Old Feb 09, 2006, 04:40 AM
algiecrook is offline
Find More Posts by algiecrook
algiecrook's Avatar
Chorley Lancs UK
Joined Nov 2005
Question
Right Angle gearboxes
Hi All ...... I spent nearly all day looking for some right angle gearboxes which could be used to produce scratch Z Drives and bow thrusters since the ready made jobs are a bit expensive and not to the scale I require, and since 6 are required Im a bit unhappy to pay the going price.
Hope some one can come up with a website which covers the smaller items.................Regards Alan
algiecrook is offline Find More Posts by algiecrook
Last edited by algiecrook; Feb 09, 2006 at 04:46 AM. Reason: Title Requires Bolder Print
Old Feb 09, 2006, 06:49 AM
jeno is offline
Find More Posts by jeno
United States, ME, Bar Harbor
Joined Sep 2005
Tamiya makes right angle boxes. www.tamiya.com
jeno is offline Find More Posts by jeno
Old Feb 09, 2006, 08:27 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Not much out there good for small bow thrusters, at least not that will save you any $$ over the commercial offerings. You'll want between 1:1 and 3:1 reduction at most, but if the reduction is in the bevel gear, you'll have a big gear blocking the water flow... so best to have 1:1 in the right angle bit. I've been eyeballing dental prophy heads:
http://www.rcgroups.com/forums/showp...44&postcount=3
But haven't gotten around to converting one yet. Would only be good for very small models, maybe 1/2" or 3/4" propeller.
For a Z drive, the configuration is so special I can't imagine building one without a small machine shop and some special gears ($$$), will be hard to beat the cost of the commercial offerings. Good luck!
Pat Matthews
patmat2350 is offline Find More Posts by patmat2350
Old Feb 09, 2006, 09:13 AM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
If you are really 'hard up' for gearing, try here;
www.hpcgears.com
I'm serious about the 'hard up' thing! They have, or can make anything you want. The question is then if you think it's going to be worth the cost (the exchange rate too since the place is in the UK).
- 'Doc
(ask for a catalog, they really will send one.)
LtDoc is offline Find More Posts by LtDoc
Old Feb 09, 2006, 10:33 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Ah, but he is in th UK!
For those on this side of the pond, it's easier shopping at https://sdp-si.com/eStore/ , though they may want to make 10,000 of any 'custom' item.
Pat M
Old Feb 09, 2006, 11:38 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
.... since the ready made jobs are a bit expensive...
There in lies the difficulty, Often the gears and bearings alone can run you right up to the retail costs. Two sets of Bevels could cost $50 US, However there is nothing that compares to building a custom drive and showing it off at the pond.
In the states, these two companies can supply a lot of parts you may need.
They aren't cheap though.
http://www.smallparts.com/
http://www.smallparts.com/products/descriptions/gbb.cfm
http://www.wmberg.com/
http://www.wmberg.com/prgears.html
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Feb 09, 2006, 01:41 PM
algiecrook's Avatar
Chorley Lancs UK
Joined Nov 2005
Hi All........ Well Food for thought !!! . It seems Im going to have to do more research, I have been in contact with HPC and am waiting for a result but im not hopeful My problem is that the majority of the commercially available are out of scale for me though I wouldnt consider that a serious deviation from the drawings Thank you all for your input and i will go through all the websites you have listed tomorrow ,I too have also looked at the dental side Pat there wouldnt be much of a problem with Revs since I dont intend to be sailing at more than midrange due to the nature of the ship Any one interested I will post a pic of the model Im copying or if you go to Model Boat Mayhem and look in the gallery at CSO Seawell you'll get an Idea of what Im up against....... Many thanks to you all for your help (Watch this space) Best Regards ........Alan
I will at some stage be posting my progress as soon as I have something to show for it
Old Feb 09, 2006, 02:27 PM
ScottOram is offline
Find More Posts by ScottOram
AME2(AW) Scott D. Oram, USN
San Diego, California
Joined Aug 2005
Try Hobby Engineering. These guys have great stuff...
