Old May 18, 2011, 10:13 AM
relax1 is offline
Find More Posts by relax1
Tampa , FL
Joined Sep 2003
Futaba 14MZ programming help
Iím helping a friend with a 14MZ setup and been able to figure most of it. Itís an aircraft set up with dual ailerons. The area im having problems with is setting triple rates to three individual switches. I can do triple to ailerons and elevator on separate switches. Now I need to set triple to the rudder on another switch. I only see six assignable functions under D/R so im short by three. I tried finding programming videos out there but they are all basic not covering what I need to do. Any videos out there that would show me?
Another problem im having is the radio transmitting without giving you an option.. On some models that are bound it asks if you want to transmit and others it bypass it. Is there an option that can be set for it? I ask some folks and said this should not be happening that there is something wrong with the TX.
Thanks for the help
Luis
relax1 is offline Find More Posts by relax1
Old May 18, 2011, 11:25 AM
paracanary is offline
Find More Posts by paracanary
paracanary's Avatar
La Habra, California
Joined May 2004
Instead of using the rate function try using conditions with the group function on everything except for AFR (D/R). You have 8 conditions which should be enough.
The second part of your question is a very useful feature. The first condition 1 (default) determines if the transmitter transmits or if you get the question Warning non default condition. To transmit without this warning, the switch on positions have to match condition 1 (default). For example, this prevents transmitting with the retracts in the up position or in anything but takeoff configuration.
paracanary is offline Find More Posts by paracanary
Discussion Futaba T12FG programming help needed. Ryderboy Radios 30 Mar 02, 2015 10:54 AM
Sold I have a 14mz looking for trade and money for 10c 2.4 futaba sherlockshah Aircraft - General - Radio Equipment (FS/W) 7 Apr 01, 2011 12:16 AM
Mini-HowTo Programming Futaba 14MZ for Full-House Sailplanes fnnwizard Sailplane Talk 28 Dec 15, 2010 04:19 PM
Help! Need help programming 14mz with my trex. timphan84 Mini Helis 34 Dec 07, 2006 05:33 PM
