Old Feb 27, 2012, 07:26 AM
gblast123 is offline
Find More Posts by gblast123
Joined Feb 2012
This is an old thread but I am interested in this concept. There is a group out in Connecticut that makes these very small generators.
http://www.dstarengineering.com/
And they make a very small 2kw generator
http://www.dstarengineering.com/pist...r_Sets_2kW.pdf
It runs on diesel, no less. I suspect that a gas powered version would be much smaller.
gblast123 is offline Find More Posts by gblast123
Old Feb 27, 2012, 07:46 AM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
Those engines look close to normal, old time model plane gas motors.
That gen-set does not look small or light, is a couple feet across,
100-200 LBS.
Lithium batts are so cheap now, just get a bunch and put in series/parallel
for more endurance. Have them drop off the plane with chutes as they
wear down!
jglenn is offline Find More Posts by jglenn
Old Mar 03, 2012, 05:54 PM
macboffin is offline
Find More Posts by macboffin
North London ENGLAND
Joined Dec 2006
Originally Posted by Hovertime View Post
If you need 2kW of electric power it would have to have about 2.5kW of mechanical power provided TO the generator, and to be on the safe side it will need an engine that has 4kW of power max rating, and run it at 65% of its power. Or get an engine that has rated CONTINUOUS 2.5kW power rating.
As most said-much easier and economical just to use engine to provide 2kW for the props in the first place, skipping all th conversion loss.
And also skipping the extra weight and complexity,cost etc; and more bits means more potential for failure.
I have been involved in several military UAV projects where we took some power off the engine (generator on back end of shaft) to charge batteries, which act as smoothers, to supply avionics, downlinks etc but these were big boys with 40 hp upwards. If you want endurance/range, use diesel; Davis Diesel sell conversion units for a large range of "model" engines.
The downside about engines is altitude effects, guesstimate power loss is about 3% per thousand feet. If you want to go to real altitude, say 12k feet and above then go electric; electric motors don't have to breathe air with oxygen in it! At the end of the day its about; what range/duration, at what height, with what payload .
macboffin is offline Find More Posts by macboffin
Old Mar 07, 2012, 11:00 AM
DKTek is offline
Find More Posts by DKTek
DKTek's Avatar
United States, FL, Palm Bay
Joined Jul 2008
What about this small turbine driving the generator? I have a 2.5m Vario XLC heavy lifter helicopter that uses a much larger and thirsty 8 kw turbine. I've considered converting it to a hybrid electric with this smaller PHT2 running the gen. Initially it will be close in weight as using batteries but with the turbine, the fuel is burned off at 6.7 pounds per gallon. Battery weight stays the same either topped off or drained. The battery bird comes back with degraded performance, the hybrid comes home performing better than when departed.
DKTek is offline Find More Posts by DKTek
Old Mar 10, 2012, 09:35 AM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Sullivan RC make a range of alternators for RC engines
Lomcevac is offline Find More Posts by Lomcevac
Old May 16, 2012, 04:06 PM
Joined Dec 2006
Variation on the theme; Enya 90 conversion with twin plugs, running on gas, with integral generator, produced by Niklas Nyroth, ( now with Schiebel) for the "Buster" special forces area surveillance etc by Mitex, (Mission Technologies Inc.)
Old Aug 22, 2012, 06:37 AM
Hondaen is offline
Find More Posts by Hondaen
Norway, Hordaland, Bergen
Joined Aug 2012
Hello,
I`m a Norwegian electro engineer and inventor.
I have a interest for UAV`s and quads. The micro generator questions raised here have puzzled me for many years, with different designs.
For now, the best results for my work:
Weight: 2320gram
Power: 1150watt continuous.
Electrical power can be delivered in any way you want, DC, AC (one or three phase). My design use a switching mode psu, lightweight, yet powerful.
Now, I have power to weight ratio of apporx 0.5watt/gram. It is possible to do better, when kW numbers go up or if I use a gasturbine as powersource. I use a O.S. glowmotor at the moment.
Hondaen is offline Find More Posts by Hondaen
Old Aug 22, 2012, 10:44 AM
ekozxx is offline
Find More Posts by ekozxx
Joined Jul 2009
Originally Posted by Hondaen View Post
Hello,
Weight: 2320gram
Very interesting. Do you use regulator or switching psu only? I would like to know if you have schematic circuit diagram.
ekozxx is offline Find More Posts by ekozxx
Old Aug 23, 2012, 04:32 AM
Hondaen is offline
Joined Aug 2012
Hello
My design deliver adjustable 320 volt DC to 570 volt DC in a regulated steady-state.
Many reasons for this, but one of the best things about this design is the possibility to use the voltage direct into a common 220V AC 50Hz switch-mode psu, commonly available all over the world.
Reason: A ordinary switch mode psu first rectify the AC voltage into DC voltage. The DC voltage is square root of 2 higher the AC voltage value.
Thus, you can use 320V DC to direct-feed a normal computer psu (for example).
Or, you can feed a smal ABB frequency drive and get out whatever frequenzy or number of phases you want.
I hope this answer your question.
In designs (aero) that favor light weight, in my opinion, it is needed to go up with the voltage in order gain more fly-time. Higher voltage also means, in common, that Ah capacity of battery systems go up.
Losses rise with square root of the current, so we would like to minimize current
My spell: We will see more of high voltage setups in the future.
Old Aug 25, 2012, 12:33 PM
ekozxx is offline
Joined Jul 2009
deleted
Old Dec 11, 2013, 11:09 AM
Joined Dec 2006
Late reply
Not mentioned; applications. Frinstance, UAVs have to fly to area, loiter for data gathering, return to base; ie duration is important, turbines are too thirsty in small sizes!
Old Mar 31, 2015, 01:47 PM
DeValk is offline
Find More Posts by DeValk
Mr. Electron
DeValk's Avatar
Chilliwack, Canada
Joined Jul 2003
So I know this is an old thread but have you guys seen this http://www.tflighttech.com/products.html
A large hex with a generator on it to allow over 2 hour flight times. This is what I want to build next
DeValk is offline Find More Posts by DeValk
Old Apr 02, 2015, 05:51 AM
taag is offline
Find More Posts by taag
Joined Nov 2005
Hello,
Weight: 2320gram
I know it is a very old post and I'm sorry to use it but I didn't find any other project about this and I'm also interested about microgenerator, I ask you if you are interested to talk about it with me, Thank you
taag is offline Find More Posts by taag
Old Yesterday, 04:47 PM
Abdalayzer is offline
Find More Posts by Abdalayzer
Joined Apr 2015
Hello,
Weight: 2320gram
Hi! I trying now to build the same thing, can you maybe write me your email and help me bit? thank you!!
Matan
Abdalayzer is offline Find More Posts by Abdalayzer
Rave Setup for hybrid micro heli? eromeros Micro Helis 1 Feb 29, 2004 01:36 PM
Sub-Micro Servos For Sale ScotY Aircraft - Electric - Airplanes (FS/W) 3 Oct 18, 2001 01:21 AM
more on micro motors for fans dave morris Electric Ducted Fan Jet Talk 2 Oct 11, 2001 04:56 PM
micro servos for sale:cheap petn7 Aircraft - Electric - Airplanes (FS/W) 2 Sep 26, 2001 08:16 PM
What Micro Heli for a Learner????? Jamie- Electric Heli Talk 37 Jun 04, 2001 03:06 PM
