Old Mar 23, 2014, 07:28 PM
Flying Pitcher is offline
Find More Posts by Flying Pitcher
الآن كنت تتحدث لغتي
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
sir, if you take it to the extreme level of flying, then let's agree that you can "fly out of updraft", but it's definitely not the way most pilots take Fixed pitch heli flyers, yes if they are in trouble and have enough skill, they will make the move, but on collective pitch, you just go into negative.
if the wind is really bad where it rolls you over in a gust, you probably won't be flying.
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Mar 23, 2014, 11:24 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
When a gust hits negative pitch is often the opposite of what you want. The gust ends with the helicopter dropping like a rock.
Roto Rob is offline Find More Posts by Roto Rob
Old Mar 24, 2014, 12:29 AM
Florida Heli is offline
Find More Posts by Florida Heli
Expert Heli Crasher
Florida Heli's Avatar
Joined Jan 2014
Originally Posted by Palm Desert Heli View Post
Can you fly a CP with no Neg pitch? Would it help a CP beginner? Or you don't want to do heli aerobatics?
Thanks!!
Instead of bickering, which does not belong in the Beginner Training Area at all ...
I'm going to point OP to a useful thread he may or may not be familiar with:
http://www.rcgroups.com/forums/showthread.php?t=1901484
Originally Posted by CaptJac View Post
First - and most importantly - get rid of all that negative pitch. -2 degrees (-2) is all you need in the beginning - and this is to insure you can get back down on the ground and glue you to the ground if there is any wind.
Your pitch curve will be -2, 0, 3, 5, 8.
Now you are controlling altitude with pitch and not head speed. This will give you far smoother control of maintaining your height - just like a full scale helicopter.
Note: At any time you want to shut off the engine - try to avoid slamming the collective down - this negative pitch will pull the heli into the ground. Condition your finger or thumb or big toe (whichever works for you) to switch ON throttle-hold or throttle-cut when you panic. This will maintain your positive pitch on the blades and help eliminate the pan-cake effect.
captJac
Thank you again CaptJac. Please refer comments and criticisms to him. Works for me in the sim at least.
Also do not ignore:
Originally Posted by Balr14 View Post
You can, but it just cripples handling with no real benefit. If you just set negative pitch to 2 or 3 you won't come down real hard and you learn quickly not to do that.
Thank you again Balr14. Please refer comments and criticisms to him. Works for me in the sim at least.
-Florida Heli-
Florida Heli is offline Find More Posts by Florida Heli
Old Mar 24, 2014, 02:52 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Its a bad idea to plant a helicopter on the ground with negative pitch. Your just asking to break it. Especially if it has a flybarless controller.
Old Mar 24, 2014, 08:33 PM
spykez is offline
Find More Posts by spykez
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
Well, quite a few of us do it to no ill effect, just saying.
Ever tried landing a 450 in 30-40 km/h winds with random gusts?
Winds like that ground planks, but not us.
spykez is offline Find More Posts by spykez
Old Mar 24, 2014, 11:32 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
30-40 km/h winds are fairly common around here. So I land a 450 in that kind of wind most of the times I fly.
I fly my planks in that kind of wind also.
Old Mar 25, 2014, 05:41 PM
focar is offline
Find More Posts by focar
United States, CA, Napa
Joined Jun 2013
With all do respect to real helicopter pilot's, us nube's don't fly much in the wind. At least I can't. I do understand that -2 or-3 is needed............just a little sarcasm to lighten things up.
focar is offline Find More Posts by focar
Discussion setting negative pitch on Spektrum DX9 pschmutz Electric Heli Talk 9 Jun 09, 2014 09:12 PM
Help! Negative pitch problem Pinata14 3D Electric Heli Flying 5 Feb 21, 2014 07:01 PM
For Sale 100% RTF Trex 600 NSP FB + Jr9503 + Extras 750$ Neg Fuel And Fly! HeliMan3D Aircraft - Fuel - Helis (FS/W) 7 Dec 26, 2013 03:34 PM
Question How to change heli so that I don't get negative pitch when at 0 throttle? Domster_26 Electric Heli Talk 5 Sep 30, 2013 09:17 AM
Discussion Throttle curve with no negative pitch? BowerR64 Mini Helis 18 Aug 12, 2007 05:40 AM
