Old May 24, 2012, 08:42 PM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
will my fatshark BASE with Head Tracker cause UHF interference?
I just picked up a pair of fatshark base goggles with the wireless head tracker and I was wondering if the head tracker will cause interference with my Dragonlink system?
imdone is offline Find More Posts by imdone
Old May 24, 2012, 09:24 PM
fatshark is offline
Find More Posts by fatshark
fatshark's Avatar
Shenzhen, China
Joined May 2007
I haven't tested with DragonLink, but it works fine with ezUHF. The 433Mhz link in the headset isn't FHSS so the DL should just hop around it. The output power of the TX is less than 3dBm. You also don't need to use the antenna on the headset to link to the dongle for less than 3m range which will cut the power down to 0dBm (I recommend not using the antenna if not needed for best HT performance).
Fat Shark
fatshark is offline Find More Posts by fatshark
Old May 25, 2012, 12:09 AM
imdone is offline
imdone's Avatar
Joined May 2011
is there any way to disable the head tracker?
Old May 25, 2012, 12:18 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
There is also a rx modual that can be removed so you use coax from video rx
I used mine for long time before removal and found no difference in video
There was one legit post saying he found UHF to effect fats hark goggles but I found them to be clean video with UHF
As with old range video googles needed ferites to get UHF lines or interference from video
So look for video quality ie interference from UHF effecting video,as well as your orrigional question concern
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Wanted Trade my Fatshark Base for your Dominators turbodriven FPV Equipment (FS/W) 0 May 04, 2012 12:14 PM
For Sale New Head Tracker for Fatshark Dominator sharonx FPV Equipment (FS/W) 0 Mar 27, 2012 08:42 PM
Question Problem with Fatshark Dominator Head Tracker and Robbe/Futaba FX-30 MrBean FPV Talk 2 Dec 13, 2011 05:35 PM
Question Fat shark base with W/L Head tracker..Where can I get it ?? khaled_abobakr FPV Talk 2 Jul 11, 2011 10:25 AM
Discussion Fat Shark Base Goggles with Integrated Wireless Head Tracker??? ftherrmann FPV Talk 8 Jul 06, 2011 02:50 PM
