Old Jul 25, 2012, 07:05 PM
Silvertone is offline
Find More Posts by Silvertone
Joined Jul 2012
Found old plane. What is it?
Hello all! Got this old model airplane with gasoline engine. Engine is marked "K&B" and "Made In USA". Plane itself has no markings. Plane is 4 feet long with 48" wing length. I'm sure it needs repairs of some sort, though I don't know anything about these things. Just curious to know what this thing is, how old it is, and its approximate value. See pics and please let me know what I got here.
Silvertone is offline Find More Posts by Silvertone
Old Jul 25, 2012, 07:51 PM
Broken Wings is online now
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
I think it was called a Kombat Airmadillo...
http://kombat40.50megs.com/
Broken Wings is online now Find More Posts by Broken Wings
Old Jul 25, 2012, 08:16 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I gave an Airmadillo away a couple years ago. That's what they are worth.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jul 25, 2012, 08:47 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
They fly pretty good, (depends on who you talk to about that though), I still have two of them that I still fly, especially when the flying field is crowded. No one messes with you in the air with them. They do well on windy days as there is less side area to have them turn into the wind on you. They are also, just about indestructable too. I had a wing bolt break on the twin Airmadillo and it twisted the wing rendering the ailerons almost useless, I almost make it back to land but it stalled and went in hard nose first. I straightened out the fuse and had it flying again in no time at all. The twin also had a couple of mid airs before and it ate the other planes and didn't even break a prop either. The single engine plane went in hard on take off when I screwed up and had the airlerons hooked up in reverse. It broke the needle valve off on the engine, but once I fixed that, the plane was ready to fly again.
Now the wing loading is higher and if you come in dead stick you need to come in faster as they tend to lose lift without the engine running.
earlwb is offline Find More Posts by earlwb
Old Jul 25, 2012, 08:51 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I took some pics of the layout for the servos and stuff. You use a fuel tank with the top cut off to stuff the RX and battery pack into.
The velcro strap is just there to keep the aileron pushrods together until I bolt on the wing.
The front two servos are the throttle and ailerons. The rear two servos are the rudder and elevator.
Each pair of servos is stuck together using double sided sticky foam tape. You then use a little sticky tape on them so they don't directly touch the metal frame, and use cable ties to mount the servos into the fuselage.
Old Jul 25, 2012, 09:01 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Oh yeah, it is not a gasoline engine but a glow engine. But it looks like you have a old beat up and abused K&B Sportster .45 glow engine on the front of the plane. Fortunately, if you are lucky, the insides are still OK, as it is a bushed crankshaft engine and doesn't have ball bearings to go bad. So it might be useable. But its hard to tell for sure from the pics. Someone appears to have used J&B Weld Epoxy or Bondo to affix a old OS muffler to the engine. I would leave the muffler attached and not disturb it, otherwise you will have to do something about reattaching or replacing the muffler then. Oil up the engine with light oil, say WD-40 or something, and if it is stuck, applu hear to it too. You can remove the engine, and pull the backplate off to help get oil inside and maybe the head too. Oil up the rusted crank end too. The front rusted threaded part of the crankshaft can be replaced with a new one from MECOA if you need to. There is a thin steel washer called a prop driver shim that is right behind the prop driver and it looks rusted too.
https://shop.mecoa.com/shopdisplayproducts.asp?id=159
Old Jul 25, 2012, 10:37 PM
dragonsm is offline
Find More Posts by dragonsm
United States, SD, Sioux Falls
Joined Jun 2011
Now that is a neat plane! I'd pick one of those up in a second if they were still available. It'd probably get some of the older members out at the field talking and rolling their eyes.
Reminds me of a little version of the "crutch" plane a friend of mine built out of an actual pair of aluminum crutches. Long and big but was always the talk of the field at any fun fly.
dragonsm is offline Find More Posts by dragonsm
Old Jul 26, 2012, 06:15 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah I hated it when their factory got blown away with Hurricane Katrina several years ago. They never restarted after that. I wanted to get the Big Kruiser or Big Mama and also the Kombat Kopter too. But they were out of business by then. Always my luck with things like this.
Old Jul 26, 2012, 12:19 PM
Gray Beard is offline
Find More Posts by Gray Beard
Joined May 2012
And in the condition the OP is showing, it is worth about the price of the post!
Most profile planes have very little resale value, even nice ones like the fun 51s unless they have a good engine and servos installed.
Gray Beard is offline Find More Posts by Gray Beard
Old Jul 26, 2012, 01:01 PM
Joined Jul 2012
Thank you, guys!
Yeah, I didn't think it was worth a fortune, but at least I now know what it is. Just put it up on Craigslist. Maybe some of you guys who fly these things at Floyd Bennett Field here in Brooklyn can use it for parts or whatever.
http://newyork.craigslist.org/brk/tag/3146198826.html
Thanks again!
Old Jul 26, 2012, 02:12 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Like that twin earl looks like the surfaces are corrugated stuff ? I remember a trainer kit at TAM's that was entirely made of that material, all in American colours, wished I had bought it, the entire plane just like folded together. If there's one for sale I'll gladly buy it. Man you do have quite a fleet !
Reginald is offline Find More Posts by Reginald
Old Jul 26, 2012, 06:31 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
You talking about this thing? If so, don't get too stuck on wishing you had one... I flew one years ago and it was an absolute pig. Yes it was durable, but it weighed almost 7 lbs and it was only a .40!
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jul 26, 2012, 07:56 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Caution
The link in post #2 triggered my virus software saying a trojan had been detected.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jul 27, 2012, 06:54 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes it is that corrugated plastic like stuff that looks similar to corrugated cardboard. They call it corroplast here. US Aircore used to make and sell airplane kits using corroplast. The Airplane factory used the more thick coroplast and US Aircore used the more thin sheets. Their trainer planes were quite popular at the time as they were extremely tough, which is great for beginners learning to fly. I still have a US Aircore low wing .40 size plane kit I haven't built up yet. Red, white and blue where the colors they used in the plane kits too.
Old Jul 27, 2012, 01:31 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I don't remember them being that way. I helped several people learn to fly and solo their planes with those US Aircore trainers. But it had been quite a while maybe my memory is faulty.
Question Found big old incomplete model. I wanna fly it! DefiniteDamage Vintage & Old-Timer Designs 18 Aug 24, 2012 11:04 AM
Discussion Another old warplane found dll932 Life, The Universe, and Politics 8 May 14, 2012 06:38 PM
Found some 10 year old 15% Nitro fuel. What should I do with it? Starguard Fuel Plane Talk 21 Oct 10, 2009 02:56 AM
Discussion Old Planes found mustang mark The Builders Workshop 22 Mar 04, 2009 11:35 AM
Discussion Old model plane found in attic.... jwlael Control Line 13 Oct 30, 2006 10:26 PM
