Old Aug 24, 2014, 06:14 PM
crash_1958 is offline
Find More Posts by crash_1958
crash_1958's Avatar
Canada, BC, Victoria
Joined May 2010
Just finished my first weekend of flying with my ZMR250 from Banggood and this is now my favourite quad to fly.
Did a 1k flight down the beach and then some proximity flying in the trees and it handled both with out any problems.
Defiantly a keeper.
Weekend Fun with the ZMR250 (4 min 43 sec)
crash_1958 is offline Find More Posts by crash_1958
Old Aug 24, 2014, 06:40 PM
RC_Flying is offline
Find More Posts by RC_Flying
United States, NJ, Edgewater Park
Joined Dec 2013
Defiantly a keeper. ]
Looks great,nice video,makes me want to try FPV asap. Never tried it before.
Good tune in the video too. What's the name of the song?
RC_Flying is offline Find More Posts by RC_Flying
Old Aug 24, 2014, 06:47 PM
RC2211 is online now
Find More Posts by RC2211
Quad fun for everyone!
RC2211's Avatar
United States, WI
Joined Oct 2013
FPV is so fun... definitely worth getting into.
The guys in this thread could help with great setups too!
RC2211 is online now Find More Posts by RC2211
Old Aug 24, 2014, 07:03 PM
Joined Dec 2013
I would probably get a Frksy module for my Turnigy 9X transmitter to do long range flying,don't think my Spektrum DX6i and OrangRX receiver could travel 1k.I will do some more reading about long range receivers.
Any tips on which receiver and module to get would be appreciated.
Along with this FPV RX/TX : Boscam FPV 5.8G 600mW 32CH Wireless Transmitter Receiver TS832 RC832
http://www.banggood.com/FPV-5_8G-600...2-p-84771.html
Old Aug 24, 2014, 07:16 PM
CO_rcDude is offline
Find More Posts by CO_rcDude
Switching to guns!!!
CO_rcDude's Avatar
Littleton, CO
Joined Dec 2009
Originally Posted by Daryoon View Post
Those EMax are SilLabs based chips fr what I can see in the photos.
Therefore, it can run BLHeli. Not SimonK. Despite the misleading name of "Simon Series"
I believe it already comes flashed with BLHeli.
Correct on all counts. Romeo (MassiveRC) has some Emax ESC's on the way. I asked the same question, and Emax confirmed with him that they are indeed using customized BLHeli firmware, despite the misleading name.
Originally Posted by Nelis View Post
Is there any advantage to get SimonK ESCs over BLHeli ESCs?
I was also thinking of getting those Emax 12A ESCs...
The Emax ESC's are said to be quite good. I just maidened today on a set of them, and they work great. From what I've read, BLHeli firmware is more stable / compatible than SimonK.
CO_rcDude is offline Find More Posts by CO_rcDude
Old Aug 24, 2014, 07:20 PM
RC2211's Avatar
United States, WI
Joined Oct 2013
I would start off with a shorter range setup first, to make it an easier learning curve and less chance of a bad accident (lost quad ).
I actually like the Boscam 8 channel 5.8Ghz 200mw VTx/VRx for an FPV beginner setup. It is a very cheap, very easy to use and a perfect starting point (usually sold $50-60, HK has it and probably BG), paired with good CP antennas. Should get you at least 300 (probably more) yards of range with antennas placed properly. For that, any diversity or full range Rx will easily get you the range.
After some practice it is easy to beef up the system for great range.
Old Aug 24, 2014, 07:21 PM
Joined Dec 2013
Thanks for the insight guys on the Emax esc's. Nice to have more options for esc's.
jtice is offline
Find More Posts by jtice
jtice's Avatar
United States, WV, Fairmont
Joined Oct 2009
Some of you have mentioned the old and new GemFan 6x3 props...
How do you tell the difference?
Also, I have some black ones, and gray ones, the gray ones are MUCH stiffer than the others.
