Old Sep 18, 2014, 01:45 AM
park aviator is online now
Find More Posts by park aviator
park aviator's Avatar
Australia, NSW, McGraths Hill
Joined Mar 2008
Help!
laser cutting depron
Hi guys anyone have experience with cutting 6mm depron on a 60 watt laser I have a 60 by 40 cm machine and am struggling to get a decent straight cut
park aviator is online now Find More Posts by park aviator
Old Sep 18, 2014, 08:34 AM
shutterbug772 is offline
Find More Posts by shutterbug772
Joined Jun 2012
If you have mirrors and lens from China you will notice an inferior cut. Make sure the optics are as clean as possible. Take the time to make sure everything is in focus and will maintain focus over the sheet of depron. Instead of focusing on the top of the depron, focus in the center of the material. Set your speed at a high setting. Cut fast with just enough power to get through the material. Adjust corner power as needed to prevent melt out.
Jim
Jtechlaser
shutterbug772 is offline Find More Posts by shutterbug772
Old Sep 18, 2014, 08:56 AM
RCROBBY is online now
Find More Posts by RCROBBY
Laser Cutter Guy
United States, PA, Greensburg
Joined Oct 2009
I cut 6mm often on my laser. My laser is a 36"x48" 120 watt. you cannot use the "air pump" air when cutting depron. You must use an alternate source of air. and the speed and power settings are very critical at 6mm. Also you must set your focus to be half way into the material. this will give you an acceptable cut with repeatable results.
RCROBBY is online now Find More Posts by RCROBBY
Old Sep 18, 2014, 09:21 AM
Laser Cutter Guy
Joined Oct 2009
Jim
Jtechlaser
Jim, I have had my laser, with China optics, for over 4 years and I call BS on that statement.
Old Sep 18, 2014, 09:35 AM
eliworm is online now
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
(posted from my wife computer before)
If you are getting good results thats fine. I have done experiments with my lasers going back and forth between optics and could detect enough difference that I don't care for the Chinese optics. Laser companies offer alternative optics for reasons more than just to make money.
Also, good call on the “air pump”. I had forgot to mention that a continuous source of air is a better alternative.
Jim
Jtechlaser
eliworm is online now Find More Posts by eliworm
Old Sep 18, 2014, 10:28 AM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
You will never get a 100% straight or true cut with any laser machine. Heat is your enemy!
txt killer is offline Find More Posts by txt killer
Old Sep 24, 2014, 10:46 PM
bluesky123 is offline
Find More Posts by bluesky123
Crash=change of flying medium
bluesky123's Avatar
Boulder, CO
Joined May 2002
I have Epilog Mini with 40W laser at work. Tried cutting 6mm Depron at max speed and very low power (don't remember exactly, something like 5W). No matter what I tried, the cut was never straight--the center melted more then surfaces resulting in the hourglass shape cross-section...
bluesky123 is offline Find More Posts by bluesky123
Old Sep 26, 2014, 11:29 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Lots of air helps. I make small line breaks to retain the parts. I too have a Chinese laser. It has a 80W RECI tube and 600x400mm cutting area. It's not possible to get a 100% straight cut with a laser due to how the beam is focused.
epilot is offline Find More Posts by epilot
Old Sep 26, 2014, 01:14 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
6mm and thicker depron results in a taper or hourglass shape to the cut. This can be used to your advantage. If you lay out the formers the taper can work with the direction of laying up the sheeting, same with a tapered wing. Just pay attention to left and right. Most of the time it doesn't make a lot of difference when you are sheeting over the foam.
If it is something you don't want a taper then use thinner depron and laminate the pieces together.
charlie
portablevcb is offline Find More Posts by portablevcb
Laser Cutting Depron?? mike98624 3D Flying 17 Aug 20, 2013 09:49 AM
Discussion Depron Laser Cutting at booth 150 gguidi Toledo Weak Signals RC Expo 1 Apr 12, 2007 04:58 PM
Question Depron Laser Cutting Tsquare Vendor Talk 0 Aug 04, 2006 11:37 AM
Discussion Intercepter Laser Depron Cutting bobbddd Foamies (Kits) 0 May 15, 2006 08:46 AM
Laser Depron cutting Balsa+Nitro Foamies (Kits) 2 Jun 14, 2005 10:32 AM