http://www.hobbyengineering.com/SectionM.html
ScottOram is offline Find More Posts by ScottOram
Old Feb 09, 2006, 03:08 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Don't know the size of the boat you are working on, but here is a link about a Graupner bow thruster assembly for about $36.00 U.S., which could be less than it would cost for a set of bevel gears.
http://www.mhsd.org/model/moonlightbt.htm
Another thought is that you might try an electric toothbrush for the shaft-to-rotary brush mechanism.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Feb 09, 2006, 03:20 PM
algiecrook's Avatar
Chorley Lancs UK
Joined Nov 2005
Hobby Engineering Looks ok Will check them out tomorrow .Pete great idea Great minds think alike how does an electric toothbrush work any idea, I dont have teeth myself so ive never used one Lol. Time to go to Howstuffworks I think.....Alan
PS the Graupner bow thruster Too small Dia tubes and the propulsion is by impeller again scale becomes a problem.......
Old Feb 09, 2006, 03:29 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
From the dental side of things, the disposable prophy angles are made of plastic and won't hold up. On the other hand the metal ones will or try contra-angles or latch angles. The metal prophy angles have a threaded part that the rubber prophy cup threads into. Contra/latch angles have a thru-hole chuck that a burr shaft will fit into.
green-boat is offline Find More Posts by green-boat
Old Feb 09, 2006, 03:42 PM
algiecrook's Avatar
Chorley Lancs UK
Joined Nov 2005
So I can rule out that avenue since a Dentists drill would be costly
Old Feb 09, 2006, 04:09 PM
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I wouldn't rule them out entirely. A lot of offices have gone to using disposable prophy angles. Which leaves a lot of the metal ones in a drawer somewhere collecting dust. Also check the phone book under dental handpiece repair, they may have some old ones laying around too.
I don't want to sound like a smart-a__ here but what the general public refers to as the dentists drill is actually the high speed handpiece and what the hygenist uses to clean your teeth is refered to as the slow-speed handpiece. There is about 200,000 RPM difference.
Just explain to the Dr. what you are trying to do and you might be suprised what you might get. Besides it doesn't hurt to ask.
Old Feb 09, 2006, 05:03 PM
P_J_Glor is offline
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Yes, I know a modeler that got a lot of used tweezers and forceps that were great for modeling but no longer suitable for surgery from his Dr. friend.
When you say "too small dia tubes," are you referring to the tubes in your model being smaller than the Graupner or the Graupner tubes being smaller than you need for your model. If your tubes need to be smaller, I have seen a windshield washer pump hooked up to a manifold to shoot water out of either side of the bow to very good effect in small models. If the Graupner thruster is too small, it looks as if you have a little more room to work with.
Pete G.
Old Feb 09, 2006, 05:07 PM
tsenecal is online now
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
try
http://www.mfacomodrills.com/gearbox...cessories.html
specifically
Pt.No.919D24. Bevel Gearbox. which is listed towards the bottom of the page...
i have no idea how much it costs, however.
in addition to the above listed gearbox, they have quite a few items that you could use to build your own gearbox, including bearings and bevel gears in plastic and metal. i would check out their entire site...
Tim
tsenecal is online now Find More Posts by tsenecal
Discussion Right Angle Servo Headers rivers DIY Electronics 36 Aug 21, 2006 04:32 AM
Right Angle USB for Nikon mount in magpie? BlueDevil Aerial Photography 0 Apr 15, 2005 11:18 AM
Dremel Right Angle Drive $12.50 shipped 1987tc Aircraft - Electric - Airplanes (FS/W) 0 Nov 09, 2004 02:49 PM
Right angle thrust Maz Power Systems 1 Apr 01, 2004 05:08 PM
Getting the right angle on elevons tenover Power Systems 5 Mar 02, 2002 11:24 AM
