Old Aug 24, 2014, 07:29 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Question
Flight sim for a 5 year old
Ben, my 5 yo grandson, is fascinated by air craft.
Are there any simple, easy to use, sims that he might be able to use?
I seem to remember a free sim (FS...perhaps?) that I downloaded from the web, used a regular 4 ch. FM radio for control. I did have to buy a cable that plugged into the trainer port on the back of the radio, the other end was a USB connection to the PC. Still have the cable but my current PC runs on WINDOWS 7
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Aug 24, 2014, 01:40 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
You're probably thinking of FMS which is more than slightly out of date these days and can be tricky to get running on modern PCs.
A better bet is RCDeskPilot http://rcdeskpilot.com/ which will use the same cable and TX but is better looking, simple to use and easier to get running on Windows 7. There are a few others but I'd start there.
Steve
slipstick is online now Find More Posts by slipstick
Old Aug 24, 2014, 09:04 PM
Joined Sep 2000
Slipstick,
Thank you for the link.
You are correct when you said this is better looking than the FMS sim.
I've downloaded the sim but can only "fly" the model using the numeric key pad. So far I have been unable to get my Futaba T6XA 6 ch 72 MHz radio to work. Obviously I would want Ben to use the same radio with the sim as he would with a real model
Any ideas on that? I'll contact the authors and see what they advise.
Thank you again.
Old Aug 25, 2014, 02:50 AM
Staffs, UK
Joined Nov 2003
The TX needs to have a battery in, be fully charged and switched on. It's also a good idea to remove the crystal which will prevent it from transmitting RF and makes the battery last a lot longer.
Is the USB cable recognised by the PC when you plug it in ? It's worth calibrating it in Windows/Control Panel/Game Controllers (under Devices and Printers). You should see a controller called "PPM" or something similar and the TX should work it. You also need to calibrate in RCDeskPilot using Menu/Controls, choose the controller (PPM again) and set the channels correctly.
Steve
Old Aug 26, 2014, 07:53 AM
Joined Sep 2000
Steve,
No joy on this. I get a message saying the device is not recognized.
The same radio and adaptor cable worked with Windows XP and FMS.
Maybe the thing for me to do is buy a "trainer cord" and connect my two Futaba radios. Then just take an old foamy I have lying around and let Ben try his luck with that.
I'm guessing the crystal should be removed from the slave radio. Any advise on flying this way?
Old Aug 26, 2014, 10:53 AM
Staffs, UK
Joined Nov 2003
When do you get that message ? I've never known a USB cable that won't work on Windows 7 if it has ever worked...but I suppose you may have the first.
But there's nothing wrong with getting out in the open air and trying some real flying with a trainer cord. Yes you can take the crystal out of the slave. The only trick I've found to flying that way it to try to keep an eye where the throttle is on the slave so you don't get a huge change when you have to take over (which with a 5-year old could be any time, generally their attention span isn't very long ).
Steve
Old Aug 28, 2014, 10:13 AM
Joined Sep 2000
Part of the problem was the USB ports on the front of the PC are a bit dodgey, sometimes working, other times not.
Using a USB port on the back of the PC did the trick. The PC found a driver and now says the device is working. But the device does not show up on the screen which shows the DVD drive, flash drives, etc.
Also, the flight sim in the control settings/controller does not show the radio either.
Could it be due to the age difference between the radio (10+ years) and the flight sim?
Old Aug 28, 2014, 11:26 AM
Staffs, UK
Joined Nov 2003
The USB controller isn't supposed to show up in the File Explorer where the hard drives, DVD drives etc. are because that only shows storage devices.
It should show up in Control Panel/Game Controllers as I said earlier (click on the Start button and enter Game Controller in the "Search programs...." box and select "Set up USB Game Controllers") . Both in there and in the sim you should see something called "PPM". You won't see anything happening until the TX is plugged in and switched on.
Any problem is unlikely to be age because RC Desk Pilot is fine with my USB interface and a Futaba Skysport 6 and JR Max 66, both of which are about 20 years old .
Steve
Old Aug 29, 2014, 10:46 AM
Joined Sep 2000
Steve,
The "installed game controller" field just has the word "controller" in it, nothing else and no options.
When I click on "advanced", the "preferred device" field indicates "none". No other options available.
From "control panel/devices and printers" I see a "MHW USB" controller. When I right click on the icon I get
Game controller settings
Create shortcut
Trouble shoot
Properties
"Game controller settings" same as above
"Properties" takes me through a series of steps, one of which indicates the device is working properly. Other steps identify the driver version, etc., etc
"Trouble shoot" says "can't identify problem" and finally suggests I contact "Steve" in the UK.
Old Aug 29, 2014, 11:12 AM
Staffs, UK
Joined Nov 2003
Larry, I think you've now defeated me. I've never seen a USB controller called MHW anything or one that doesn't show up in the Game Controller list and I've run out of ideas. Sorry for wasting your time.
Steve
Old Aug 30, 2014, 07:43 AM
Joined Sep 2000
Steve,
I don't think you wasted any of my time. If anyone is guilty of wasting another's time, it was me wasting yours.
I do thank you for all your assistance.
Kind regards
Old Sep 09, 2014, 07:20 AM
Joined Sep 2000
After an unsuccessful attempt at getting the RCDeskpilot sim to work with anything other than the numerical keypad and having my questions to them unanswered, I uninstalled the sim.
Still wanting a flight sim for 5 yo Ben, I downloaded the FMS sim to an old PC that is running Windows XP. Still no joy using a Futaba transmitter but it does work very well with an old joy stick type controller.
As it turns out, using the joy stick is far more intuitive than the transmitter is as Ben immediately understood how to use it.
I do limit him to only 15 minutes on the sim and then it's on to other activities.
Old Sep 10, 2014, 09:53 AM
Mr Rowl is offline
Find More Posts by Mr Rowl
Mr Rowl's Avatar
United Kingdom, England, Oxford
Joined Jul 2002
You can also try PicaSim. It should work with the transmitter and joystick under Windows, and also under Android/iOS if you've got a smart phone/tablet...
It's more glider-orientated, which may or may not be a good thing!
Mr Rowl is offline Find More Posts by Mr Rowl
Sold Phoenix Flight Sim v4 (upgrades to version 5) $OLD shipped, paypal justplainold Aircraft - General - Miscellaneous (FS/W) 1 May 16, 2014 04:44 PM
Question Suggestions for a newbie , and 5 year old son. Seabass80 Off-road Cars 5 Apr 22, 2014 09:54 AM
Question Anything for a 5 year old? zires Micro Ready-to-Fly 16 Jan 19, 2014 07:19 AM
Wanted Real Flight Simulator - need a basic setup for my 5 year old son joshuajcrouch Aircraft - General - Miscellaneous (FS/W) 1 Sep 03, 2013 08:58 PM
Help! 83 Year Old New Pilot - Needs Flight Sim GeorgiaBoy Beginner Training Area (Fuel) 2 Sep 07, 2006 10:30 AM
