Old Jan 04, 2013, 12:26 PM
turko is offline
Find More Posts by turko
Canada, BC, New Westminster
Joined Oct 2009
heli louder
I'v installed a KDS 3800kv motor in my blade 450 3d,and i'v noticed that it is quite a bit louder than with the stock motor,Everything seems normal as in the main gear mesh and I was warned that the motor is more powerful than the stock one.Could this explain the difference in sound?
turko is offline Find More Posts by turko
Old Jan 04, 2013, 12:41 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
I'm thinking it could just be louder because it has more power, just double check the gear mesh to make sure..I've come to find out that you should be able to move the main gear just barely, without the pinion moving at all..If you can't move it a tit, chances are it is too tight.
ASTREA1 is offline Find More Posts by ASTREA1
Old Jan 04, 2013, 06:53 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Noise usually comes from more rpm, poor gear mesh, smaller pinions, and motor balance issues.
Roto Rob is online now Find More Posts by Roto Rob
Discussion Making a plane locater "beeper" louder? richg99 DIY Electronics 19 Aug 23, 2009 10:34 AM
Discussion DX6i louder pudd Mini Helis 1 Sep 19, 2008 03:31 PM
Discussion What causes ESCs to be louder than usual? ziomatrixacs Power Systems 6 Jul 05, 2008 10:50 AM
Discussion "Scale speed" - actions louder than words Work in Progress Scale Kit/Scratch Built 23 Jan 08, 2008 10:28 AM
faster stronger louder harder GehhtoFlyer Micro Helis 4 Mar 28, 2005 05:17 PM
