice on charging TX
I have a Sanwa RD 6000 Super tx with a 9.6 600mah ni-cad batt I have just bourght a 9.6 1600ma NiMh batt,I have read that I can use the standard TX charger to charge it with it says the formula for charging is add 20% to the capacity of the pack so that would be 1920 I think then divide by the charger output which is 75ma=25.6 hours any one know if this is ok or do I need to buy a special charger
TS250X is offline Find More Posts by TS250X
Old Jul 08, 2004, 04:50 PM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
If you don't mind the wait - as long as the voltage is the same - it will charge with your "wall wart" charger.
I personnaly keep a NiCd/NiMH charger around to charge my hi-cap TX pack at a 1c rate. You can get the charger leads on-line or your LHS may have 'em
LTChip is offline Find More Posts by LTChip
Old Jul 08, 2004, 05:18 PM
TS250X is offline
Shropshire UK
Joined Jun 2004
Cheers LTChip will slap um on charge now and then off for some zzzzzzzz
Advice on a 3D TX vrex 3D Fuel Heli Flying 7 Sep 16, 2004 10:37 AM
Question Need advice on getting a crystal for my t6xa Futaba TX Prashanth Radios 2 Dec 26, 2003 04:10 AM
Charging tx batteries sambo Electric Plane Talk 3 Jun 08, 2001 09:52 AM
advice on second e-plane Johan Electric Plane Talk 6 May 11, 2001 02:41 PM