Anyone tested those?
Cant wait for the rest of my parts to get here so I can get this quad built!!!!!
jtice is offline Find More Posts by jtice
Old Aug 24, 2014, 07:30 PM
nebbian is online now
Find More Posts by nebbian
Re-kitting planes since 1990
nebbian's Avatar
Australia, WA, Beldon
Joined Jun 2013
Was thinking about trying different esc's.
Has anyone used the Emax 12amp ESC's with SimonK?
If so,what is your experience with them?
Do they have heat sinks?
I've been using the Emax 12A "Simon series" ESCs on my cloneout, and they work really well. Don't seem to get hot, very stable, plenty of power.
As others have said, they run BLHeli, not simonk. For some reason the marketing people thought that simonk sounded better than blheli (despite from what I understand blheli being at least as good, if not better than blheli, especially for small mini pancake motors).
The only funny thing about them is the startup tones... they go on for a while!
Recommended
nebbian is online now Find More Posts by nebbian
Old Aug 24, 2014, 07:31 PM
Joined Dec 2013
Sounds good.The other day I ordered the Quanum DIY FPV Goggle Set with Monitor (KIT) from Hobbyking,some omnidirectional anntenna's and already have a Lumenier CP-520 Pico - 520TVL Nano Camera I was going to use for a micro quad. So I just need the RX/TX.
Old Aug 24, 2014, 07:33 PM
CO_rcDude's Avatar
Littleton, CO
Joined Dec 2009
Apparently, the orange and green ones are the newer ones (they didn't make those colors in 6030 before). However, I don't know how you could tell the difference between the newer black glass mix ones versus the old black carbon mix ones.
Old Aug 24, 2014, 07:35 PM
FLDataTeK is online now
Find More Posts by FLDataTeK
ModifiedRC Guru
FLDataTeK's Avatar
United States, FL, Jacksonville
Joined Dec 2013
The blades are super thin.. You almost tweak them tightening the nut down for the prop. They are also black, I think the newer ones are grey.
FLDataTeK is online now Find More Posts by FLDataTeK
Old Aug 24, 2014, 07:38 PM
jtice is offline
jtice's Avatar
Joined Oct 2009
Well I have black 5x3 and 6x3 and the grey 6x3 to try on this quad.
I will let you guys know how they do, but by feel, unless they are brittle, the stiffer grey ones seem like they would do great and provide a ton of power.
ModifiedRC Guru
FLDataTeK's Avatar
Joined Dec 2013
I'd suggest a Boscam TS5823 due to its smaller size and can run off of 2S-6S batteries if he was going to start in the 200mw range. Other wise I would get its bigger brother the TS58500 500mw 32 channel
Its also a 32 channel vTX.
Old Aug 24, 2014, 07:45 PM
medimatt is offline
Find More Posts by medimatt
United States, CA, Dana Point
Joined Oct 2013
just threw some FC 6045 props on my RCX 1806.. holy crap.
medimatt is offline Find More Posts by medimatt
Build Log Carbon fiber & Balsa composite H frame hd27 Scratchbuilt Multirotors 19 Nov 17, 2014 02:09 PM
Found Mini H Quad Frame Carbon Frame / ARF / RTF / FPV BajaSky619 Aircraft - Electric - Multirotor (FS/W) 1 Apr 09, 2014 05:41 PM
For Sale BAH Mini H Quad - Carbon Fiber Frame (version 1) starvinmrvn Aircraft - Electric - Multirotor (FS/W) 2 Mar 04, 2014 03:49 PM
Sold Carbon fiber mini H-frame with motors/ ESC's and 2 sets of props!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 2 Aug 31, 2013 01:11 PM
Sold Butterfly X250 330mm Shaft Mini QuadCopter Fiber Carbon Frame, Brand New $35 Shipped nautique Aircraft - Electric - Multirotor (FS/W) 2 Jan 25, 2013 04:09 PM
