Old Oct 24, 2014, 04:24 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Build Log
Hobby King Cessna 182 balsa kit
First things first. This kit is not really for a first timer or begainner. I bought the kit from HK. It arrived very fast. The laser cut parts are done really well. Usually you have to cut out a lot of the parts yourself. The main problem with this kit is the building plans. You get none. It does come with a photo layout of sorts and a main wing plan that is not to scale. That being said. Very nice kit. I will try to post my progress as I go.
Tom
http://www.hobbyking.com/hobbyking/s...arehouse_.html
carr52 is offline Find More Posts by carr52
Old Oct 24, 2014, 04:38 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I started by separating all the parts. They are numbered fairly well. F parts are fuselage. X parts are motor mount. The battery tray and servo mount are also F parts. Make sure you and your parts around the windows before you glue the pladtic in. I sand just about everything Prior to glue. I hope this is a help to someone.
Tom
Old Oct 24, 2014, 05:26 PM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
Subscribed. Mine should be here next week. Thanks for being the Guinea pig on this kit with no documentation!
Joe
turbojoe is offline Find More Posts by turbojoe
Old Oct 24, 2014, 05:35 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I stopped building so I could try to take a few more pictures before they get covered up. I'll also try to number them the best I can.
Tom
Old Oct 24, 2014, 05:40 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
subscribed
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Oct 24, 2014, 06:13 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Quick pic of how these two fit. Motor mount and cowl.
Old Oct 24, 2014, 07:44 PM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
HK is selling Zeke's "Wisp" series of kits and I thought maybe this 182 was his as well. I went to his site and looked at the C-182 manual. Not even close.....
Joe
Old Oct 24, 2014, 10:29 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Finished gluing the fuse together. I'll try to get some better pics tomorrow.
Tom
Old Oct 24, 2014, 10:59 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Building over cork - good call!
Old Oct 25, 2014, 07:55 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I like what I see.
Can you provide a link to this kit ?
TomCrump is online now Find More Posts by TomCrump
Old Oct 25, 2014, 09:06 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Originally Posted by TomCrump View Post
I like what I see.
I put the link back in the first post. This kit is listed in the USA Warehouse only, under Laser cut kits.
Old Oct 25, 2014, 09:26 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
The cork is 12"x12" tiles I found at Lowes. Used for bulletin boards.
Tom
Old Oct 25, 2014, 11:03 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Mystery pieces. It looks like part F 7.5 comes up through the bottom of F6 so it needs to be glued in before F6. The picture/plans are not real clear. I'm not cutting F6 out so I'll just have to deal with it. It appears to be alignment tabs for the wing. No idea where parts 7, 8, & 9 go but work progresses.
Tom
Old Oct 25, 2014, 12:25 PM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
In looking at the poor quality picture from the HK site it looks like those F7-F9 parts go in the center leading edge of the wing. Have you been able to figure out how the wing is attached yet? I don't see any dowel holes for rubber band or anything to suggest it's a bolt on either. Mine will definitely be bolt on. Looking forward to your wing build as it's just begging for flaps and mine will probably get them.
I don't see any windows/windshield in the HK or your pictures. Does it come with anything?
Joe
Old Oct 25, 2014, 01:03 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Looks like the wing is screwed down to part F6 and F18. The kit comes with all the window plastic and hardware. Even control rods and tubing. In my opinion this is a very good quality kit. The laser cut out is first rate.
Tom
Update: I'm putting all the build pictures in my blog also.
Started a little of the ribbing.
Discussion Hobby King Telamon Electric Sailplane Balsa Composite 1768mm (PNF) YFZ450MANNY Electric Sailplanes 24 Mar 09, 2016 04:50 PM
Build Log Top Flite Cessna 182 balsa kit build erie_flyer Balsa Builders 60 Jun 18, 2015 10:37 AM
Sold Top Flight Cessna 182 kit FREE SHIPPING| AMJ San Antoni Aircraft - Fuel - Airplanes (FS/W) 4 Oct 17, 2014 10:41 PM
Wanted Projet Cessna 182 Preferably NIB or similar kit Bombogenesis Aircraft - Fuel - Airplanes (FS/W) 4 Oct 14, 2014 06:54 PM
