Old Feb 09, 2015, 08:38 PM
abecar9 is offline
Find More Posts by abecar9
abecar9's Avatar
United States, GA, Atlanta
Joined Jan 2015
Help!
power up
I own a Thunder AC680 charger for my lipos and just bought a field box. My question is : can I purchase a 12v 7ah rechargeable battery and power up my Thunder charger to charge my lipos? I don't want to but a power panel when I have a charger. Any advice or recommendations is much appreciated.
abecar9 is offline Find More Posts by abecar9
Old Feb 10, 2015, 02:57 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Yes but....it depends what "my lipos" are. A 12V 7AH battery is only going to be able to charge one or two fairly small lipos before it runs out of power. You might just get something like a couple of 3S 2200mAh charges out of it.
There are good reasons why people lug 100AH charging batteries around with them.
Steve
slipstick is online now Find More Posts by slipstick
Old Feb 10, 2015, 05:57 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
You will also get a very short life time out of that 12v 7AH battery; just one or two deep discharges (below 11.9 volts at rest) will ruin it. A Pb battery takes a lot of care to keep any reasonable lifetime for it. Never fast charge, never deep discharge and never overcharge.
Rodney is offline Find More Posts by Rodney
Old Feb 10, 2015, 05:10 PM
abecar9 is offline
abecar9's Avatar
Joined Jan 2015
Steve
The largest battery I have is an 1800. Do you think a 20ah rechargeable would work?
Old Feb 11, 2015, 02:38 AM
Staffs, UK
Joined Nov 2003
It's the total energy that's important so just "1800" tells you nothing. If it's a 2S 1800mAh battery it only need half the energy of a 4S 1800mAh pack. One of them you could safely charge maybe 9-10 times from a 20Ah battery, the other only about 4-5 times.
If you do most of your charging at home and only the occasional charge at the field then you might be o.k. Only you know what batteries you have, how many of them and how many you want to charge in a day at the field.
I have used a 12V 17Ah battery to run a charger but mainly for indoor stuff (1S 150mAh batteries). Normally I do all my charging at home and only maybe 2 or 3 charges at the field. If I'm going to want more than that I run the charger from my (85Ah) car battery....with the car running to keep it topped up.
Steve
Old Feb 11, 2015, 02:48 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Take the supply battery's Ah, divide it by 2, then multiply it by the nominal voltage, and you'll get how much energy it can probably supply. So 12v x 20Ah x 1/2 = 120 watt-hours.
Then do the same with your LiPos, except don't divide by 2, and you'll get how much energy they need to fully charge. So a 3S (just guessing) 1800mAh LiPo will require 12.6v x 1.8Ah = 23 watt-hours.
That shows that, assuming your LiPos are not fully discharged, so don't need a full charge, you might get six charges out of your suggested battery provided it's fully charged and in good condition.
abenn is offline Find More Posts by abenn
Sold Kong Power Lipo Charger up to 6S. Plus 2 Kong Power 3S 2200mah 25c lipos. richord Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 25, 2015 10:27 AM
Sold SOLD Watt Up Power meter, Watts, Amps, Mah and more. Bonestockz06 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 26, 2014 09:36 AM
For Sale Power Up 3.0 Paper airplane kit outflying3d Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 25, 2014 06:52 PM
Discussion Power up DSM2 6ch rx from Heads up Hobby stamp80 Radios 0 Aug 13, 2014 07:36 PM
Sold REDUCED PRICE Heads Up RC Power Up Sport 25 Brushless Motor KenSue Aircraft - Electric - Power Systems (FS/W) 3 Mar 27, 2014 11:43 AM
