Old Jul 02, 2015, 03:28 AM
Quax BP is offline
Find More Posts by Quax BP
Joined Jul 2015
Question
UMX Warmliner projekt AS6410NBL problem
Hi, i have been placing the gutts of my E-flite Habu with an 180 BL outrunner
EFL-UM180BLB in a scratch built Hotliner.
Unfortunately motor spins wrong way and turing connection cable from esc to motor 180 degrees gives full funktionality av correckt spinning rotation but leads to overheating cutt off on the brick.
As far as i can see i the brick from the HABU the Eflite DSMX 6Ch AS3X Receiver with BL ESC which is identic to the one used in for example the UMX pitts there in a another orientation and with the motor i am using .
I hope i am asking ntohing which has beeen diskussed a thousand times before but i couldn\t get a ansver by searching. Wrote to Horizon hobby but havnt got a ansver yet.
Appriciate help Regards
Quax BP is offline Find More Posts by Quax BP
Old Jul 02, 2015, 06:33 AM
Quax BP is offline
Joined Jul 2015
Kan add that i have been using 2 bricks of same type. Same result.
Old Jul 03, 2015, 12:59 AM
Quax BP is offline
Joined Jul 2015
Update: Horizon Hobby Germany hasn't heard about the problem !?
Old Jul 03, 2015, 03:45 AM
Mile High Micro is offline
Find More Posts by Mile High Micro
Joined Jul 2015
Can you hook the brick up to a different motor? If you power up the brick without a motor attached what does it do? Have you tried different batteries? Are the batteries fully charged?
What does the brick do when it is in this condition? Doe it do this with or without a prop on the motor? When the fault occurs, are you spinning the motor or does it do this with throttle set to 0?
Mile High Micro is offline Find More Posts by Mile High Micro
Old Jul 03, 2015, 05:57 AM
Quax BP is offline
Joined Jul 2015
Really appreciate your reply - getting slightly mad about this problem as modell i otherwise flies extremly well.
-This i think is done so far as the brick was taken out of at elktrically working but otherwise damaged HABU
- I have full kontroll over all channels. There is no malfunktion cutoff or whats or ever fail
Have you tried different batteries? Yes i did.
Are the batteries fully charged? I thougt.
Going to check this again !
What does the brick do when it is in this condition? Doe it do this with or without a prop on the motor? When the fault occurs, are you spinning the motor or does it do this with throttle set to 0?[/QUOTE]
Whole brick shuts down most likely due to overheating cut off as it is so hot that you hardly kan touch it. After a minutt or so it coms back and binds again to the radio with no current to motor. Waiting lit longer and motor i working. Looks like shut of comes earlier the more throttle you apply. Prop is used in a Gee Bee UMX with same motor (same brick?) and shout work without drawing to much Amp.
Most irritationg is that this problem only occurs if you have turned connection cable esc(or brick) to motor 180 degrees as suggested in order to reverese spinning direktion. Turned right way (Prop spinning wrong direktion) no problem
Old Jul 03, 2015, 09:22 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Sounds like you're getting a bad connection turning the connector 180 degrees.(Not made to do this=resistance?)
Try switching any 2 of the 3 wires in the connector itself. You will see 3 little holes in the connector, push the little pin down and pull out the wire. Before reinstalling the wire in a different spot you might have to pry that little pin back up so the wire stays in the connector.
I R Irv is offline Find More Posts by I R Irv
Old Jul 03, 2015, 08:23 PM
Joined Jul 2015
I was wondering if you could try it with another motor because if it can spin the second motor, in the right direction, without a problem, then the issue is probably with the first motor or the connector on the motor as I R Irv has pointed out.
Old Jul 04, 2015, 06:03 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Isn't the motor used in the edf a much higher kV than used in the prop planes? The bl180s used in the various prop planes have a kV between 2000 & 2500. I think the motor in the Habu has a kV of about 11000!
Never mind I just zoomed in on your picture and see you have the out runner version.
Petefoss is offline Find More Posts by Petefoss
Old Jul 04, 2015, 07:04 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
It's possible that the speed control on the Habu board doesn't like a low kV motor. That said I'm running a edf on the original Sbach board with no issue at all. But I have seen controllers that could not be timed for low kV motors.
Old Jul 04, 2015, 11:25 AM
Quax BP is offline
Joined Jul 2015
Thanks a lot for your replies. Taking fokus from the brick to the connection and motor helped a lot. Actually the spinning rotation issue turned out to be a motorproblem. As the brick was doing fine with the original motor i tried annother motor which i took from my pitts and this worked fra better.
I havn´t solved the issue totally as the brick is getting very hot as soon as you power up the brick. But as long as you get this thing in the air the cooling from the wind keeps temperture low enough to keep the brick going.
Finally a couple of flights have been done and i could not be happier. First flight after the fix was very good , needed minor adjustments. Then I found out that I under all this motor changing i mounted prop wrong way. Next fly left me speachless. Very fast very manuverable unlimited vertikal climb.
I posted a short video. Not sure if this shows good enough how good this thing flies.
If you like take a look.
The Specialist - UMX Hotliner - AS6410NBL RX (2 min 44 sec)
Old Jul 07, 2015, 01:02 AM
Joined Jul 2015
Awesome! That little plane flies like a bullet!
Discussion DIY projekter - Projekter udviklet af Dennis SpookiePower DK FPV 284 Feb 02, 2016 08:24 AM
Discussion My Umx sbach is having problems. FutureGuy007 3D Foamies 0 Jun 22, 2015 05:21 AM
Build Log German hydrofoil build PROJEKT 81.2 CaptDH Scale Boats 8 Nov 24, 2014 05:42 PM
Build Log A minor projekt.... Brushy Racing Boats - Electric 24 Dec 02, 2013 01:22 PM
For Sale UMX AS6410NBL SPMSA2030L MIG EDF Plus 3 Batteries $45 Shipped typhoonmaster Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Aug 30, 2013 10:30 AM
